Results 1 to 19 of 19
  1. Hi there,
    In order to get one key, I go at this adress https://cdrm-project.com/, I just saw this :
    [Attachment 79517 - Click to enlarge]
    Does anyone understand how it works for a simple request please ? (PSSH + lic URL = token) ?
    like for this example please : (may need canadian IP)
    MPD :
    https://rcavtoutv.akamaized.net/64af8f3c-bf6b-4188-952a-983c9bb3b05a/2020-03-06_07_00_00_cestcommecaquejetaime_0002.ism/manifest(format=mpd-time-csf,filter=3000)
    PSSH :
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEI26pbdxuU7XvwV2i61Khyw=
    LIC URL :
    https://rcavtoutv-key.akamaized.net/Widevine/?KID=8dbaa5b7-71b9-4ed7-bf05-768bad4a872c
    HEADER with token :
    POST /Widevine/?KID=8dbaa5b7-71b9-4ed7-bf05-768bad4a872c HTTP/1.1
    Host: rcavtoutv-key.akamaized.net
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:126.0) Gecko/20100101 Firefox/126.0
    Accept: */*
    Accept-Language: fr,fr-FR;q=0.8,en-US;q=0.5,en;q=0.3
    Accept-Encoding: gzip, deflate, br, zstd
    Authorization: Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1cm46bWljcm9zb2Z0OmF6dXJlOm1lZGlhc2VydmljZXM6Y29udGVudGtleWlkZW50aWZpZXIiOiI4ZGJhYTViNy03MWI5LTRlZDctYmYwNS03NjhiYWQ0YTg3MmMiLCJuYmYiOjE3MTcxNjczMTQsImV4cCI6MTcxNzE2NzYyOSwiaWF0IjoxNzE3MTY3NjE0LCJpc3MiOiJodHRwczovL3NlcnZpY2VzLnJhZGlvLWNhbmFkYS5jYS8iLCJhdWQiOiJodHRwOi8vbG9jYWxob3N0LyJ9.NgGjFJal_QJZxRVcBgevkJvXGzwzzpR98DrKy5KA_wM
    Content-Length: 2
    Origin: https://ici.tou.tv
    DNT: 1
    Sec-GPC: 1
    Connection: keep-alive
    Referer: https://ici.tou.tv/
    Sec-Fetch-Dest: empty
    Sec-Fetch-Mode: cors
    Sec-Fetch-Site: cross-site
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    Here is a video provided by the dev : https://files.videohelp.com/u/309512/template.mp4
  3. Originally Posted by aqzs View Post
    thanks !
    Sep 2005
    Darkest Peru
    Thanks!!! Spend hours the past couple days trying to figure this out and all it takes is a couple minutes once you understand it.
  5. Member MaxRenn1983's Avatar
    Feb 2022
    Buenos Aires
    Hi, I'm trying with kanopy website.
    Do you know if the data must be copied from other elements?
    Sep 2005
    Darkest Peru
    Weird. I ran into the same confusion trying to get Hoopla to work tonight. Similar site.
  7. Originally Posted by MaxRenn1983 View Post
    Hi, I'm trying with kanopy website. Do you know if the data must be copied from other elements?
    kanopy required custom script. if you need key only, share video link
  8. Member MaxRenn1983's Avatar
    Feb 2022
    Buenos Aires
    custom script or custom data ?
    I want to learn how to get the keys by myself. I thought that's what cdrm is for.
  9. maybe i'm wrong. kanopy it's easy to do, i thing
    yes i have one custom script for kanopy, but now i can't remember how kanopy work
    share video link and i try to see how it work. and write here, PM is useless
  10. no kanopy it's easy to do. no need extra custom script
    for the first link i get:
    {"httpCode":401,"requestId":"Root=1-66d59034-1fd194ac489fc44f1883939b","status_code":401,"error_type":"unknown","error_msg":"Sorry","error_msg_long":"Unknown error"}
    but on second link work fine FoxRefire guesser. here your key
    4fef1645311a4516ac415e3437c09bb7:7688376faab4be271e00290e25d35c1b
  11. Member MaxRenn1983's Avatar
    Feb 2022
    Buenos Aires
    But I don't understand how to get the CDRM keys (thanks for the keys).
    PSSH:AAAAV3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADcIA RIQT+8WRTEaRRasQV40N8CbtxoLYnV5ZHJta2V5b3MiEIbl4b+ D9E2QrjyOWcMPeYwqAkhE
    License: https://kcms.kanopy.com/api/v1/playback/widevine_license ?
    or
    https://widevine.keyos.com/api/v4/getLicense ?
    Cookies: I guess the curl bash > curlconverter > copy cookies from there
    Headers and JSON like cookies?
    I don't understand where to put:
    {"httpCode":401,"requestId":"Root=1-66d59034-1fd194ac489fc44f1883939b","status_code":401,"error _type":"unknown","error_msg":"Sorry","error_msg_lo ng":"Unknown error"}
    I'm using Windows 10, Chrome or Firefox.
    I'm asking how to use CDRM for kanopy. Does it work ?
    I cannot ask for every pair of keys of every movie.
  12. there is nothing to understand. simply use FoxRefire guesser and it finds key automatically. easy
    https://forum.videohelp.com/threads/414140-[Release]-Widevine-L3-Guesser-Extension-Wor...-Chrome-All-OS
    Sep 2005
    Darkest Peru
    Doesn't that require you dump a CDM key to use it? Not exactly the same as using CDRM-Project.
    Someone needs to write a script that works with that site.
  14. yes the guesser need android cdm with the usual two files (like old wks tool required)
    but guesser is not the same as cdrm site, guesser is fully automated process. play only the video and get the key
    and no script is needed for this site: as i said before gesser is more than enough
    Sep 2005
    Darkest Peru
    I'd honestly like to learn how to do this manually. If I wanted it automatic I'd use streamfab.
    Sep 2005
    Darkest Peru
    or
    While I still haven't figured out Hoopla, I signed up with Kanopy tonight and found StreamFab doesn't support it. Ripped a video manually in no time at all.
    I use TamperMonkey to get the PSSH and it looks like you grabbed that okay.
    The license URL is https://www.kanopy.com/kapi/licenses/widevine/(with some numbers here).
    I copied cURL (Bash) from that link and pasted it in https://curlconverter.com/.
    So for cdrm-project you can paste the pssh, the license url, and the headers {...} and cookies {...} and you get the key.
    The .mpd file is easy enough to find: https://www.kanopy.com/kapi/manifests/dash/14422074.mpd
  17. Member aqzs's Avatar
    Mar 2024
    Paris
    As mentioned earlier you need a custom script for kanopy, cdrm-project will not be enough. I can help you if you provide me access to the content.
  18. Member
    Sep 2005
    Darkest Peru
    Huh? I didn't use a script. It was a piece of cake to download from.
