1. When I close the application down after processing a few files I get the message:
The multiplex settings creating "<No destination file>" have been modified. Do you really want to close? All changes will be lost.
I have no idea what this message refers to. I simply click “Close Settings” and when I come back everything works fine. I cannot find any "<No destination file>" description anywhere under preferences. I see the Destination file box at the bottom of the application and it goes blank when the multiplexing process is finished. I need some insight on this.
2. When I load an MKV file into the Source file input box the tracks show in the bottom box. The old MKVTooNix I was using (v7.7.0) had a button to toggle all the tracks on or off. Under v85.0 I have to select a track then (ctl + A) to select all the tracks then right mouse click and select Disable all items. Is that the only way to toggle these tracks on or off?
1. It simply says this because you haven't specified an output file for the current multiplex settings. To avoide this simply go to Preferences -> Gui -> Warnings ; and disable "Warn before closing modified tabs"
2. Right-click anywhere in your "Track chapters and tags" box, and select "Disable all items" You don't have to mark them all first.
MKVToonix status for Win7 or Win10
By loninappleton in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2023, 17:09 -
A couple questions about overscan in analog SDTV?
By Videogamer555 in forum CapturingReplies: 2Last Post: 21st Jul 2023, 14:26 -
A couple of x265 related questions
By asw3 in forum Video ConversionReplies: 7Last Post: 8th Dec 2022, 21:30 -
A couple of questions about VHS tape storage & a VCR I got
By Kzzrn in forum MediaReplies: 2Last Post: 15th Dec 2019, 14:12 -
I have a couple corrupt mp4's and I need help
By Z.hb71 in forum Newbie / General discussionsReplies: 38Last Post: 15th Jun 2019, 01:59
