  1. Good afternoon, my friends. I should ask for your kind help to solve the problem in downloading live streams from swiss television. To make an example, please consider the url https://www.rsi.ch/play/tv/live/la-2?tvLiveId=livestream_La2. I've been able to get the following file .mpd
    https://rsila2-lsvs.akamaized.net/out/v1/bb970ee9c86844a180a999312cc04f8a/index.mpd?dw=7200
    license server
    https://srg.live.ott.irdeto.com/licenseServer/widevine/v1/SRG/license?contentId=RSI2DRM
    and the PSSH
    AAAAOnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABoSEBBFqGcra0XeiO4TyN4/TYE4AEjj3JWbBg==
    anyway, inserting them into https://keysdb.net/ I cannot find the key. Should I use some headers? Thank you very, very much, in advance, for all help and advice. Stream is geo-restricted, so you may have to use a vpn. Have a great day
  2. Code:
    --key 1045a8672b6b45de88ee13c8de3f4d81:e0dca46691a5383ccf390bded2e00a9a
    License request must be sent from a Swiss IP as well, that's why keysdb fails.
  3. Originally Posted by white_snake View Post
    Thank you very, very much, for prompt answer and key. So, what may I do in such cases? Thanks, again, for help
  4. Originally Posted by misiek1963 View Post
    You should rather do the license request from your local machine (while you're connected to the Swiss IP) using a pywidevine script like this: https://github.com/devine-dl/pywidevine?tab=readme-ov-file#usage
    Of course, in order for this to work you need Python installed, the pywidevine module and a CDM in .wvd format.
  5. Originally Posted by white_snake View Post
    Thank you so much for help and advice, I was already thinking about this procedure, only was figuring out if it could be possible to avoid this
