I've converted online ( bandlab , spliter AI etc) live dual-mono audio
so i could make them sound a bit better
i had a few individual files (bass , drum , vocals and others*)
and i also had stems (aac) the sounded a bit better
and the stems imported in Vegas (VMS) and cakewalk as the main dual mono track (no bass , no drum etc)
but in audacity i had 5 dual mono tracks (main , drums, bass , vocal , and others*) this is 10 tracks looks like i can't export more than 8 with audacity
Their must be an easier way to work with them ...
i want to clean up artifacts and add a few vst
any suggestions ?
*others being guitars , melody ...
The first consideration is artistic, what do want to do to your stems with regard to sound modification,
second is logistical, how/can Audacity be used to manipulate the tracks to do what what you want in terms of mixing and export, etc.
For example , with a multi track project open, you can use mute/solo to hear individual or groups of track
and use the Select button (CTRL key to select more that one) to apply effects to the seleced track(s)
and mix to a new track and/or export
just those tracks (usually mix to stereo is automatic)
Audacity can do it, but its interface takes a bit of getting used toLast edited by davexnet; 26th May 2024 at 13:20.
mp4decrypt not work
By lfybbk10 in forum Video Streaming DownloadingReplies: 38Last Post: 20th Feb 2025, 06:46 -
Can't Get MKVcleaver to Work
By DarrellS in forum Video ConversionReplies: 9Last Post: 5th Nov 2023, 22:04 -
Is there a work around for no AV-IN?
By plehoediv in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 9th Jul 2023, 07:04 -
how work yt-dlp
By whs912km in forum Video Streaming DownloadingReplies: 18Last Post: 22nd Nov 2022, 20:43 -
Does AVCHDCoder work?
By rthurlow in forum Authoring (Blu-ray)Replies: 3Last Post: 7th Jun 2020, 17:59
