When preparing a DVD for edit and it has combing I first use Bob() and if there is motion with every field I know it's interlaced and if there's motion every two fields I know it's progressive. The DVD in this case has combing and after applying Bob() it gives me two identical frames then three identical frames (repeated). What do I have here and what's the way to handle it? Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
It is 2-3 telecined. You should IVTC (Inverse Telecine) rather than deinterlace the video to get the original progressive film frames back.
In Avisynth:
Code:TFM().TDecimate()
If it is soft telecined your player has just to ignore the pulldown flags.
https://en.wikipedia.org/wiki/TelecineLast edited by Sharc; 4th Jun 2024 at 05:49.
Great stuff, thanks, Sharc. Am I right in saying that if the DVD was PAL you'd omit TDecimate() from the code?
3 cases:
(a) Speed up (runs slightly faster, 25/24, 4.2%)
Films on PAL DVDs are often just speed up from 24fps to 25fps. Encoded and flagged as interlaced for PAL DVD spec compliance, but the video is actually progressive and can be processed as progressive because both fields are from the same film frame (same moment in time)
(b) Telecine (keeps original run time)
If telecine is used for the speed conversion 24fps -> 25fps it will be using 2:2:2:2:2:2:2:2:2:2:2:3 pulldown (aka "Euro pulldown"). It can be IVTCed by
Code:TFM().TDecimate(cycle=25)
(c) Phase shifted
25fps interlaced with the 2 fields taken from subsequent film frames.
For decoding just use
Code:TFM()
http://avisynth.nl/index.php/TIVTCLast edited by Sharc; 4th Jun 2024 at 11:32.
Just a small addition to the excellent Sharc's reply.
TFM sometimes fails for phase-shifted / not phase shifted material where there is a very very small amount of movement (for instance static end credits), choosing the wrong field. In this case is better to use:
Code:DoubleWeave().SelectOdd()
If the material has not constant / not always present phase shift, the reccomended TFM(order=1, PP=0) is more appropriate as Sharc suggested.
Image Sequence with Subtitles
By Mr. Fanservice in forum SubtitleReplies: 1Last Post: 9th Feb 2024, 13:30 -
By Mr. Fanservice in forum SubtitleReplies: 0Last Post: 9th Feb 2024, 12:02 -
JXL Image Sequence
By Jay123210599 in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2024, 18:35 -
Webp image sequence
By Jay123210599 in forum Newbie / General discussionsReplies: 19Last Post: 15th Jan 2024, 17:13 -
Image sequence back into a video?
By jedi55 in forum RestorationReplies: 5Last Post: 6th May 2021, 20:42
