Hello,
I have been experiencing conversion troubles with multiple mp4 -> [vob, bup and ifo] conversions with dvd flick.
I noticed similar kind of posts before and this post can and should be put to the right location as well.
So the problem is that at certain but not all conversions the resulting files (ImgBurn to dvd-r) will have two specific problems and I have got over a dozen of such failed dvds by now so I decided to find out what the f is going on by coming here and asking someone who actually knows their way around the details etc.
I read from some post that the stuff I am experiencing: Every second or so the picture pulsates / stops for a tenth of a second and then continues like that. Also I believe that it happens more clearly during scenes where there is a lot of movement involved. Besides that I know that the audio is screwed if this stuttering is on the dvd: The audio comes too soon so the mouth movements while speaking look horrid. I found a way to go around that by changing a setting from my tv. Makes the audio come out when it should but preferably I would like all the dvds to work like the original mp4 files: Flawlessly...
Mediainfo:
General
Complete name : E:\PSYCHO_G4 Title 2.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 974 MiB
Duration : 1 h 48 min
Overall bit rate : 1 256 kb/s
Frame rate : 25.000 FPS
Writing application : Lavf58.44.100
Video
Format : AVC
Format profile : Main@L3.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Codec ID : avc1
Bit rate : 965 kb/s
Width : 768 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.087
Stream size : 748 MiB (77%)
Writing library : x264 core 158 r2984 3759fcb
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=1 / keyint=25 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=22 / qpmax=22 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 288 kb/s
Maximum bit rate : 320 kb/s
Channel(s) : 1 channel
Channel layout : M
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 223 MiB (23%)
Language : English
Default : Yes
Alternate group : 1
General
Complete name : C:\Users\nuusk\Documents\dvd\Kirjastoleffa\dvd\VID EO_TS\VTS_01_1.VOB
CompleteName_Last : C:\Users\nuusk\Documents\dvd\Kirjastoleffa\dvd\VID EO_TS\VTS_01_5.VOB
Format : MPEG-PS
File size : 4.21 GiB
Overall bit rate mode : Constant
Overall bit rate : 5 559 kb/s
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : Variable
Bit rate mode : Constant
Bit rate : 5 348 kb/s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.516
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 4.05 GiB (96%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Muxing mode : DVD-Video
Bit rate : 96.0 kb/s
Channel layout : M
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 74.4 MiB (2%)
Service kind : Complete Main
Dialog Normalization : -31 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Menu
Format : DVD-Video
Original pal mp4 file that of course goes down in quality when it is forced into a smaller dvd-r disc. The second one is the first of five pal vob files and I believe that someone who understands what is going on can find the problem from here. I thought the problem had something to do with 24fps turning into 25fps but that doesn´t seem to be the case after all. So, please help me, pretty please?
To ensure the symptoms are not due to poor burn/media, use the utility mentioned here to test it in the PC,
ie., the "Disk Quality" and "Scan disc" tabs
https://forum.videohelp.com/threads/414624-DL-dvds-freezing-on-playback#post2736465 -
I used DVDFlick years ago. I stopped using it for a reason although I can't recall what that reason was now.
Have you tried other conversion software? I recommend trying AVDtoDVD, a newer simple DVD converter. It has a PAL speed-up option for converting from 24 fps to 25 fps. (Options > Preferences > AviSynth > Use PAL SpeedUp)Ignore list: hello_hello, tried, TechLord, Snoopy329
DVD conversion problems
By Rixter in forum Video ConversionReplies: 3Last Post: 8th May 2023, 16:32 -
DVD flick says no usable video track
By yeoldmetalhead228 in forum Authoring (DVD)Replies: 10Last Post: 21st Nov 2022, 08:49 -
Using DVD Flick to Make Multiple Copies
By Gary123 in forum DVD RippingReplies: 1Last Post: 18th Jan 2021, 23:40 -
DVD Flick Encoding Audio Error
By sniperfx20 in forum Authoring (DVD)Replies: 2Last Post: 26th Nov 2020, 11:29 -
DVD Flick Error
By SheenSizzle in forum Authoring (DVD)Replies: 11Last Post: 24th Sep 2019, 07:26
