Hi there, I wish to capture VHS with my GV-USB2 cable via OBS Software, then use Hybrid to apply deinterlacing and other features to the captured video file.
Is there a way to disable deinterlacing through the GV-USB2 cable? I'm struggling with this. All I seem to be able to get is progressive video. Is it possible to to capture lossless video through the GV-USB2 without deinterlacing, denoising, resizing, etc?
Thank you for any advice!
Disable Deinterlacing? Right-click on the GV-USB2 in Sources and choose "Disable". I've never actually tried that.
[Attachment 79971 - Click to enlarge] -
Hi, thanks for the reply! Sorry, I should have been more clear.
I knew how to turn off deinterlacing in OBS - what I mean is that I need to disable it within the GV-USB2 itself:
In OBS, when I open "Properties" for the GV-USB2 cable, and click "Configure Video," it gives me options for deinterlacing within the GV-USB2. But it doesn't seem to give me the option to disable deinterlacing entirely and capture the untouched interlaced video. See attached image:
[Attachment 80029 - Click to enlarge]
The reason I want to capture it without deinterlacing applied is because deinterlacing and filtering in general normally should be done after capturing, since proper filtering usually can't be done in real time. So I'm hoping to capture the completely unfiltered/interlaced video via the GV-USB2 cable through OBS, and then process the captured video through Hybrid in order to apply deinterlacing and other necessary filters.Last edited by Casey Stelken; 19th Jun 2024 at 09:11.
Just switch to AmarecTV 310 and capture YUV 4:2:2 lossless interlaced, Y/C preferably.
GV-USB2 or GV-USB2/E ?
By Bwaak in forum Capturing and VCRReplies: 12Last Post: 7th Jun 2025, 01:16 -
Disable chroma or luma while deinterlacing a video file?
By rcoltrane in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2023, 12:06 -
GV USB2 Audio issue
By Kat_ in forum Capturing and VCRReplies: 15Last Post: 11th Dec 2023, 20:25 -
GV-USB2 crop issue?
By chconnor in forum Capturing and VCRReplies: 9Last Post: 25th Nov 2023, 18:26 -
GV-USB2 Capture Stick-What's In It?
By Alwyn in forum Capturing and VCRReplies: 39Last Post: 11th Apr 2021, 11:22
