Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 74
  1. This is the first time I have download with "N_m3u8DL-RE"
    First step I wrote (cmd) in the adress bar in the folder "N_m3u8DL-RE" location and got the (mpd link), Now I don't know how to get the key of video.
    [Attachment 79805 - Click to enlarge]
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Video url?
  3. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Video url?
    https://www.plus.fifa.com/en/player/49bd3d63-7429-499b-8c9b-4521541aea6f?catalogId=0be...a-764720c447a4
    this URL of Video, but i want to know how to get the key
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    a8dd9d0fcfd402e5a83aea49b75bf050:04c11e2f589acddbcefbbf25914f42ab
    If you're just interested in getting the keys you can try @foxrefire's addon. It's a pretty neat tool. If you want to do it manually, you can start by reading the sticky threads.
  5. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    can you get key for this URL
    https://www.plus.fifa.com/en/player/0970b531-3224-4f48-a8e1-6456fd5277f9?catalogId=866...f-d741c97792d3
  6. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    If you have like 100 URLs you want, you could just create a txt file and put in it all the urls on separate lines, they need to be in format /en/player/ etc. There's no point in doing one by one.
  7. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    ok.
  8. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    If this is possible I want the complete codes for these videos to download from N_m3u8DL-RE.
    If that is not possible, can you only put the keys.
  9. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Sure. Here are the commands for your 116 videos.
    cmds.txt
    Generated using:
    python widefrog.py Text.txt --basic
  10. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    [Attachment 79823 - Click to enlarge]
    Generated using:
    Great job, thank you
  11. If the link is like this, can I download it with N_m3u8DL-RE?
    https://www.fifa.com/en/watch/7wST4MTAbpXRAAmufEpCbx
    And, can I provide many links like that in TXT file? may be up to 800 files?
    I want the complete codes only.
  12. Member aqzs's Avatar
    Mar 2024
    Paris
    Here is your download command :
    N_m3u8DL-RE 'https://d33tkx2907c8gi.cloudfront.net/s/vod/main_106/FIM106849-M00_v05.76e0dc92_SDR_20240308-1710/FIM106849-M00_v05.76e0dc92_SDR.eng_mul.h264_SDHDP.cenc_subs.mpd' --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --save-name 'Jürgen Klinsmann Goal 61' | Germany vs Bolivia | 1994 FIFA World Cup USA™' --log-level OFF --key 46a995a9e47cb526ce0f4541d6754195:91de8534113cfd09491f9d5548811f19
    You can use widefrog to get 800 commands.
  13. Originally Posted by aqzs View Post
    Thank you for your reply, but if I cannot deal with Widefrog, can I put all of these links in a txt file and have someone provide them to me in a txt file also as well in the form of codes that I download through (N_m3u8DL-RE)
  14. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Doesn't matter how many URLs you have. You can even have 1k URLs. Just upload the txt file.
  15. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Ok, thx for your reply.
  16. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    I have attached the URLs including (en/watch) or should they include (en/player) for it to work?
  17. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Here are your 362 download commands.
    cmds.txt
    Your input file had 364 URLs but 2 were duplicates:
    https://www.fifa.com/en/watch/1Q7tkiOkd9fu4d61pJvLTI
    https://www.fifa.com/en/watch/dM6C3d5oNWofPVa95jAmH
    Widefrog currently doesn't support fifa.com (only plus.fifa.com) but I'll add it as a separate service in the next version. If you have a lot of URLs just give one single file with all of them. I'd like to stress test the downloader with 1k to even 10k links.
  18. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    [Attachment 80238 - Click to enlarge]
    Thank you for Your support.
    All the URLs I attached IN TXT file are from plus.fifa.com website, But the short link I attached contains fifa.com and when you play it, it turns into plus.fifa.com
    This file contains more than 1000 URLs, If you want to turns them to plus.fifa.com just tell me.
  19. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    No problem. I like doing this to test my tool and fix any unexpected errors. What better way to do this than with input received publicly.
    I know all of the fifa.com/.../watch/... redirect to plus.fifa.com. However the way widefrog is designed is by assigning a specific service to each unique base url. The advantage to that is I can just feed the URL to the downloader and it can handle it without needing any additional parameters to specify what service to use. As a bonus, I can just feed a file with 1000 URLs each pointing to a separate site and the downloader can still handle it as long as each of the 1000 services is properly defined. That's why I mentioned the fifa.com/plus.fifa.com problem. No need to turn them into plus since I already added fifa.com
    Here are your 1047 (out of 1048) download commands.
    cmds.txt
    One of them wasn't even a video. https://www.fifa.com/en/watch/1lCxgqjZaH0CNHkVzpl0za
    It did pretty good with 25 threads at once. Give me a 10k file next time.
