Hi i cant find the right how to guide for this.. what do i need to convert a SeCam tape to the computer and record it on a cd in vcd format, and how do i do this? whats a good capture card you would recomend for this? THANKS!
Kinda tricky, since most capture devices do Ntsc/Pal only and not Secam.
If you have a capture card that will only capture in Ntsc/Pal, you need a VCR that can play Secam and convert it to a Pal/Ntsc output. I believe the Samsung S5000 would be your best bet (can t be bot outside the States though).
Another option is to look for a cheaper VCR that plays Secam properly (input/output Secam) + a separate video converter to Pal/NTSC (the little boxes typically cost about 100 USD or thereabouts). I personally use a Sharp multisystem VCR with an external converter and the quality is ok.
As for capturing, there are many capture cards: you can look at the Pinnacle Video Studio Deluxe or the Dazzle DVC I, II or III, they can capture VCD-compliant footage that can then be burnt to VCD using software like Nero or EzCD Creator Deluxe.
Cheers
Arnaud
can a PAL disc work fine in a SECAM system ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 05:55 -
PAL DVD work on SECAM?
By BobAchgill in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2009, 07:20 -
VHS capture jumping between PAL and ME SECAM...help
By pijetro in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 19:55 -
Help! - ntsc and secam versions of chapter authored pal dvds
By devdev in forum Video ConversionReplies: 3Last Post: 25th Aug 2008, 22:05 -
h.264 digital format to PAL, SECAM, NTFC formats in DirectShow ?
By manzoor505 in forum ProgrammingReplies: 1Last Post: 8th Dec 2007, 09:28
