Hi,
I'm trying to download a video and audio track from an HLS playlist using N_m3u8DL-RE, and I'm having some issues.
Here's what I need:
Video: 1920x1080 resolution
Audio: Stereo 2CH
This is the command I used:
However, instead of the stereo 2CH audio, it is downloading a 16/JOCCH audio track. I'm not sure what I'm doing wrong.
HTML Code:N_m3u8DL-RE https://xxxx/master.m3u8 -sv res='1920*' -sa codec='2CH*' -M format=mp4 --save-name=test --download-retry-count=10 --thread-count=12
Any help to get the correct audio track would be greatly appreciated.
HTML Code:N_m3u8DL-RE https://xxxx/master.m3u8 -sv res='1920*' -sa codec='2CH*' -M format=mp4 --save-name=test --download-retry-count=10 --thread-count=12 01:35:16.884 INFO : N_m3u8DL-RE (Beta version) 20230628 01:35:16.895 INFO : Loading URL: https://xxxx/master.m3u8 01:35:16.975 INFO : Content Matched: HTTP Live Streaming 01:35:16.975 INFO : Parsing streams... 01:35:16.975 WARN : Master List detected, try parse all streams 01:35:16.981 WARN : Writing meta json 01:35:16.981 INFO : Extracted, there are 10 streams, with 6 basic streams, 4 audio streams, 0 subtitle streams 01:35:16.981 INFO : Vid 3840x2160 | 5931 Kbps | 24 | avc1.64001f 01:35:16.981 INFO : Vid 1920x1080 | 2892 Kbps | 24 | avc1.64001f 01:35:16.981 INFO : Vid 1280x720 | 1625 Kbps | 24 | avc1.4d401f 01:35:16.981 INFO : Vid 853x480 | 919 Kbps | 24 | avc1.4d401f 01:35:16.982 INFO : Vid 640x360 | 535 Kbps | 24 | avc1.4d401f 01:35:16.982 INFO : Vid 426x240 | 359 Kbps | 24 | avc1.4d401f 01:35:16.982 INFO : Aud audio_EC3Atmos | 'ENGLISH' | 16/JOCCH 01:35:16.982 INFO : Aud audio_51 | 'ENGLISH' | 6CH 01:35:16.982 INFO : Aud audio | 'ENGLISH' | 2CH 01:35:16.982 INFO : Aud audio_AC4IMS | 'ENGLISH' | 2/IMSACH 01:35:16.982 INFO : Parsing streams... 01:35:17.003 INFO : Selected streams: 01:35:17.003 INFO : Vid 1920x1080 | 2892 Kbps | 24 | avc1.64001f | 855 Segments | ~02h22m21s 01:35:17.003 INFO : Aud audio_EC3Atmos | 'ENGLISH' | 16/JOCCH | 855 Segments | ~02h22m21s 01:35:17.003 WARN : Writing meta json 01:35:17.003 INFO : Save Name: test 01:35:17.003 WARN : MuxAfterDone is detected, binary merging is automatically enabled 01:35:17.004 INFO : Start downloading...Vid 1920x1080 | 2892 Kbps | 24 | avc1.64001f 01:35:17.007 WARN : Reading [url=https://www.videohelp.com/software/MediaInfo]media info[/url]... 01:35:17.053 INFO : NaN: Video, h264 (avc1), 1920x1080 01:35:19.504 WARN : Force Exit... Vid 1920x1080 | 2892 Kbps | 24 ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 15% 198.91MB/1.41GB 105.26MBps 00:00:13 ⣾ Aud 'ENGLISH' | 16/JOCCH ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 0% - - --:--:-- ^C
I doubt that "2CH" corresponds to the audio codec. If you provided the actual m3u8 url, that would help us help you, or if it's not accessible, copy-paste its whole content here.
