Page 6 of 6
FirstFirst ... 4 5 6
Results 151 to 167 of 167
  1. Originally Posted by autodidact View Post
    I haven't changed ffmpeg defaults but if that is a desired change and simple to implement I would consider it.
    @autodidact Thanks for the consideration, it would be greatly appreciated if you could implement this easily in the Windows 7 builds, the original eac3to developer madshi had disabled DRC in his custom FFmpeg build, the concern is about preserving the original dynamic range there is some old discussion about it here https://ffmpeg.org/pipermail/ffmpeg-devel/2015-March/170771.html
    Mar 2024
    germany
    Does someone know how to use the apple aac_at in high efficiency 2 (aac_he_v2)
    here it sais https://trac.ffmpeg.org/wiki/Encode/AAC#aac_at
    Note: -profile option only accepts numeric values for aac_at encoder, e.g. 4 works as aac_he and 28 as aac_he_v2. (​https://trac.ffmpeg.org/ticket/9574).
    so "-profile:a 4" (aac_he) is working but "-profile:a 28" (aac_he_v2) just crashes
  3. I just tested with the version of ffmpeg I have
    The -profile:a 28 fails with a bunch of errors.
    I'm using the last 32-bit versions autodidact posted.
    It is possible that a later version of audiotoolbox Encoder might be able to do this.
    It probably would tale a later version of Windows than my Windows 7 32-bit.
    Probably a 64-bit version of ffmpeg,audiotoolbox Encoder,& Windows could .
    Mar 2024
    germany
    This is crashing on latest ffmpeg 8.1.1 from this post https://forum.videohelp.com/threads/414767-ffmpeg-7-0-1-and-Windows-7/page3#post2781425
    Im on Win 10 64bit, and also the latest audiotoolbox files from https://github.com/AnimMouse/QTFiles
    Feb 2004
    I think with aac_at the aac_he_v2 profile may only work directly on MacOS. On Windows we use the
    audiotoolboxwrapper which is based on qaac and that only supports aac_he.
    QAAC only does LC and HEv1. It can use some of the audiotoolkit filters while it works.
    Source:https://wiki.hydrogenaudio.org/index.php?title=Apple_AAC
    PB
    Mar 2024
    germany
    Oh okay, thats a bit weird but thanks for the information
  7. Member manolito's Avatar
    Jun 2009
    Germany
    Originally Posted by manolito View Post
    I have no idea if this ETA information is directly taken from the console or if it is recalculated by the GUI. Whatever, it works fine under FFmpeg 7.x, and it fails under FFmpeg 8.x.
    Hi autodidact,
    after some research I do know that the ETA calculation in the dmMediaConverter output screen does not get its ETA information directly from the FFmpeg console output. Instead it calculates the ETA data itself from the console output. And since the console output is different between FFmpeg 7 and 8, the ETA display will also be different.
    Which means that I need to approach Marius Dalacu and ask him if and how dmMediaEncoder could be updated to spit out correct ETA values both for FFmpeg 7.x and FFmpeg 8.x ...
    Cheers
    manolito
    Mar 2024
    germany
    is it possible to use FhG AAC (Winamp) "enc_fhgaac.dll" with ffmpeg?
  9. Originally Posted by geextah_2 View Post
    I did find that this can be done.
    From Pandy's link below:
    http://tmkk.undo.jp/tools/fhgaacenc-20120624.zip
    Extract to there own folder:
    fhgaacenc.exe
    libsndfile-1.dll
    In order to use it you need to download the latest WinAmp installer (version 5.666, it seems) and extract the following files with a program such as 7zip. No need to install WinAmp, just extract the three files and put them in the same folder as fhgaacenc.exe.
    enc_fhgaac.dll, libmp4v2.dll, nsutil.dll
    This will complete the folder.It worked for the code I will post below.
    There is one more file I found recommended: libsndfile-1.dll I found it is my AVIsynth plugins folder.
    ffmpeg -i input.wav -f wav - | fhgaacenc --vbr 6 --ignorelength - output.m4a
    Use a full path to the folder with fhgaacenc.exe as well as the location of your input file.
  10. Check this https://github.com/tmkk/fhgaacenc , perhaps piping from ffmpeg is supported.
  11. @ autodidact,
    First I want to thank you for all the work you have & are doing to keep a ffmpeg version for Windows 7.
    Especially the 32-bit like I need to use.
    I decided to try to convert to AV1.
    You have the --enable-libaom in the version I'm using.
    I was wondering if it would be possible to add: --enable-libsvtav1
    Feb 2004
    @cholla,
    If we are talking about 32-bit then the svtav1 library is not supported. And just recently I
    removed it from the 64-bit builds because a Windows 7 incompatible function was added to it.
    It is in 64-bit builds just prior to the latest.
    There is also librav1e for AV1 which is the library that first caused Windows 7 incompatibility.
    I compile a patched Rust so I can still include it. I may also pin svtav1 to the last working
    version and add it back to the 64-bit builds.
    PB
  13. The --enable-libaom seems to work fine for Windows 7 32-bit.
    It takes time but works fine.
    I have only converted a few videos with it anyway.
    Feb 2004
    Updated FFmpeg in post #33.
    FFmpeg release version updated to 8.1.2 in post #89.
    • Restored svtav1 version 4.1.0 to the 64-bit builds
    • Changed the default for (E-)AC3 decoder -drc_scale to 0 - suggested by oniiz86
    PB
  15. @autodidact Oh my, thanks so very much for implementing the disabling of DRC "-drc_scale to 0", it's oh so greatly appreciated, you're an absolute gem.
  16. In the latest version:
    This may have been happening in older version 8s but I don't know.
    If I try a conversion with: -c:v mpeg2video as the video codec.
    I get this message :
    [Attachment 92973 - Click to enlarge]
    ffmpeg-git-gb441d97486-full-static-WIN7_32 from post # 33 does this conversion with no problem.
    I don't need to use version 8 for this I'm just reporting it.
    Feb 2004
    Interesting. Thank you for reporting.
    It appears that the 32-bit 8.1.1 release has the same issue but the 64-bit build for both releases works fine.
    PB
