I have this movie source that has this kind of ghosting effect every 4 and 5 frame, it says it's MBAFF encoded and interlaced but the output is progressive and doens't has any combing effect. To my knowledge, it looks as if they just deinterlaced this telecined movie which called really for a IVTC, and then got this way. Is there any way of minimizing this effect/then return to 23.976 fps? TDecimate() on this source, often leaves both of the ghosting frames in, i thought it could at least drop the fps and leave just 1 of these 2, but after examining in in avspmod it doens't really work out. Sample (cut losslessly using avidemux): https://mega.nz/file/5kJhmDKA#mfntaw-agHMkqc171SNME0f1_CXvF7jQIkOr2-idj28
Since this ins't really interlaced all the code i have so far isCode:LWLibavVideoSource("D:\movie.mkv").propSet("_FieldBased",0) Crop(240, 0, -232, -0)
It's not always perfect. Things like edits after being telecined, compression artifacts, etc. can cause it to screw up now and then. It worked pretty well with your source though.
Frame blending/ghosting - how do I remove it from a webrip video
By MTRX in forum RestorationReplies: 7Last Post: 25th Sep 2024, 15:36 -
Ghosting and Chroma Ghosting?
By JadHC in forum RestorationReplies: 5Last Post: 2nd Aug 2023, 22:44 -
Old silent movie with weird duplicate frame pattern.
By dopethrone in forum Newbie / General discussionsReplies: 19Last Post: 6th Apr 2023, 19:37 -
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27 -
Which SBS format is the same as a Frame Packed movie?
By ebruce in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2021, 08:23
