I use Selur Hybrid almost exclusively for interlaced SD videos. I use Filtering--Deinterlace and select QTGMC and select the Bob option. This gives me an SD video, progressive, at 59.97fps, which I understand is best as it preserves the odd and even frames from the original interlaced video (although I understand the issue of deinterlacing is hotly debated and may not be necessary in every case if for no other reason than QTGMC does more than just deinterlace and tweaks the image slightly).
Anyway, I recently noticed Selur's guide from 2018 on how to convert to 60fps. He doesn't mention QTGMC and Bob. I assume that is because if you are starting with a progressive video, you obviously can't deinterlace.
I just want to make sure that for interlaced SD video, the QTGMC/Bob is right way to go to get progressive video at 60fps. And that in my use case, I don't need to touch anything in the Filtering--Deinterlace tab.
Yes, unless there is a defect in your interlaced(!) content, using a bob deinterlacer is the way to go.
Yes, the linked thread aims at handling progressive content.
You can still add some frame interpolation to replace specific frames or aim for a higher frame rate after deinterlacing.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Converting 30fps (prev interlaced) into 60fps interlaced
By Saturn2888 in forum Video ConversionReplies: 4Last Post: 29th Sep 2023, 09:01 -
Strange issue DeInterlacing DV capture - QTGMC-Bob (Hybrid Vapoursynth)
By SupermanTV in forum Capturing and VCRReplies: 23Last Post: 17th Sep 2023, 18:00 -
QTGMC Choppy Frame Rate After Selecting Bob
By AdamJellicorse in forum RestorationReplies: 2Last Post: 19th Apr 2023, 22:18 -
Encoding 60fps with Interframe on staxkrip error
By airy in forum Newbie / General discussionsReplies: 9Last Post: 18th Apr 2023, 20:29 -
PotPlayer NS + Uplavnyalka (SVP port) 60fps + debanding noise levels pxshad
By DanilaZabiaka in forum Software PlayingReplies: 5Last Post: 17th Apr 2021, 11:05
