I want to try my hand menu creation, but it seems I need stills and/or a moving sequence. Can anyone tell me how to go about capturing both of these? Thanks in advance.
surferr
If you have PowerDVD or something similar it's pretty easy - there's a capture button or key. Just make sure that harware acceleration is turned off or you'll get blank screenshots.
As for a moving sequences you could always cut one out from the rip you do with TMPGenc "Merge & Cut" feature or set a range to encode.
image capture from DVD
By deanst2 in forum Newbie / General discussionsReplies: 17Last Post: 7th Oct 2009, 22:55 -
Capture image from DV
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 11th Sep 2008, 14:00 -
image shift in frame with Virtualdub capture
By Knightmessenger in forum Capturing and VCRReplies: 0Last Post: 27th Aug 2007, 00:16 -
Is it possible to capture the image from plasma and copy directly to HDD?
By Steve237 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2007, 13:35 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
