I extracted the Mpeg-2 from a bin and cue using vcdgear with fix mpg errors on but vcd imager says there are still errors. I tried using MPEG-Corrector and i tried multiplexing with tmpegenc but there are still errors.
What I do is extract the mpg file with Isobuster. Demux using TMPGEnc's Mpeg tools. Then remux, using the SVCD setting. So far this has always worked for me. If there are errors which prevent this, maybe you are better buring the bin/cue straight to disc, and hope for the best!
Access to the path 'F:\.mpg' is denied. Any idea how to fix it??
By StangGurl in forum Authoring (DVD)Replies: 6Last Post: 17th Dec 2010, 18:29 -
Scan and Fix a DVD that has some errors
By ppeterr in forum Authoring (DVD)Replies: 5Last Post: 21st Apr 2010, 02:38 -
How to test MPG files for errors?
By madmartian in forum Software PlayingReplies: 1Last Post: 17th Jun 2009, 14:30 -
Sound on both channel fix possible on mpg and wmv?
By Blå_Mocka in forum AudioReplies: 2Last Post: 3rd Jul 2008, 14:25 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 07:56