  20. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    I know all of the fifa.com/.../watch/... redirect to plus.fifa.com. However they way widefrog is designed is by assigning a specific service to each unique base url. The advantage to that is I can just feed the URL to the downloader and it can handle it without needing any additional parameters to specify what service to use. As a bonus, I can just feed a file with 1000 URLs each pointing to a separate site and the downloader can still handle it as long as each of the 1000 services is properly defined. That's why I mentioned the fifa.com/plus.fifa.com problem. No need to turn them into plus since I already added fifa.com
    [Attachment 80242 - Click to enlarge]
    You are doing a great job with this tool, I wish you all the best, Thank you for Your support.
  21. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Bro, I forgot some files. I hope you can provide them for me like the previous ones.
  22. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    forgot some files
    126 / 128
    urls.txt
    https://www.fifa.com/en/watch/2PPgztGTe9gXubqGkHaDoT - is not redirecting at all to plus.fifa.com and doesn't have DRM. A simple m3u8 network request filter + N_m3u8DL-RE / yt-dlp used with it gets that video
    https://www.fifa.com/en/watch/1lCxgqjZaH0CNHkVzpl0za - is not a video
  23. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    forgot some files
    126 / 128
    [Attachment 80438 - Click to enlarge]
    Ok, Thank you.
  24. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I know I said that https://www.fifa.com/en/watch/1lCxgqjZaH0CNHkVzpl0za wasn't a video, but I found a way to download a hidden video version of that link using the command:
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,b3f4945a2eb447eaa886a5a1de373241,8cf14e3d244245f4addd5bbed48a343d/1076f07d88183cecd2066be7e4df0a23/2smPoejwRMWBXWTMq2SxM4WzThe1nWRVTPmQ8EgmHKX.m3u8?pbs=6892cbaf0c5846fcbdafa8e9cfffbe4d&mbtracks=1" --save-dir "media\fifa_com" --save-name "Julius_Aghahowa_Goal_27_Sweden_vs_Nigeria_2002_FIFA_World_Cup_KoreaJapantm"
    I don't know if the query parameters expire so I'll post a download link as well.
    https://www.transfernow.net/dl/20240707c8haECQq
    For anyone else curious about why is it hidden, that video is a DRM-free version of the original one. Most fifa.com/watch links redirect to DRM plus.fifa.com. So all of them have 2 video versions, with and without DRM. Honestly, when I compare them visually the DRM one looks nicer. So in short, for any plus.fifa.com link you might have, if you find a fifa.com/watch link that redirects to it, you can skip the DRM and download it without even needing a CDM.
    The downside is that the quality might look worse (but it's better when you have no other alternative).
  25. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    From my personal experience, I was compared the videos when I was downloading them from yt-dlp via a direct link from fifa.com, and when I downloaded them with a player link via N_m3u8DL-RE I found them to be the same.
    Also there are some videos that have the FIFA logo on them, and others that don't have them when downloaded.
    I think all the videos from the World Cup 2002 on FIFA website is poor quality, reverse 98 and 94 World Cup and the older tournaments.
  26. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    There is a clear visual difference. For example take this link: https://www.fifa.com/en/watch/7wST4MTAbpXRAAmufEpCbx
    You can download 2 versions from that. The first version is the DRM one which everyone can get easily since the page redirects to plus.fifa.com
    The second version is the hidden one accessible from fifa.com (directly from their API) which is DRM-free (has to be muxed manually since N_m3u8DL-RE breaks for that m3u8).
    N_m3u8DL-RE "http://d33tkx2907c8gi.cloudfront.net/s/vod/main_106/FIM106849-M00_v05.76e0dc92_SDR_20240308-1710/FIM106849-M00_v05.76e0dc92_SDR.eng_mul.h264_SDHDP.cenc_subs.mpd" --key 46a995a9e47cb526ce0f4541d6754195:91de8534113cfd09491f9d5548811f19 --save-name "drm_version" -M format=mkv:muxer=mkvmerge
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,5c528f4da80d4f24826f30128d429aa1,8cf14e3d244245f4addd5bbed48a343d/d8f8c9af0637104a84135ba8d3bf7852/5qpK4fyFw8WPl6NW2Qdy225ruDw2VEzvtIpF8SLPwqWc.m3u8?pbs=5217c4edced140de8963b724d4a7d601&mbtracks=1" --save-name "drm_free_version"
    Comparison
    [Attachment 80515 - Click to enlarge]
    I know it's not exactly at the same second and also the logo on the right, but to me, the right DRM one looks "better". You can compare the grass.