Here is what I got from the playlist
HTML Code:#EXTM3U ## Generated with https://github.com/google/shaka-packager version v2.6.1-634af65-release #EXT-X-INDEPENDENT-SEGMENTS #EXT-X-MEDIA:TYPE=AUDIO,URI="audio/aac/stream.m3u8",GROUP-ID="audio",NAME="'ENGLISH'",AUTOSELECT=YES,CHANNELS="2" #EXT-X-MEDIA:TYPE=AUDIO,URI="audio/ec3/stream.m3u8",GROUP-ID="audio_51",NAME="'ENGLISH'",AUTOSELECT=YES,CHANNELS="6" #EXT-X-MEDIA:TYPE=AUDIO,URI="audio/ac4/steam.m3u8",GROUP-ID="audio_AC4IMS",NAME="'ENGLISH'",AUTOSELECT=YES,CHANNELS="2/IMSA" #EXT-X-MEDIA:TYPE=AUDIO,URI="audio/ec3joc/steam.m3u8",GROUP-ID="audio_EC3Atmos",NAME="'ENGLISH'",AUTOSELECT=YES,CHANNELS="16/JOC" #EXT-X-STREAM-INF:BANDWIDTH=2106175,AVERAGE-BANDWIDTH=1625055,CODECS="avc1.4d401f,mp4a.40.2",RESOLUTION=1280x720,FRAME-RATE=24.000,AUDIO="audio",CLOSED-CAPTIONS=NONE 720/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=3931655,AVERAGE-BANDWIDTH=2892428,CODECS="avc1.64001f,mp4a.40.2",RESOLUTION=1920x1080,FRAME-RATE=24.000,AUDIO="audio",CLOSED-CAPTIONS=NONE 1080/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=7673658,AVERAGE-BANDWIDTH=5931275,CODECS="avc1.64001f,mp4a.40.2",RESOLUTION=3840x2160,FRAME-RATE=24.000,AUDIO="audio",CLOSED-CAPTIONS=NONE 2160/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=1140623,AVERAGE-BANDWIDTH=919157,CODECS="avc1.4d401f,mp4a.40.2",RESOLUTION=853x480,FRAME-RATE=24.000,AUDIO="audio",CLOSED-CAPTIONS=NONE 480/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=647998,AVERAGE-BANDWIDTH=535819,CODECS="avc1.4d401f,mp4a.40.2",RESOLUTION=640x360,FRAME-RATE=24.000,AUDIO="audio",CLOSED-CAPTIONS=NONE 360/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=409348,AVERAGE-BANDWIDTH=359268,CODECS="avc1.4d401f,mp4a.40.2",RESOLUTION=426x240,FRAME-RATE=24.000,AUDIO="audio",CLOSED-CAPTIONS=NONE 240/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=2151908,AVERAGE-BANDWIDTH=1684205,CODECS="avc1.4d401f,ec-3",RESOLUTION=1280x720,FRAME-RATE=24.000,AUDIO="audio_51",CLOSED-CAPTIONS=NONE 720/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=3977388,AVERAGE-BANDWIDTH=2951578,CODECS="avc1.64001f,ec-3",RESOLUTION=1920x1080,FRAME-RATE=24.000,AUDIO="audio_51",CLOSED-CAPTIONS=NONE 1080/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=7719391,AVERAGE-BANDWIDTH=5990425,CODECS="avc1.64001f,ec-3",RESOLUTION=3840x2160,FRAME-RATE=24.000,AUDIO="audio_51",CLOSED-CAPTIONS=NONE 2160/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=1186356,AVERAGE-BANDWIDTH=978307,CODECS="avc1.4d401f,ec-3",RESOLUTION=853x480,FRAME-RATE=24.000,AUDIO="audio_51",CLOSED-CAPTIONS=NONE 480/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=693731,AVERAGE-BANDWIDTH=594969,CODECS="avc1.4d401f,ec-3",RESOLUTION=640x360,FRAME-RATE=24.000,AUDIO="audio_51",CLOSED-CAPTIONS=NONE 360/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=455081,AVERAGE-BANDWIDTH=418418,CODECS="avc1.4d401f,ec-3",RESOLUTION=426x240,FRAME-RATE=24.000,AUDIO="audio_51",CLOSED-CAPTIONS=NONE 240/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=2034117,AVERAGE-BANDWIDTH=1565735,CODECS="avc1.4d401f,ac-4.02.02.00",RESOLUTION=1280x720,FRAME-RATE=24.000,AUDIO="audio_AC4IMS",CLOSED-CAPTIONS=NONE 720/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=3859597,AVERAGE-BANDWIDTH=2833108,CODECS="avc1.64001f,ac-4.02.02.00",RESOLUTION=1920x1080,FRAME-RATE=24.000,AUDIO="audio_AC4IMS",CLOSED-CAPTIONS=NONE 1080/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=7601600,AVERAGE-BANDWIDTH=5871955,CODECS="avc1.64001f,ac-4.02.02.00",RESOLUTION=3840x2160,FRAME-RATE=24.000,AUDIO="audio_AC4IMS",CLOSED-CAPTIONS=NONE 