Hi, just switched to a new i713th Gen PC with integrated GPU.
MPC-HC is not working like it used to.
When playing a video, clicking anywhere on the timeline updates the preview in pause/play mode.
But unlike my old windows 7 PC, after I've clicked to the end of the video, but choose to click any point back on the timeline, the screen doesn't update to match the frame I've clicked on, until I click stop and play again.
Does anyone know a solution to this?
Well my Win7 also works they way you previously described.
Could it be that an upgrade to the sw has altered this - my version is not new and I rarely upgrade (if it ain't broke then why try to fix it). The 'fix' may be to install the version you previously used (unless that is the one that now does not work) from the list on this site's link. -
mpc-hc -cant scrub randomly and time skip
By rocketman122 in forum Newbie / General discussionsReplies: 6Last Post: 14th Dec 2023, 17:13 -
K-Lite Standard 17.x MPC-HC won't use VID (video engine).
By bookagood in forum Software PlayingReplies: 2Last Post: 8th Aug 2023, 09:13 -
Umatic Problem- Black/Snowy Video on Playback, yet Video Visible in Scrub?
By peahix in forum Capturing and VCRReplies: 21Last Post: 30th Apr 2022, 22:42 -
Which video player will scrub and has easy frame capture ?
By DBenz in forum Newbie / General discussionsReplies: 16Last Post: 26th Oct 2019, 14:41 -
Can I install Machete on more than one machine? Is it portable?
By drstew12 in forum EditingReplies: 10Last Post: 14th Sep 2019, 20:18