    You can take a look yourself if you're curious. https://www.transfernow.net/dl/20240708sXcuWEf5
  27. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    [Attachment 80516 - Click to enlarge]
    Firstly, I don't know how is this happened, but when I downloaded the two videos, it appeared to me that the one without logo is better, unlike what happened with you.
    I think the contrast is a little higher in the second video.
    Secondly, I am glad that you discovered this, because frankly, I prefer video without a logo, even if its quality is slightly lower.
    If I want all the Links without the logo, how do I get the hidden link?
  28. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I still think the DRM one looks better. If you want the other hidden version, you can use this script.
    import json
    import re
    from urllib.parse import quote
    import requests
    from unidecode import unidecode
    INPUT_FILE = "input.txt"
    def get_valid_filename(name):
        if name is None or len(name) == 0:
            return None
        try:
            temp_name = unidecode(name)
            if temp_name is not None and len(temp_name) > 0:
                name = temp_name
        except:
            pass
        s = str(name).strip()
        s = re.sub(r'\s+', ' ', s)
        s = s.replace(" ", "_")
        s = re.sub(r"(?u)[^-\w.]", "", s)
        s = re.sub(r'_+', '_', s)
        s = re.sub(r'\.+', '', s)
        if s in {"", ".", ".."}:
            return None
        return s
    def get_command(url):
        video_id = re.search(r"/watch/([^/?]*)", url).group(1)
        response = requests.get(
            'https://cxm-api.fifa.com/fifaplusweb/api/videoPlayerData/{video_id}'.format(
                video_id=video_id
            params={'locale': 'en'}
        status_code = response.status_code
        if status_code == 404:
            raise Exception("Content not available")
        response = json.loads(response.content.decode())
        video_title = get_valid_filename(response.get('title', video_id))
        response = response["preplayParameters"]
        preplay_url = 'https://content.uplynk.com/preplay/{content_id}/multiple.json'.format(
            content_id=response["contentId"]
        if response.get("queryStr", None) is not None:
            preplay_url += "?" + response["queryStr"]
        if response.get("signature", None) is not None:
            if "?" not in preplay_url:
                preplay_url += "?"
            else:
                preplay_url += "&"
            preplay_url += "sig=" + quote(response["signature"])
        response = json.loads(requests.get(preplay_url).content.decode())["playURL"]
        return f'N_m3u8DL-RE "{response}" --save-dir "fifa_com" --save-name "{video_title}"'
    with open(INPUT_FILE, 'r') as file:
        urls = file.readlines()
    urls = [u.strip() for u in urls]
    urls = list(dict.fromkeys([u for u in urls if len(u) > 0 and "plus.fifa.com" not in u]))
    index = 0
    nr = len(urls)
    for u in urls:
        index += 1
        print(f'[{index}/{nr}]')
        try:
            print(get_command(u))
        except Exception as e:
            print(f"Failed to get: {u}. Reason: {str(e)}. Try again later...")
    Keep in mind, this is most likely an exploit. You aren't even supposed to see this version from their site. So consistency is something I wouldn't expect. You should check whatever you download to see if the logo is missing or not. If you do too many requests, the script may fail for specific URLs, but it's ok since you can attempt after a few seconds only for those URLs that failed.
    Put everything you have in a local file input.txt and run it. Only fifa.com links are allowed since I have no idea how to get the watch ID just from a plus.fifa.com link.
    python script.py
  29. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    These attached files I have already downloaded before, but they contain digital rights (FIFA+ Logo) in screen.
    I need to download it again but without the digital rights, can you give me commands for those files, thank you.
    You may notice that videos with digital rights have the scoreboard outside the screen frame.
  30. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You can just run the script from post #28. It still works. You don't need a cdm for that script since it ignores the DRM version and goes for the hidden one. I'll give you the commands but I don't know how fast they expire. So you'll most likely have to run the script yourself later.
