Hey i have a budget of around 300 bucks and i need a card that does very high quality analog capture. It doesnt have to have decent software ( since i already have a copy of premire) and it doesnt have to do video out.
I just bought the Pinnacle Studio Deluxe. Is has a breakout box that connects to firewire that captures at a fixed DV quality. There are RCA stereo/composite video/S Video Inputs AND Outputs. You can pick it up for about $260. Comes with Pinnacle Studio, which must be used for capturing. I give a review when i get it if you want.
-Chris -
i took a trip to compusa today and that thing caught my eye and i was just comming on hereto ask what people thought of it, since i cant seem to find ANY reviews of it online
PCMag has a short review of it, so does videoguys.com, but they are biased b/c they want you to buy it. xiaNaix has some old posts about it and he seemed to like it. If you can stand the fixed capture, I would say it is the way to go for high quality. Also try the Canapus ADVC-100 (spelling?), I heard it is great, but it needs a firewire connection. I didn't buy it b/c I don't have a firewire card and i wanted included software. Decide what format you want to capture in. DV is the highest, then MPG-2, then MPG-1. Be sure to factor in a new harddrive if you need it, because you'll need alot of space.
-Chris
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
