  1. Hello, excuse me If my English is not so good I'm new to streaming and I'd like to know an effective tool to broadcast MPEGTS format with AAC audio codec. I successfully managed to make it using OBS. However it consumes a lot of CPU and I'd like to broadcast multiple streams at the same type.
    My set up goes as follow,
    I use an external URL to transcode it to MPEGTS, AAC using OBS and rebroadcast it to icecast server.
    I used ffmpeg (I'm not so good using it) and streamed MP3 file successfully ffmpeg -i outputURL -codec:a libmp3lame -ab 128k -ac 2 -content_type audio/mpeg -f mp3 icecast://sourceassword@localhostort/mountpoint
    the OBS profile goes as follow;
    [General]
    Name=Untitled
    [Video]
    BaseCX=1920
    BaseCY=1080
    OutputCX=1280
    OutputCY=720
    [Panels]
    CookieId=21A7A2D421F6C353
    [Output]
    Mode=Advanced
    [AdvOut]
    TrackIndex=1
    RecType=FFmpeg
    RecTracks=1
    FLVTrack=1
    FFOutputToFile=false
    FFURL=icecast://sourceassword@localhostort/mountpoint
    FFFormat=mpegts
    FFFormatMimeType=video/MP2T
    FFExtension=ts
    FFMCustom=content_type=audio/mpegts tls=0 ice_name=STREAM-NAME
    FFVEncoderId=0
    FFVEncoder=
    FFABitrate=128
    FFAEncoderId=86018
    FFAEncoder=aac
    FFAudioMixes=1
    VodTrackIndex=2
    FFVBitrate=0
    FFVGOPSize=0
    FFIgnoreCompat=true
    FFACustom=
    [Audio]
    SampleRate=44100
    I'd like to do the same thing with any other tool to broadcast MPEGTS/AAC audio. can anyone please help me with the ffmpeg code or even a software I can use?
    Thanks in advance
  2. Check Avalpa software - currently i can't find details but i recall they offered free software able to properly broadcast so perhaps it will work for you.
    I was able: https://github.com/aventuri/opencaster so perhaps this will suit you.
  3. thank you pandy for your reply. I'm using Windows I'm not very familiar with linux
    Jul 2009
  5. VLC may work for you then... ffmpeg has ffserver but it is not officially available for Windows - however you may try to search for Windows ffserver - if i recall there are some unofficial builds in Internet.
    https://stackoverflow.com/questions/2679569/how-to-do-simple-video-streaming-with-ffse...ver-on-windows
    https://trac.ffmpeg.org/wiki/ffserver
  6. thanks dears it finally worked i used this line and this was exactly what I needed , I'm grateful for you both
    ffmpeg -i streamURL -c:a aac -ab 256k -ac 2 -filter:a "volume=2.5" -content_type audio/adts -f mpegts icecast://sourceassword@hostname: port/mountpoint
    <3
