I'm converting some mini DV tapes to my computer and I'm not happy with the quality. What would be the best device to purchase that will give me the best quality. My old home videos are on VHS tapes, Hi8 and mini DV, is there a device that can give great quality of picture and sound?
	What method/workflow do/did you use to get your DV footage onto your PC?
 If you're "transferring" from your DV camcorder to your PC with Firewire, you won't get any better, and it WILL be good. It will not be "bad quality" unless the tape recording itself, or the camcorder, are bad.
 There are a few options, each one with different requirements.
 Some questions:
 Does your PC have a Firewire port?
 If not, can your open the case and insert a PCIe card?
 What operating system/Windows version are you using?
	Man, that is such a broad question. The question you should be asking is how much time and money do you want to spend to do these conversions.
  Transferring video footage from camcorder tapes to computerBy newfielander in forum Capturing and VCRReplies: 0Last Post: 17th Feb 2024, 21:40
  Tape ruined camcorder. Camcorder ruined tapes. Tapes only play static.By camcorder problem in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd Jul 2023, 06:06
  no audio when capturing 8mm tapes to computer. Camcorder has a mono jackBy smoneydrains in forum Capturing and VCRReplies: 1Last Post: 21st Sep 2020, 16:47
  Converting Panasonic Palmcorder Mini DV tapes to digital videos on computerBy mgsibat in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2020, 20:42
  Sony Camcorder TRV815 Hi8 old tapes won't playback in camcorderBy Dforsythe in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2019, 17:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
