Hi, I have burned some VCD's and they play on my PC
but the DVD just says no disc. can someone help.
That could be due to a number of things. Are you sure your player will play VCDs? Most do. If so, what type of media are you using? Can your player read Cdr or Cdrw? What brand? If you haven't looked up your player on the DVD player list, it would be a good start. That might shed some light on your problem. It seems to me that the type of media is the most common problem.
thx for the reply. I have tried a number of types of media
but none work. it does play audio cdrs though.
Should a vcd just autoplay on a standalone player.
Please help.
I read the list and it says it cant play cdr cdrw but it does as audio works -
Sad news...I looked up your player and it won't play CDR or CDRW according to the reviews. Check this out:
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=96&Search=Search&list=0
It probably only plays commercial VCDs. My experience with Hitachi's are they suck for compatibility. I have a friend who has one and his won't play jack.
Don't confuse audio cd-r's with video cd-r's - they are different.
If it says in the list that your DVD Player cannot read CD-R's it means that it can't read Video files on CD-R. -
Thx for the help guys. Looks like I'm F*$ked.
Some of the guys reporting on this player said that
they were able to use cdr VCD's -
try Mr. Write CD-RW 4X. It works on most DVD players which do not accept Princo CD=r & CD-RW.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
.ogm Won't play
By shiroshadows in forum Software PlayingReplies: 8Last Post: 2nd Jan 2010, 20:38 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 15:29 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
