Hi I have allready encoded a few movies. I tried to encode 2 different movies that I downloaded off winmx with both Tmpge and Nero. A window pops up that says "can't open file, or unsuported". I haven't had this problem before. I had no problem watching them on media player.
Hi
Try Virtualdub.
1) Open the avi, goto Audio, choose full processing mode.
2) Still in audio choose conversion and select 44100Hz (if it is anything else)
3) Still in audio choose compression and choose no compression (PCM).
4) Choose file, and save wav.
5) Give it any name.
6) Open Tmpgenc and do as usual, but choose the wav you just created for sound input.
Hope this works.Best regards
Jens Gervil -
Some avi files are DIVX or SMR and some of the older ones are INDEO. Usually if it wont load in TMPG you don't have the right codec installed.
In TMPGENC, under Environment Settings, go to VFAPI settings and make sure that your DirectShow filters have a much higher priority than zero (you do that by right-clicking on the filter and giving it a higher priority).
That should help.
You also may want to download and install the latest Nimo Codec
http://icingdeath.d2g.com/
what do you use to encode .avi?
By mrjust in forum Newbie / General discussionsReplies: 17Last Post: 17th Mar 2010, 13:50 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 20:51 -
all I want to do is encode an avi file
By moopsimoo in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2008, 15:56 -
SUPER cannot encode to AVI
By Grunberg in forum Video ConversionReplies: 14Last Post: 23rd Nov 2007, 22:26 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 14:01
