Hello
does anyone know how to download the subtitles from MyCanal website?
For example: https://www.canalplus.com/divertissement/hot-ones/h/18582832_50001
Thanks!
				Results 1 to 11 of 11
	I think I need a subscription and to be located in France or countries where it is possible to subscribe.
 If you have downloaded the videos and you can't get the subtitles easily, upload one episode and PM me the download link and I will create the subtitles for you.Last edited by Subtitles; 12th Jun 2024 at 11:10.
	Hi, thank you!
 But I only want to download the subtitles (because I have more that I want) without having to DL the video. Do you think that's possible? Maybe with the browser?
	I can't find any subtitles for this video by using their video player. Can you post a random free video URL from them that uses subtitles? Regardless you can try the stream detector addon, load your subtitle and see if it's detected as vtt or srt. Then you can get it without downloading the video/audio. --[----->+<]>.++++++++++++.---.--------.
	I think they have two versions of the video, one without subtitles and the other with embedded (hardcoded) subtitles.
 The video in the above link does have subtitles when you choose to show it in their player
	I sure am blind. They have subtitles if you press on the small square near the play button, called "Langues et sous titres". I hate non intuitive players. Subtitles should be near the wheel settings button, on one place with audio and video settings. Regardless, here's your subtitle:
 subtitle.srt
 Downloaded using:
 Yep you're right, I missed the button. They're not hardcoded however. You can find them on a separate track in their manifest.Code:N_m3u8DL-RE.exe "https://dashmkpc-od-aka-canalplus.akamaized.net/mkpc/canalplus/canalplus/ANT_1264939_8_CPSV/2714074/ANT_1264939_8_CPSV.mpd" -ss all --[----->+<]>.++++++++++++.---.--------.
	Thanks. You can get 1080p from them using the browser but it's useless if you download it and can't decrypt it. This is what N_m3u8DL-RE displays for video:
 The first 2 ones are 1080p and 720p. You can easily get 540p video if you decrypt it using public methods regarding L3 cdms. The higher tiers need L1 (which won't ever be public due to its nature since it's tied to hardware). I dunno about a cracked chrome cdm. Streamfab recently cracked it so it should be leaked to the public in the following months thanks to their API (it has happened before). But that's another story.[ ] Basic
 [X] Vid *CENC 4502 Kbps | Video8.1.1.1 | avc1.640029 | 1 Segment | ~35m21s
 [ ] Vid *CENC 3402 Kbps | Video7.1.1.1 | avc1.64001F | 1 Segment | ~35m21s
 [ ] Vid *CENC 960x540 | 2102 Kbps | Video6.1.1.1 | avc1.4D401F | 1 Segment | ~35m21s
 [ ] Vid *CENC 960x540 | 1502 Kbps | Video4.1.1.1 | avc1.4D401F | 1 Segment | ~35m21s
 [ ] Vid *CENC 960x540 | 1102 Kbps | Video5.1.1.1 | avc1.4D401F | 1 Segment | ~35m21s
 [ ] Vid *CENC 768x432 | 752 Kbps | Video3.1.1.1 | avc1.4D401E | 1 Segment | ~35m21s
 [ ] Vid *CENC 640x360 | 302 Kbps | Video2.1.1.1 | avc1.4D401E | 1 Segment | ~35m21s
 [ ] Vid *CENC 416x234 | 192 Kbps | Video1.1.1.1 | avc1.4D401E | 1 Segment | ~35m21s--[----->+<]>.++++++++++++.---.--------.
  Problem for get keys for mycanalBy root747 in forum Video Streaming DownloadingReplies: 2Last Post: 20th Jun 2023, 16:38
  MX Player Subtitles Settings not working on videos with SSA subtitlesBy anubhav007 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2023, 06:07
  Trying to get some replays out of MyCanalBy GOffrier in forum Video Streaming DownloadingReplies: 0Last Post: 12th Nov 2022, 07:49
  How to convert mkv (with subtitles) -> mp4 (with subtitles)By covo in forum Video ConversionReplies: 4Last Post: 18th Oct 2021, 12:42
  Insert Forced subtitles in Original subtitles (.srt)By VideoOn in forum EditingReplies: 1Last Post: 12th Feb 2020, 02:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
