hi there
i ripped swordfish to my hd and there is no sound!i tried dvd audio extacters but the sound is all over the place and i can seem to get it to work what should i do?
the programes i have are:
clad dvd xp
dvd2avi
tmpg
vobrator 2.0
please help as soo as possible!
thanks :wink:
use dvd2avi to extract the audio...
in dvd2avi's audio options....Dolby digital -> decode
MPEG audio-> demux
once you have this set up, if you still can't extract the audio when you create the project file (.d2v), then you need to select another audio track..it could be the track you selected is DTS, which dvd2avi can't decode
so choose another track and try again -
When I ripped swordfish the main track is dts - dvd-avi will not produce a wav file - you will have to use the dvdripping program to extract exactly which track you want - for these problems i use clad dvd xp - and chose which audio track to be ripped with the video
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Blu-ray ripped files to hard drive in Folders not un ISO Image
By judgmentday in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2008, 14:26
