Results 1 to 16 of 16
  1. Hello,
    Seem recently AbemaTV use new DRM for protect their content. And I predict that it's not Widevine because it's not uuid I've seen.
    Now I can't use StreamFab to downloading.
    Can anyone help me this problem? This is video link: https://abema.tv/video/episode/19-189_s1_p1
    Thanks for your reading.
  2. yt-dlp don't work anymore ?
  3. It's using clearkey
    MPD
    https://ds-vod-abematv.akamaized.net/program/19-189_s1_p1/manifest.mpd
    Key
    8a20f5c1d8b34b2c99f5827aaf986570:e1b95906ae8144e08103a7b159d2134a
  4. Just needs a Japanese IP. If current yt-dlp doesn't work for you, update to the latest:
    pip install yt-dlp --upgrade --pre
    Edit: @Frieren: oh, does it? yt-dlp worked just fine for me though.
  5. Originally Posted by Frieren View Post
    It's using clearkey
    MPD
    Key
    [Attachment 79740 - Click to enlarge]
    Thanks for your help! Can you teach me howw to get key with clear key DRM? It can be use with some sites like cdrm-project.com?
  6. Banned
    Apr 2022
    Hong Kong
    I just used the so-called "traditional" way to download their video.
    Here's your key:
    e7bcbc32f3fc890fb2a8037bbac94ee0
    and here's the iv:
    11b76561d9861250a2199502224c3bdf
    and then use N_m3u8DL-RE to download it:
    N_m3u8DL-RE.exe "https://vod-abematv.akamaized.net/program/19-189_s1_p1/1080/playlist.m3u8" --custom-hls-key e7bcbc32f3fc890fb2a8037bbac94ee0 --custom-hls-iv 11b76561d9861250a2199502224c3bdf
  7. Originally Posted by Frieren View Post
    It's using clearkey
    MPD
    Key
    thanks, great job! it is the best way for people like me have no knowledge about custom aes-128 encrypt.
  8. Originally Posted by white_snake View Post
    yeah, I just test with yt-dlp and it worked. seem clearkey doesn't cause downloading error from abema.
  9. For downloading, yes, just use yt-dlp. If anyone's attempting to decrypt the clearkey license server response because you're writing an addon/plugin or something, there's a variety of ciphers/obfuscation used: AES-CBC, HMAC-SHA256, Blowfish-ECB, RC4, Base58 encoding (Bitcoin variant).
  10. I know I need to decode base64 to hex, but like this, how to do? It's 3 ".", and I don't know what thing I can take.
    Bjro6aoWsPeWvSdHZUTV5SV9CK31UPdzZE9a5NjLjCgq.LwwAT T6x1DK7rTvgbh8qve5.e5b13d650a0780dd19d30f00e29d010 f
  11. Originally Posted by kienkzz View Post
    yt-dlp not work?
  12. Originally Posted by shellcmd View Post
    yt-dlp not work?
    Before it didn't work, but in latest version it works normally. I'm just curious about this thing.
  13. okay, I'll use wvg-next (Widevine L3 Guesser 2024) extension for get clearkey. When I play content with clearkey, it can automatically detect it's clearkey protection and will give me key. So great if I can't download from abema with streamlink or yt-dlp.
  14. Originally Posted by kienkzz View Post
    That's encrypted using all five ciphers/obfuscation techniques I listed in my previous reply. You'll also need your Abema user ID and several keys you can extract from the .js files on the website. As you're only curious, I won't share the actual details.
  15. Member aqzs's Avatar
    Mar 2024
    Paris
    In fact, it would be better to grab keys from EME LOGGER at this point..
  16. Originally Posted by aqzs View Post
    That's why I said "because you're writing an addon/plugin or something", when you want to avoid manual intervention.
