Hello,
I've been struggling with something for a couple of weeks now and am becoming very desperate for an answer. What I'm trying to do is take a Blu-Ray which I have created from a DVD using DVDtoBD Express and replace the main video files on there to my own authored video files that are better quality but keep the menus. Then burn the updated files to a BD-R disc. I'm not sure if doing something like this is possible at all due to the fact that I've found little to no threads related to this.
I tried using multiAVCHD but for whatever reason, it's not allowing the files to be replaced and then put on the disk properly. If anyone can direct me to a program that might help or tell me this isn't possible that'd be greatly appreciated. Thank you!
Results 1 to 1 of 1
BDInfo, VLC, and Video Streams on 4K UHD Blu-ray Discs
By Chris Kelly in forum Software PlayingReplies: 4Last Post: 9th Mar 2022, 04:01 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 12:02 -
Replacing .M2TS to a Blu Ray
By RafaMR14 in forum Authoring (Blu-ray)Replies: 8Last Post: 16th May 2020, 05:54 -
FFMPEG - Replacing a video stream, while keeping all other streams the same
By vandalay22 in forum Video Streaming DownloadingReplies: 4Last Post: 11th Nov 2019, 10:41 -
Replacing subtitle tracks on Blu-Ray discs??
By LinkingHeartZ in forum SubtitleReplies: 10Last Post: 27th Aug 2019, 10:46