2160/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=1068565,AVERAGE-BANDWIDTH=859837,CODECS="avc1.4d401f,ac-4.02.02.00",RESOLUTION=853x480,FRAME-RATE=24.000,AUDIO="audio_AC4IMS",CLOSED-CAPTIONS=NONE 480/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=575940,AVERAGE-BANDWIDTH=476499,CODECS="avc1.4d401f,ac-4.02.02.00",RESOLUTION=640x360,FRAME-RATE=24.000,AUDIO="audio_AC4IMS",CLOSED-CAPTIONS=NONE 360/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=337290,AVERAGE-BANDWIDTH=299948,CODECS="avc1.4d401f,ac-4.02.02.00",RESOLUTION=426x240,FRAME-RATE=24.000,AUDIO="audio_AC4IMS",CLOSED-CAPTIONS=NONE 240/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=2407908,AVERAGE-BANDWIDTH=1940205,CODECS="avc1.4d401f,ec-3",RESOLUTION=1280x720,FRAME-RATE=24.000,AUDIO="audio_EC3Atmos",CLOSED-CAPTIONS=NONE 720/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=4233388,AVERAGE-BANDWIDTH=3207578,CODECS="avc1.64001f,ec-3",RESOLUTION=1920x1080,FRAME-RATE=24.000,AUDIO="audio_EC3Atmos",CLOSED-CAPTIONS=NONE 1080/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=7975391,AVERAGE-BANDWIDTH=6246425,CODECS="avc1.64001f,ec-3",RESOLUTION=3840x2160,FRAME-RATE=24.000,AUDIO="audio_EC3Atmos",CLOSED-CAPTIONS=NONE 2160/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=1442356,AVERAGE-BANDWIDTH=1234307,CODECS="avc1.4d401f,ec-3",RESOLUTION=853x480,FRAME-RATE=24.000,AUDIO="audio_EC3Atmos",CLOSED-CAPTIONS=NONE 480/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=949731,AVERAGE-BANDWIDTH=850969,CODECS="avc1.4d401f,ec-3",RESOLUTION=640x360,FRAME-RATE=24.000,AUDIO="audio_EC3Atmos",CLOSED-CAPTIONS=NONE 360/stream.m3u8 #EXT-X-STREAM-INF:BANDWIDTH=711081,AVERAGE-BANDWIDTH=674418,CODECS="avc1.4d401f,ec-3",RESOLUTION=426x240,FRAME-RATE=24.000,AUDIO="audio_EC3Atmos",CLOSED-CAPTIONS=NONE 240/stream.m3u8 #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=184548,AVERAGE-BANDWIDTH=66011,CODECS="avc1.4d401f",RESOLUTION=1280x720,CLOSED-CAPTIONS=NONE,URI="720/iframe.m3u8" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=292012,AVERAGE-BANDWIDTH=106698,CODECS="avc1.64001f",RESOLUTION=1920x1080,CLOSED-CAPTIONS=NONE,URI="1080/iframe.m3u8" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=311242,AVERAGE-BANDWIDTH=168860,CODECS="avc1.64001f",RESOLUTION=3840x2160,CLOSED-CAPTIONS=NONE,URI="2160/iframe.m3u8" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=92944,AVERAGE-BANDWIDTH=38457,CODECS="avc1.4d401f",RESOLUTION=853x480,CLOSED-CAPTIONS=NONE,URI="480/iframe.m3u8" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=45172,AVERAGE-BANDWIDTH=22333,CODECS="avc1.4d401f",RESOLUTION=640x360,CLOSED-CAPTIONS=NONE,URI="360/iframe.m3u8" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=27419,AVERAGE-BANDWIDTH=13461,CODECS="avc1.4d401f",RESOLUTION=426x240,CLOSED-CAPTIONS=NONE,URI="240/iframe.m3u8"
[Attachment 79544 - Click to enlarge]
Still not working.. Since op didn't share the url I don't know if I can share it..
N_m3u8DL-RE Video+Audio Separated In Folders
By Mochomo in forum Video Streaming DownloadingReplies: 15Last Post: 6th Mar 2024, 12:56 -
Download Youtube video with specific audio track?
By Zabon in forum Video Streaming DownloadingReplies: 8Last Post: 8th May 2023, 13:18 -
Edit Video Track Separately From Audio Track in VideoPad
By meandersleut in forum EditingReplies: 0Last Post: 12th Sep 2022, 12:11 -
Automatically skip specific subtitle
By gurman in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2022, 01:08 -
Turn Off Default Sub Titles (not forced) from specific audio track.
By Drakesal in forum Authoring (Blu-ray)Replies: 5Last Post: 21st Nov 2019, 03:29
