But each frame is different (when doublerate deinterlaced). There is major motion at every second frame, but the following frame is also (just) different; but it's certainly not the same. Your GIF shows this. Isn't this video PSF, as per post #18?Originally Posted by Lollo
Results 31 to 51 of 51
Here is another clip
VirtualDub direct stream copy
The colorspace should be correct this time.
Lagrith codec used, Lagrith does not flag interlacing always shows progressive but I don't think it is.
https://files.videohelp.com/u/308503/riceD.avi
Thanks everyone for helping -
The video is progressive (PsF), as before. There is no motion between the even and the odd field. Separating the fields and stepping through the fields gives a pattern like aabbccddeeffgghh..., with motion between the pairs only.
This is how interlaced would look like. Now you see motion between every field, not just between pairs of fields.Last edited by Sharc; 1st Jul 2024 at 11:13.
As Sharc already said this is again a "progressive" video, aka PsF.
You should get familiar with AviSynth and check the fields architecture by yourself. Here a simple script. You load it in VirtualdDub (for example) and step field-by-field analyzing the pattern repetition (aabbccddeeffgghh... in this case, as Sharc explained, meaning "progressive "source).
Code:video_org=AviSource("riceD.avi") # separate fields tff video_org_sep_tff=video_org.AssumeTFF().separateFields() # to check if progressive or interlaced return(video_org_sep_tff)
As a demo here a comparison of the 2 variants side-by-side, after separating the fields and stepping in slow motion through the fields as per Lollo's instructions.
Left is your progressive (aka PsF) source. Right is what you would get if your source were interlaced. You see that the progressive (PsF) version has motion with every 2 fields only, while the interlaced variant has motion with every field advancement. -
Originally Posted by LolloOriginally Posted by VHS
"For a progressive or PSF source, don't deinterlace, just encode it as-is into whatever final format you want"? -
Please tell me the correct settings to use for Moviestudio.
If I choose progressive I get the interlaced looking lines.
It has quite a few options.
When I import it asks me do I want to match source if I do match source it imports it as progressive and if I encode it progressive I get interlaced looking lines, we know it's not because experts say it's PSF. I always get progressive source on both Huffyuv and Lagrith.
In project properties playback you have
Upperfield
Lowerfield
Progressive
For de-interlacing you have blend fields or interpolate fields. (It only de-interlaces if upper or lower are chosen.
Then another confusing options disable resampling (I don't know what this does) and the reduce interlace flicker should that be left off or on? I've used it and it does get rid of jagged lines
If you right click source it's progressive by default, it can be changed to upper or lower fileds
then when rendering the same issue you have 3 options render progressive upper field or lower filed, should everything match project
properties? -
Are you sure? Just becasue Mediainfo says it's progressive, you should check it in Vdub2 to confirm.
Secondly, if all your captures are progressive, something must be going wrong in your capturing process.
In general you set the project based on your requirements, then you properly define the source and how it should be handled. -
Originally Posted by VHS).
What is your capture device and what program are you using to capture?
Originally Posted by VHSVideoCapture
For your VHS captures, which will be Interlaced, TFF (even though they might look like they're progressive):
-set the movie framerate to 50fps and 720x576, 4:3.
-if you have version 2022 or later, there's a new bug with analogue video import. In the video object properties, set the aspect ratio to 1.33 (not 1.33333 or 4:3).
-set the Interlacing to TFF (should already be set from the clip info).
Leave the other interlacing options in video object properties unticked.
That should result in a smooth, progressive video. -
I'm getting PsF it looks progressive I need to learn how to deal with PsF in Moviestudio
They aren't actually progressive, only lagrith shows as progressive, Huffyuv wrong shows it BFF lower field first so it's not progressive.
I need someone to tell me the correct settings for Moviestudio. -
I did, before here it is again the rice.avi clip is how all my captures look
The experts say it's PsF I don't know how to handle Psf video in Moviestudio or VD..
I just noticed 1 thing in the capture pin tab of virtualdub the quality level is set to half way other settings are fine 720×576 PAL
25 FPS.
I'm using Huffyuv, will having the quality slider half way effect final file quality?
Will I have to recapture. If I'm using ES15 will this also effect quality and make the video progressive? -
GV-USB2 wave option selected in driver settings to keep it interlaced.
Virtuldub 1.911 because it's what is suggested the modt for capture.
I will do that what about the most confusion. De-interlace method none I'm assuming but other options are blend fields or interpolate
In Moviestudio TFF is upper field first
What about the project properties in timeline (right click) that is set to progressive should I set that to upper field too? -
Blend fields blurs the two fields together. I don't know if your software is smart (only blending where there's obvious combing) about that or not but you generally want to avoid blending. But with all your horizontal time base jitter, noise, and uneven brightness between the two fields, it may improve the video.
True blend is not recommended I'm not sure if moviestudio is smart or not.
Reduce interlace flicker cleans up the issue that option also blends. the fields but I don't think its recommended.
Uneven brightness is because I was using the ES15 it is known for having brightness issues without using one some tapes flag.
Noise can be removed I'm sure I have a plugin in virtualdub that can remove noise it's called VHS I think? It has a chroma option a noise option.
What would be the bes de-interlace t option in virtuldub?
Virtuldub has interpolate with Yadif Bob, Blend, other options top field first, bottom field first
Remove top-bottom field. Topfield -Bottomfiled first double frame rate.
Would Yadif blend be better in Virtualdub than vegas? -
Of course blend deinterlace isn't generally recommended. With real interlaced video it makes every frame with motion look like a double exposure. But your video isn't interlaced. It has comb artifacts from the bad horizontal time base, uneven brightness of the two fields, and lots of noise. I was just suggesting a blend deinterlace might make it look better.
Yadif double rate is usually the best option in VirtualDub.
TFF vs. BFF depends on which your video is. -
Originally Posted by VHSvideocapture
OBS DeInterlacing Options-Which is best?
By Alwyn in forum RestorationReplies: 5Last Post: 28th Oct 2023, 22:44 -
VHS with Blackmagic Intensity PRO and OBS studio...
By Bartoloni in forum Newbie / General discussionsReplies: 26Last Post: 19th May 2023, 11:33 -
Problems capturing analogue video in Virtualdub and OBS Studio
By techmot in forum Capturing and VCRReplies: 85Last Post: 6th Jan 2022, 15:43 -
Obs studio produces screen capturing files with consequently delayed sound
By Glen in forum Newbie / General discussionsReplies: 4Last Post: 1st Sep 2021, 03:25 -
Deinterlacing with VirtualDub's Yadif filter?
By dellsam34 in forum Capturing and VCRReplies: 44Last Post: 29th Jul 2019, 14:27
