  1. i reduced the size of a movie i have to fit on a dvd-r using rempeg2. how do i burn the .m2v and .ac3 files using prassi? or should i use a different program?
  2. Use SpruceUp....
    Make sure that the m2v and the ac3 are of the same name... like MyMovie.m2v and MyMovie.ac3.
    Import the m2v as an asset... the ac3 should follow on straight after. then play your movie back in the preview window to make sure of audio and video sync.
    That should get you started.
