Is that question even answerable ?
What really is best s-vhs VCR In terms of picture quality, durability and reliability in your opinion for let's say video capturing and in general.
You can name one for each brand like JVC model... and Panasonic model...
The answer is simple, there is no best video recorder.
Which VCR is best depends primarily on your tapes (condition, video content, ...generation copy, copy protection,brand.....) and the workflow used for capture the tapes.
Depending on the workflow, the recommendation may be different:
-VCR with Line-TBC & external FrameTBC-Capture Card
-VCR & DVD-Recorder Passthrough-Capture Card
-VCR-Capture Card with Line-TBC
-VHS Decode Project
or any other workflow.
You have probably already read the overview of all PAL Panasonic & JVC recorders?
https://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide-16.html#post77079
https://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide-17.html#post84039
Or here is a more up-to-date version in German language (that shouldn't be a problem to read).
https://gleitz.info/forum/index.php?thread/48526-%C3%BCbersicht-%C3%BCber-alle-jvc-pan...r-deutschland/
The most recommended PAL devices over the years on various video platforms have been the JVC HR-S9600 & the Panasonic FS200. This is reflected in the used market prices and finding any in good condition will be difficult.
You should also take a look at the Philips VR-1100, VR1500, VR1600 & Sharp VC-S2000 series which are based on JVC devices.
With the JVC's (and also Philips devices) you should consider the dynamic drum, as this seems to fail more often and is not repairable, as there are no more spare parts available. (the only possibility would be to deactivate it - just search here in the forum for more information)
Here is a comparison of various devices (Sharp VC-S2000, Telefunken A1200, Thomson VPH6990 (VHS), Panasonic HS860, Philips VR1500, Panasonic HD650 (VHS), Nordmende Spectra V6400S, JVC BR-S811E, JVC HR-S 8960, JVC HR-S 7600,JVC HR-S 5950, Hitachi S390E, Blaupunkt RTV966, Blaupunkt RTV950, Blaupunkt RTV925) why your tapes are one of the deciding factor are which is the best video recorder (for your tapes).
PAL-VCR comparision Luminance clipping.mpg -
a good quality vcr , its better than the original vcr where vhs were recorded?
i just found same model of my dead vcr on thift shop but i skip it. -
Hi,
thanks for all the info. and time
I have two workflows
1. JVC S9760E - Elgato
2. HS-1000 - ES-10 (for filtering) - Pinnacle 710 (won't work with VD only in pinnacle studio for some reason it's rev 1.0)
And picture on HS-1000 is a bit warmer but overall picture quality is kind of better sharper than on JVC, but on JVC is super quality also with ES-10 and without. -
Any machine you decide on is at least 30 years old.
Just saying.
S-VHS JVC VCR as comb filter passthrough for non S-VHS VCR?
By Krazern in forum Capturing and VCRReplies: 22Last Post: 6th May 2024, 06:18 -
The old "war of opinion" - Capture 8mm tapes in DV or lossless?
By Marvolo in forum RestorationReplies: 367Last Post: 31st Jan 2024, 11:55 -
Second opinion on digitising VHS home videos
By Kaos-Industries in forum Capturing and VCRReplies: 93Last Post: 9th Aug 2021, 17:00 -
Mono VCR + HiFi VCR As Passthrough = HiFi Audio Out?
By companda in forum RestorationReplies: 7Last Post: 16th Feb 2021, 11:18 -
A Blu-Ray player & VCR connected together, VCR input settings?
By Kzzrn in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2019, 10:15
