Hi all. First time posting here.
I'm not sure what I'm trying to learn has a name. It has black background, and on the foreground there are a numbers of columns/pillars representing the window look.
Example : https://www.youtube.com/watch?v=i4gJvcwlT28
Usually the freedom of this is you can edit the content of the what's inside of the rectangle panels.
Here's one of the best example using this style.
https://www.youtube.com/watch?v=h2Tzd7MiOj8&t=1171s
Eventually I hope to find a tutorial showing how to do this. I'm a beginner.
Thanks a lot everyone.
It's called an "overlay". The foreground pillar layer is placed "on top" of the background. The slots are "transparent", so the bottom background layer (the "rectangular panels") show through . In that example, there is a 3rd layer on top of the pillars, because the black pillars are partially covered
Usually this is done in a video editor (there are many free ones like shotcut, kdenlive)
Because the pillar layer is static (it' s not animated) , you can use a still image such as a PNG with alpha channel. The alpha channel is required for the transparency. You can make this in an image edtior such as gimp, photoshop
Recommended technique for using VHS capture equipment for LaserDisc?
By ehbowen in forum Capturing and VCRReplies: 2Last Post: 6th May 2024, 05:37 -
Tip - How to Capture with AJA Kona LHe Plus
By jwillis84 in forum Capturing and VCRReplies: 2Last Post: 19th Jan 2023, 10:08 -
Any camcorder top handle tip
By realspeed in forum Newbie / General discussionsReplies: 0Last Post: 11th Oct 2022, 12:22 -
Name of "teleprompter" feature or technique
By Video Bear in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2021, 04:53 -
How do you get this 3D technique?
By Buel in forum Newbie / General discussionsReplies: 12Last Post: 21st Dec 2020, 14:18