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,d21f2b1bbb2e4850a2f5acb4fbb2b7e4,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/qIgOVD3PF1RSSNQJpdIBK5NDJpyGEklN8epN3jONU5n.m3u8?pbs=7b2ea804f5c943b6abfe6fc5de90dff5&mbtracks=1" --save-dir "fifa_com" --save-name "Spain_v_Korea_Republic_Group_Matches_1994_FIFA_World_Cup_USAtm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,b040ce4b236a473b95d16949426928e0,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/5Vqz5K8KqufmB12v5VT1Bl2fcWQtjOaLRDSmFE34Qtbx.m3u8?pbs=d7b1eec0666a4023b4812f97a59f7224&mbtracks=1" --save-dir "fifa_com" --save-name "Usa_v_Colombia_Group_Matches_1994_FIFA_World_Cup_USAtm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,a9c19eb09ce841f4995bca9c0991f7c3,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/1fgg23Ygo4wSJLqFEng3H458VM96yJ97HpRbQI1pNuXO.m3u8?pbs=97fab655d3934b4cb101f021d40f52d6&mbtracks=1" --save-dir "fifa_com" --save-name "Italy_v_Spain_Quarter-finals_1994_FIFA_World_Cup_USAtm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,8aa2ba6479fc4c958a3e6b5cf8a52247,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/4YiTdYhksuBxr9j2bMTxuk45a2nAW414D1kUyR2G8sLn.m3u8?pbs=32f8b05b97724790ae020978109b63ac&mbtracks=1" --save-dir "fifa_com" --save-name "Netherlands_v_Brazil_Quarter-finals_1994_FIFA_World_Cup_USAtm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,1f65f2cdae8f472e853a78a98028f60e,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/5HdF810hNhmdu6ZlVZqFqr14fI1rXfpJ0iHSJCI1dc45.m3u8?pbs=012bf5788dfd4ab2b9695dff8f1eec5c&mbtracks=1" --save-dir "fifa_com" --save-name "Spain_v_Nigeria_Group_D_1998_FIFA_World_Cup_Francetm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,59261f2528f14e999479198506351eb6,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/55ibe8gYlcgNtJja8uJVBZ6vEqFCTq1hLfQE84UeftUV.m3u8?pbs=18cd9797add846f8826da8099d40de1b&mbtracks=1" --save-dir "fifa_com" --save-name "Netherlands_v_Argentina_Quarter-finals_1998_FIFA_World_Cup_Francetm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,d6b8df56da284875ad25a88322fc3ef2,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/7XjscL0dDojRvo3WMn5EwK1KMIluw50xObf5M9KFjZfK.m3u8?pbs=6ed12232105c4ad59f7a952e42dbbbe4&mbtracks=1" --save-dir "fifa_com" --save-name "Argentina_v_Brazil_Second_Round_1982_FIFA_World_Cup_Spaintm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,7733a841e5ba45ffb48b225aad4975e9,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/3Rd9yP5DDtI9Sl6AwkAXyi49U8OQnW0P3IIBOvIpPN1B.m3u8?pbs=a7b773403a37486e9276f09a4f4f9b86&mbtracks=1" --save-dir "fifa_com" --save-name "Italy_v_Brazil_Second_Round_1982_FIFA_World_Cup_Spaintm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,10647f06be664cc28627474b32613760,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/7MpWgyck4BCUc626arKaKU71aWsUo1Ky3aPGw7ccfW7j.m3u8?pbs=5a454c36f5f24d079328fe0610b6f388&mbtracks=1" --save-dir "fifa_com" --save-name "Germany_FR_v_France_Semi-finals_1982_FIFA_World_Cup_Spaintm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,924b8a0551b843ce8dd9413be34dcd98,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/cTFrHOvNUKNaNulGhOb3Q2O1FDyeP4NyESmIuGvDc76.m3u8?pbs=727fbeaacf074784b52e6a5a3e18c661&mbtracks=1" --save-dir "fifa_com" --save-name "Portugal_v_Morocco_Group_Matches_1986_FIFA_World_Cup_Mexicotm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,c49bb50bcd0a4685829c174aa9b3abb2,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/5wfsGsRk2nDTgLMLlcLbky6tmaffANc0cg1hwsIiVw7v.m3u8?pbs=9071a06a51d847af830edd4a1ae9e1a8&mbtracks=1" --save-dir "fifa_com" --save-name "England_v_Cameroon_Quarter-finals_1990_FIFA_World_Cup_Italytm_Full_Match_Replay"
    N_m3u8DL-RE "https://content-aeui1.uplynk.com/preplay2/9a497a6ee69441c69371499105effbcc,2bda2cd114da4ec6936cfd3beff1fdaa,8cf14e3d244245f4addd5bbed48a343d/3b94fe78464f5c023c2346e78f983769/6plFbAeTmJNW85xzXfO8aW6bkMORu1b3CMI1xrFrsiPr.m3u8?pbs=e707c5c3fa3044099eb0ef8ea4362de7&mbtracks=1" --save-dir "fifa_com" --save-name "England_v_Egypt_Group_Matches_1990_FIFA_World_Cup_Italytm_Full_Match_Replay"
