Is there any way to have the Audio tab default to Copy instead of Convert in Xmedia Recode? A setting in the ini file would be fine. Thanks for any help.
I was able to change the number of reference frames displayed in the application from 2 to 4. I had to change V11NbRefFrames=2 in the mkv.ini file to V11NbRefFrames=4. Now I don’t have to worry about doing that manually.
I don’t know what needs to be changed in order to do what you desire. However, convert and copy both appear under Mode: in the application, under the Video and Audio tabs. I did a string search of all the Xmedia Recode ini files looking for the word “mode”. I did two searches, one for “mode” and one for “Mode”. I later found that there is a switch I could have used to find both cases at the same time. I actually liked the separate files. There are quite a few mode entries in both listings.
My guess is, assuming “mode” is the key word, is that the ini file to change would be under the type of file you selected under the Format tab. In my case it was mkv.ini. There are two “mode” entries in that file and twelve “Mode” listings. My guess is one of those entries is the one you are looking for but it’s just a guess. I haven’t played around with modifying any ini files but it’s easy enough. I always save a copy of the original file even though I’m making a small change. There’s always the possibility that there is a master ini file too.
I won’t list my finding here but in case your not comfortable with command line syntax I will list what I did. I’m on Windows 10 Pro 64. First open up the command prompt.
Switch to Xmedia Recode’s Format directory. Your directory path might be different.
cd\program files\xmedia recode 64bit\format
Make a listing of lower case “mode” entries. If you want a separate file for uppercase Mode assign a different file name, mode0.txt, mode1.txt.
Findstr mode *.ini > mode.txt
Now if you want all cases of mode:
Findstr /I mode *.ini > mode.txt
Sorry for the long winded response. Hopefully it helped some.
Good luck. Be sure to report back what you find if you go this route.
Any way to make certain settings default? (XMedia Recode)
By AnonThrowaway in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2023, 11:27 -
Rename Audio Track with XMedia Recode
By ten in forum AudioReplies: 2Last Post: 24th Jun 2022, 03:53 -
XMedia Recode - Crop video with video copy?
By thegdog in forum Video ConversionReplies: 5Last Post: 6th Jan 2022, 09:25 -
XMedia Recode - Video Tab - "Preset" Setting
By Cherry Picker in forum Video ConversionReplies: 0Last Post: 28th Dec 2021, 10:55 -
XMedia Recode problem: can't have any audio
By dr.noise in forum Newbie / General discussionsReplies: 22Last Post: 12th Jan 2020, 09:13
