Hi everyone,
1 year ago I bought a cheap USB HDMI capture card with a MS2130 chipset. I was not satisfied by it and it as too late to return it to the seller as it took more than 1 month to arrive.
I already had a cheap USB HDMI capture card with a MS2109 chipset and was satisfied by it. But it only captures MJEG and I would have like YUV (and it is posssible with MS2130.
Searching on github, I found some firmware for the MS2130 but I don't know how to fash it on the USB capture card to see if it improves the problems I encountered.
Does any of you know how to flash a firmware on this?
Best regards
I wouldn't try and flash a crappy capture card,it will still be the same,just look in the threads here for a better capture device.
Looking for a usb HDMI capture card that can be set at 24 fps
By Milardo in forum Capturing and VCRReplies: 12Last Post: 25th Nov 2023, 17:45 -
MS2130 chipset, the new low budget Hdmi capture card killer ?
By Hunk91 in forum Capturing and VCRReplies: 12Last Post: 2nd Jul 2023, 15:13 -
Tevion USB capture card not recognized (shows USB 2861 Video)
By retractOffer in forum Capturing and VCRReplies: 3Last Post: 4th Mar 2023, 12:38 -
HDMI USB Capture with 576i (uncompressed) support
By slikvik in forum Capturing and VCRReplies: 32Last Post: 15th Jun 2022, 02:49 -
Cable box > HDMI audio receiver > HDMI splitter > Capture card?
By ArianK in forum AudioReplies: 0Last Post: 6th May 2021, 04:18
