Hi videonerds
I'm getting more and more frustrating...
I try to get away of these videoglitches on still objects in the video when using QTGMC. (with SLOW default; looking at the down right at the letters)
The jumping effect is more see when the "real" videoclip is changing the sequence.
So this must be the devil....
Playing with the ThSAD1 & ThSAD12 and ThSCD1 & ThSCD2 parameters helped a little bit, but increases ghosting effects.
Also in general, after using QTGMC, the video is much more blurry, compairing the sharpness at the letters again.
Much less readable.
Hopefully someone can help me out.
Thanks.
Results 1 to 16 of 16
The glitch on the stationary text appears whenever there is lot's of motion on the entire screen. I have seen this before plenty of times. By default, QTGMC has a quite sensitive scene change detection which triggers this (btw, nice old recording of that TV station).
This means ThSCD1 and ThSCD2 are the first parameters to fiddle with. I never use the sensitive defaults. I found that ThSCD1=300, ThSCD2=110 work well for me most of the time.
Some more parameters you can have a look at to help the issue are:
• dct=5
• Rep0=1 (maybe, try)
• Blocksize=8
ThSAD1 and ThSAD2 should be increased only as a last resort.
Edit: With that being said, whenever there is an actual proper scene change, this bobbing of the entire frame for the duration of two former fields is what QTGMC is supposed to do, and making it not do it is going to have ill-effects on the actual video.Last edited by Skiller; 27th May 2024 at 09:55.
Another approach is to mask out the part of the box area with a bwdif(field=2) or tdeint(mode=1, tryweave=true) , so the video is processed by QTGMC (whatever settings), but the problem text area will be weaved and sharp .
the flickering of the logo in the right corner should be fixed by using Lossless=2
users currently on my ignore list: deadrats, Stears555 -
ffms2("aerzte_original.avi") convertbits(16).converttoyuv444(matrix="Rec601") bwdif(2).qtgmc(preset="slower",noisepreset="slower",inputtype=1)
Try preset "Ultra Fast"
Sharpness with complex motion is a place for M_QTGMC* . Though some flickering at small letters still exist and present near scene change. Will try to play with thSCD1 param when I will have time.
Here is example of M_QTGMC_medhigh() - performance is
encoded 986 frames, 1.76 fps, 2930.02 kb/s
with x264 at i5-9600K CPU. Also added _high example (of about 0.1 fps performance @i5-9600K CPU - datacenter renderfarm or XeonMAX with HBM RAM integrated recommended for better fps).
"This means ThSCD1 and ThSCD2 are the first parameters to fiddle with."
Yes - increasing ThSCD1 to 300 helps at least at some scene changes. But not with all present. Added also version with ThSCD1=300 (and a bit higer ThSAD2 to 250).Last edited by DTL2023; 1st Jun 2024 at 02:26.
LWLibavVideoSource("Z:\aerzte_original.avi")
converttoyv12()
interp = nnedi3(field=-2)
tdeint(mode=1,slow=2, tryweave=false,denoise=true,edeint=interp)
merge(selecteven,selectodd)
or
converttoyv12()
blendbob()
both give a softer picture but smooth motion at 25FPS. merge seems to be a bit smoother on the text side scrolling for me. if you want full 50FPS out then the QTGMC route definitely looks better.if all else fails read the manual -
Yes - setting Lossless to 2 greatly fixes sharpness of small letters in that logo (close to simple weave). But also degrages other possible details and sharpness at other frame areas possible with QTGMC.
I found setting SourceMatch=2 without Lossless as somehow more balancing between logo small letters details and other frame areas. Result in the attach. Also adding SourceMatch processing takes some more performance and result is about 0.4 fps at i5-9600K.
Also I not see visible difference between MatchPreset slow and fast so select fast to save some time.
Additional idea: It looks defaults of QTGMC (no MatchSource and no Lossless) are developed for 'restoration' and may significantly change the source. So it is applicable to not very good quality sources. And new additions of MatchSource and Lossless cause returning to input source quality so mostly applicable to very good quality sources. In this example if we treat logo with small text as good quality source we need to apply MatchSource and Lossless only to this area in best case.Last edited by DTL2023; 2nd Jun 2024 at 02:43.
Use different processing for different areas via Overlay() and a mask.
Code:########################################################################## # # Fill a rectangular box with a specified color. # ########################################################################## function BoxFill(clip v, int x, int y, int w, int h, int color) { BlankClip(v, color=color) Crop(0, 0, w, h) Overlay(v, last, x, y) } ########################################################################## LWLibavVideoSource("aerzte_original.avi, "format="rgb32") ConvertToYV24() #deinterlace QTGMC(SourceMatch=2) # strong temporal filter only on the yellow countdown overlay bmask = BlankClip(last).BoxFill(628, 444, 88, 124, color_white).ColorYUV(cont_y=50).Blur(1.5).Blur(1.5).Blur(1.5) Overlay(last, SMDegrain(tr=3, thsad=1000, PreFilter=4), mask=bmask) prefetch(8)
Yes - masking is best solution but for full-auto processing it is nice to have feature of auto-masking of static areas like logo. May be some plugins/scripts exist to combine 2 clips depending on motion ? It is possible to do via mvtools MMask() so maybe already implemented ? The QTGMC may exports MVs via globals so no additional slow MAnalyse is required.
"# strong temporal filter only on the yellow countdown overlay
Overlay(last, SMDegrain(tr=3, thsad=1000, PreFilter=4), mask=bmask)"
MC SMDegrain for static low half of yellow logo is waste of resources and also dangerous for some false scenechange detection and stopping of processing of some frames so may give uneven temporal result (same as we curently get with QTGMC). It is more fast and safe to use non-MC temporal denoiser at this area like vsTTempSmooth or simple Average.Last edited by DTL2023; 2nd Jun 2024 at 02:52.
+1 and here is a demo script which I have tested with OP's file
Code:# set up the source LWLibavVideoSource("aerzte_original.avi") ConvertToYV12() PropDelete("_FieldBased") # force Avisynth field order # double rate mocomp deinterlacing with slightly raised weave thresh BWDIF(field=-2, thr=2) # qtgmc antialiasing (low strength) QTGMC(InputType=1, preset="slow", Sharpness=0.2).Prefetch(4) # qtgmc antialiasing (high strength) # QTGMC(InputType=2, preset="slow", Sharpness=0.5).Prefetch(4)
Jumping/Flickering video
By Gemma Wood in forum Video ConversionReplies: 16Last Post: 26th Jan 2024, 22:10 -
Jumping-Hesitating Video
By Alwyn in forum RestorationReplies: 32Last Post: 2nd Aug 2023, 07:38 -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
delay in playing video when jumping ahead
By rocketman122 in forum Software PlayingReplies: 0Last Post: 22nd Sep 2021, 00:53 -
H.264 video jumping when output to av receiver
By BeachNut in forum Software PlayingReplies: 0Last Post: 23rd Mar 2020, 07:15
