This is about MakeMKV. I have tried to use it over the years and found that as it runs at 100% of CPU I got more heat than I was comfortable and just shut it down. My question is, does anyone know of some sort of throttle where MakeMKV could be run in the background at a low CPU rate such as (I think) Handbrake has?
Also of possible interest in the subtitle section, a user found a portable version not previously on the videohelp software list.
Here that is:
https://rahim-soft.com/makemkv-1-10-portable/
Start the it up, then in the Windows Task Manager, Details tab, right click the task and select "set affinity".
Remove the check mark from some of the processors -
See if this can help?
How to cool down CPU while encoding with GPU
Yes not having played with any of this before I see that an adjustment can be made to the individual task.
So:
View running processes with Task Manager (the only way to find it in Win 7 search bar) > Processes > Rt click to find your program that is running > Select Properties > navigate to Low Priority
MakeMKV
By biferi in forum Video ConversionReplies: 64Last Post: 6th Jan 2025, 22:07 -
MakeMKV help
By biferi in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2023, 00:00 -
MakeMKV alternative?
By Instant Martian in forum DVD RippingReplies: 10Last Post: 26th Aug 2022, 11:05 -
MakeMKV
By jarod1005 in forum Newbie / General discussionsReplies: 25Last Post: 8th Feb 2022, 12:26 -
MakeMKV v1.16.4 - freezing ?
By Frasier in forum DVD RippingReplies: 2Last Post: 17th Jul 2021, 14:38
