I’d like to extract the DTS-HD MA tracks from several mkv files ripped from Blu-rays, and I’m looking to preserve to original audio quality.
I’ve extracted the tracks with FFMPEG and MKVToolNix.
For the file created by Handbrake, JRiver Media Center lists the bitrate as 3825, and on playback the bitrate spends a lot of time in the 4500’s and spikes as high as 23,000 kbps on orchestral flourishes.
The files created by FFMPEG and MKVToolNix have constant bitrates of 3767 and 3764, respectively, and play at noticeably lower volume and narrower dynamic range.
Handbrake will also put the DTS-HD MA track in an m4v container, which I couldn’t get to work in FFMPEG or MKVToolNix.
What’s the best way to extract an audio only DTS-HD MA file?
Also, which DTS-HD MA container file type has the widest compatibility?
	To my knowledge DTS-MA always has a variable bitrate and I wouldn't worry too much about different bitrate values being listed.
 Since your sourcefiles are mkv I would use mkvextract.exe to retrieve the audio. It's a cli tool that comes with the MKVToolNix package. Frontend I use is gMKVExtractGUI.
 A possible reason for differences in playback volume is dialog normalization metadata being present, and/or if this metadata is honoured by the playback device. It can be removed by eg. MKVToolNix. Lower playback volume should not be mistaken for lower dynamic range though.
 As for "widest compatible" container format, this depends on what your player(s) - whether standalone or built-in - would prefer. I think three most widely used containers that support DTS-HD MA are m2ts, mp4 and matroska (mkv or mka).Last edited by Ennio; 26th May 2024 at 05:04.
	You can use clever FFmpeg-GUI.
 Extract the exe from the zip archive, click it and follow the instructions.
 Then load your mkv, click main, click extract streams, uncheck the videostream, click extract.
 Done.
 [Attachment 79381 - Click to enlarge]
 The sample used is a DTS HD MA 7.1.
 Tested
  Subtitle Edit is only extracting the last xx min of subtitles on mkv filesBy goggleboy in forum SubtitleReplies: 4Last Post: 12th Oct 2023, 01:55
  Conversion of MKA files to .DTS and .WAV formats from original MKV sourceBy cybnmusic in forum MacReplies: 2Last Post: 25th May 2023, 18:07
  Split video and audio tracks in seperate files from a MKV source fileBy ElegantRain in forum Video ConversionReplies: 29Last Post: 13th Sep 2021, 12:28
  MKV files keeping attachments as Video Tracks Post Conversion Using FFmpegBy savethelost007 in forum Video ConversionReplies: 1Last Post: 2nd Dec 2020, 05:29
  Convert mkv with DTS HD MA to mkv with DTS core - Mac userBy bardian in forum MacReplies: 3Last Post: 9th Apr 2020, 15:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
