Hello! One of my hobbies is video editing, but the software I'm using (Sony Vegas) does not support MKV videos, so I always convert them to MP4 with MKVtoMP4. I've been using it for years and I know it's not being developed anymore, but words can't describe how much I love it, because it converts relatively quickly and with almost no quality loss, not to mention it's free. (The only other converter I use is HandBrake, but only as last resort, because it's too slow.) Anyway as of quite recently there's a problem when I try to convert with MKVtoMP4. Here's the error log:
Starting x264 with the parameters:
../Tools/x264/x64/x264 --vf resize:1280,720 --crf 20.000 --preset veryfast --no-interlaced --profile high --level 4.1 -o "../Temp/video.h264" "C:/Downloads/TV Shows/The.Falcon.and.the.Winter.Soldier.SEASON.01.S01.CO MPLETE.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA/The.Falcon.and.The.Winter.Soldier.S01E01.New.World .Order.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA.mkv"
ffms [error]: could not create video source
lavf [error]: could not find decoder for video stream
avs [error]: failed to load avisynth
raw [error]: raw input requires a resolution.
x264 [error]: could not open input file `C:/Downloads/TV Shows/The.Falcon.and.the.Winter.Soldier.SEASON.01.S01.CO MPLETE.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA/The.Falcon.and.The.Winter.Soldier.S01E01.New.World .Order.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA.mkv' via any method!
x264 terminated with error: 4294967295
Total time: 6 sec.
0 files processed.
1 errors.
So I wanted to ask what can I do to solve this error? Thank you for your help in advance!
Here's the mediainfo report:
General
Unique ID : 127705967623897516585708407339682858354 (0x601346538CF4AAFDE98AF84295178572)
Complete name : C:\Downloads\TV Shows\The.Falcon.and.the.Winter.Soldier.SEASON.01. S01.COMPLETE.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA\The.Falcon.and.The.Winter.Soldier.S01E01.New.W orld.Order.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA.mkv
Format : Matroska
Format version : Version 4
File size : 945 MiB
Duration : 47 min 18 s
Overall bit rate : 2 794 kb/s
Frame rate : 24.000 FPS
Movie name : PSArips.com | The.Falcon.and.The.Winter.Soldier.S01E01.New.World .Order.2160p.10bit.HDR.WEBRip.6CH.x265.HEVC-PSA.mkv
Encoded date : 2021-03-19 22:15:07 UTC
Writing application : mkvmerge v55.0.0 ('Waiting For Space') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 47 min 16 s
Bit rate : 2 593 kb/s
Width : 3 840 pixels
Height : 1 608 pixels
Display aspect ratio : 2.39:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.017
Stream size : 877 MiB (93%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Audio
Format : AAC LC SBR
Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name : HE-AAC
Format settings : Explicit
Codec ID : A_AAC-2
Bit rate : 199 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 23.438 FPS (2048 SPF)
Compression mode : Lossy
Delay relative to video : 23 ms
Stream size : 67.5 MiB (7%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 42 min 35 s
Bit rate : 68 b/s
Frame rate : 0.264 FPS
Count of elements : 674
Stream size : 21.2 KiB (0%)
Title : English (SDH)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Duration : 45 min 48 s
Bit rate : 46 b/s
Frame rate : 0.139 FPS
Count of elements : 383
Stream size : 15.8 KiB (0%)
Title : Dansk
Language : Danish
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 48 b/s
Frame rate : 0.187 FPS
Count of elements : 515
Stream size : 16.2 KiB (0%)
Title : Deutsch
Language : German
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 52 b/s
Frame rate : 0.209 FPS
Count of elements : 574
Stream size : 17.7 KiB (0%)
Title : Español (Latinoamericano)
Language : Spanish
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 53 b/s
Frame rate : 0.207 FPS
Count of elements : 569
Stream size : 18.0 KiB (0%)
Title : Español
Language : Spanish
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 45 b/s
Frame rate : 0.206 FPS
Count of elements : 565
Stream size : 15.3 KiB (0%)
Title : Suomi
Language : Finnish
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 48 b/s
Frame rate : 0.204 FPS
Count of elements : 562
Title : Français
Language : French
Default : No
Forced : No
Text #8
Format : UTF-8
Duration : 43 min 17 s
Bit rate : 50 b/s
Frame rate : 0.216 FPS
Stream size : 16.0 KiB (0%)
Title : Français (Canadien)
Language : French
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 54 b/s
Stream size : 18.2 KiB (0%)
Title : Indonesian
Language : Indonesian
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 48 b/s
Count of elements : 566
Stream size : 16.3 KiB (0%)
Title : Italiano
Language : Italian
Default : No
Forced : No
Text #11
Format : UTF-8
Bit rate : 48 b/s
Frame rate : 0.146 FPS
Count of elements : 400
Stream size : 16.1 KiB (0%)
Title : Nederlands
Language : Dutch
Default : No
Forced : No
Text #12
Format : UTF-8
Bit rate : 45 b/s
Stream size : 15.2 KiB (0%)
Title : Norsk
Language : Norwegian
Default : No
Forced : No
Text #13
Format : UTF-8
Bit rate : 53 b/s
Frame rate : 0.208 FPS
Count of elements : 571
Title : Português (Brasil)
Language : Portuguese
Default : No
Forced : No
Text #14
Format : UTF-8
Bit rate : 50 b/s
Frame rate : 0.202 FPS
Count of elements : 555
Stream size : 17.1 KiB (0%)
Title : Português
Default : No
Forced : No
Text #15
Format : UTF-8
Bit rate : 51 b/s
Frame rate : 0.155 FPS
Count of elements : 427
Stream size : 17.2 KiB (0%)
Title : Svenska
Language : Swedish
Default : No
Forced : No
Use clever FFmpeg-GUI.
Download it, extract the exe file, start it and follow the instructions.
Then load your video, click main, click multiplex, select mp4 as container, click multiplex.
Done. -
"I'm with you 'till the end of the line!" ~ Bucky Barnes
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
Problem with HSBS 3D mkv when converting from in-mux 3D bluray
By NetDragon in forum Video ConversionReplies: 0Last Post: 25th Jul 2021, 17:43 -
Seeking advice on converting .iso to .mkv or .mp4 -
By vhwul62 in forum Video ConversionReplies: 10Last Post: 12th Jan 2021, 07:22 -
HELP !! Convert sub(SRT and SSA) to MKV with MkvToMp4.
By piggy21212 in forum Newbie / General discussionsReplies: 5Last Post: 25th Nov 2019, 02:14 -
Converting from MP4/MKV to MTS
By smithb in forum Video ConversionReplies: 4Last Post: 17th Oct 2019, 14:21
