Results 1 to 9 of 9
  1. Hi,
    It's been all day long I'm trying to DL a video from M6+. The url is here : https://www.6play.fr/un-jour-un-doc-p_22196/mon-menage-a-petits-prix-c_13072170
    I found the PSSH and the licence link, but I'm stucked with these informations. Plus I'm on a mac, even if I've already installed yt-dld. But if you can help me, and explain to me how does that really work it would be awesome.
    Thanks !
  2. I see, you just registered .....
    Have a look at here "N_m3u8DL-RE"
    https://forum.videohelp.com/threads/407987
    And perhaps this may also be relevant on Mac
    https://forum.videohelp.com/threads/414856
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
  3. Hi !
    Yeah I tried to read as much as I can, and I keep going ahah
    Thanks for your quick answer, I read these two pages, thank you so much.
    But I'm still stucked on finding the key. When I use CDRM Project, it always says to me "Headers could not be loaded correctly, please make sure they are formatted in python dictionary". But I just copy and paste what I found on the cenc file.
  4. Originally Posted by quinouol View Post
    Hi !
    Maybe try this awesome tool
    https://forum.videohelp.com/threads/414140
  5. Member aqzs's Avatar
    Mar 2024
    Paris
    Hi !
    You need to convert ccurl to python dict using https://curlconverter.com/.
    Download command :
    N_m3u8DL-RE "https://lbcdn.6cloud.fr/resource/m6web/s/m6web/output/3/4/7/3479f324fa4d3fc2e5252281e6451375c6658fa3/static/13072170_4dd58121fa8786e22824e260053a5c76_web_dash_upTo1080p_1080p_vbr_cae_drm_software.mpd?expiration=1718775300&scheme=https&groups%5B0%5D=m6web&token=TRUNCATED" --save-name "Un jour, un doc - Mon ménage à petits prix" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --log-level OFF --key 72315416e2cd7b34cee455938efe66f9:2027e6721feeee93b4b9f4448fdff688
    Download link : https://www.swisstransfer.com/d/b3fb7001-7a50-45c1-a719-3120cd3b46b4
  6. Good morning and thanks to you two !
    @PSSH, thank you for this tool, it looks awesome. I might doing it wrong but I'm not able to dump CDN keys because I have a Mac. Maybe there is another solution or maybe I just misunderstood something, but it looks that it won't work for me.
    @Aqzh Thanks for the code and the file, it is really helpful. But I really would like to understand how to do in order to don't bother anyone another time. I used the curlconverter, but I got the same message in CDRM project. Maybe I have to change something in the header ?
    Here is what I got :
    import requests
    Thank you again
  7. Originally Posted by quinouol View Post
    Thank you again
    I do not believe it's OS dependent
    https://github.com/FoxRefire/wvg/tree/next
    it works under Linux (more in FF... at least for me).
    Also, it looks like you are running out of date OS ...Catalina support finished November 30, 2022...
    The headers also contain all sorts of information you do not want to publish online ....IMHO
  8. Thanks again.
    Yeah it works well with their example, but the second step of the pre-setup doesn' work for me because I need to boot an android device on a PC, if I understand well, it's the CDM keys that helps the tool to get the keys. So the plugin works well but can't find the key for the website. Besides, I'm not on Catalina but on Sonoma on the latest version so it won't be a problem.
    Oh ok I will delete the headers then, but can you explain to me why it doesn't work in CDRM Project ? I guess I don't know where to start an stop the copy paste maybe...
    Thank you again
  9. This shows a different story:
    'User-Agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36'
