What for?! They discuss plugins for IPTV (Internet), and not satellite (DVB-S/S2) as fuge has issues.
Just to confirm: The USB hard disk must have a separate power supply, as the USB itself may not power it sufficiently, especially when recording channels with high bitrate, HD.
I never tried to record to a flash drive but I expect everything depends on the port and drive speed capability. So you need to check their tech spec.
Results 31 to 33 of 33
Unfortunately, there does not appear to be any option to install a plugin. However, the most recent recording with the external USB hard drive was ok so maybe the problem has gone away for some reason. The discussion at the link was quite interesting as there were a number of possible explanations mentioned for the lack of audio/video synch.
Thank you for your response and for your list of possible explanations.
We are now using an externally powered USB drive and do not notice any signal interruptions during playback. Insufficient write speed or a fragmented file system do not seem to be the source of the problem as the original flash drive was USB 3 and newly purchased. The set-top box not handling the recording process efficiently seems to me to be a possible explanation as there is quite often a remaining problem where the audio and video are obviously not synchronised.
Downloading videos using a 4K set-top box
By nadya86 in forum Video Streaming DownloadingReplies: 6Last Post: 20th Sep 2025, 17:36 -
Amino Amigo 7X Set Top Box ( Streaming TV)
By muusicman in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2023, 20:31 -
Capturing in 1080i from set top box
By pthebest19 in forum Capturing and VCRReplies: 8Last Post: 17th Nov 2022, 20:24 -
How to use MPEG 4 set top Box of only playing USB
By shrikant.tillu in forum Latest Video NewsReplies: 3Last Post: 31st May 2021, 00:53 -
VLC cannot read .TS files from set-top box
By pchan in forum DVB / IPTVReplies: 14Last Post: 15th Mar 2020, 09:30
