  1. Hello, I have this issue where I'm downloading a HLS stream using streamlink, and I download them to .ts format for best stability as after many trial and error trying to download directly to mkv resulted in delayed audio also. Now I'm trying to convert these files to mkv format to edit them, but both using ffmpeg or mkvtoolnix, audio issues happen (delayed audio, straight up no audio and random screeches of loud noise)
    Here are the logs trying to convert using ffmpeg and having an output with no sound at the beginning, but halfway through it has no sound :
    ffmpeg -i .\prof1.ts -c copy "prof1.mkv"
    [aist#0:1/aac @ 00000202e79dee40] timestamp discontinuity (stream id=221): -20011999, new offset= 20011999
    [vist#0:0/h264 @ 00000202e6fc9d00] timestamp discontinuity (stream id=211): 20012000, new offset= -1
    [vist#0:0/h264 @ 00000202e6fc9d00] timestamp discontinuity (stream id=211): -20012000, new offset= 20011999
    [aist#0:1/aac @ 00000202e79dee40] timestamp discontinuity (stream id=221): -4010666, new offset= 24022665
    [vist#0:0/h264 @ 00000202e6fc9d00] timestamp discontinuity (stream id=211): -4000000, new offset= 28022665
    [aist#0:1/aac @ 00000202e79dee40] timestamp discontinuity (stream id=221): -21485999, new offset= 49508664
    [aist#0:1/aac @ 00000202e79dee40] timestamp discontinuity (stream id=221): -22030432, new offset= 71539096
    [mpegts @ 00000202e6f51a80] DTS 1998004806 < 1999982196 out of order
    [out#0/matroska @ 00000202e6f5d740] video:2618569KiB audio:117852KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 0.078680%
    What I'm confused about is that I had this type of message in other attempts of conversion, but the output file was perfectly fine.
    This lack of consistency is what is getting me so confused.
    Example of messages in fine output file :
    [aist#0:1/aac @ 0000025bd6716640] timestamp discontinuity (stream id=221): 51625148, new offset= -51625148
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): -51625144, new offset= -4
    [aist#0:1/aac @ 0000025bd6716640] timestamp discontinuity (stream id=221): 51623258, new offset= -51623262
    [h264 @ 0000025bd67341c0] illegal memory management control operation 32
    [h264 @ 0000025bd67341c0] illegal reordering_of_pic_nums_idc 32
    [h264 @ 0000025bd67341c0] reference count 1 overflow
    Last message repeated 2 times
    [h264 @ 0000025bd67341c0] illegal reordering_of_pic_nums_idc 31
    [h264 @ 0000025bd67341c0] reference overflow 1118 > 15 or 0 > 15
    Last message repeated 1 times
    [aist#0:1/aac @ 0000025bd6716640] timestamp discontinuity (stream id=221): -9985886, new offset= -41637376
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): -9960000, new offset= -31677376
    [aist#0:1/aac @ 0000025bd6716640] timestamp discontinuity (stream id=221): -27149953, new offset= -4527423
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): 27149956, new offset= -31677379
    [mpegts @ 0000025bd6691a80] DTS 6149782746 < 6152222646 out of order
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): -27110000, new offset= -4567379
    [aost#0:1/copy @ 0000025bd6d0e400] Non-monotonic DTS; previous: 134862, current: 134845; changing to 134862. This may result in incorrect timestamps in the output file.
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): 31750000, new offset= -36317379
    [aist#0:1/aac @ 0000025bd6716640] timestamp discontinuity (stream id=221): -10007730, new offset= -26309649
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): 10007734, new offset= -36317383
    [mpegts @ 0000025bd6691a80] DTS 7020312786 < 7021209186 out of order
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): -9960000, new offset= -26357383
    [aost#0:1/copy @ 0000025bd6d0e400] Non-monotonic DTS; previous: 9785629, current: 9785604; changing to 9785629. This may result in incorrect timestamps in the output file.
    [aist#0:1/aac @ 0000025bd6716640] timestamp discontinuity (stream id=221): -20987974, new offset= -5369409
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): 20987967, new offset= -26357376
    [mpegts @ 0000025bd6691a80] DTS 7020223866 < 7022109186 out of order
    [vist#0:0/h264 @ 0000025bd772f040] timestamp discontinuity (stream id=211): -20948000, new offset= -5409376
    [aost#0:1/copy @ 0000025bd6d0e400] Non-monotonic DTS; previous: 9805573, current: 9805556; changing to 9805573. This may result in incorrect timestamps in the output file.
    [out#0/matroska @ 0000025bd67158c0] video:3232659KiB audio:164495KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 0.071552%
    size= 3399585KiB time=02:55:45.47 bitrate=2640.9kbits/s speed= 223x
    Any help is appreciated, thank you.
  2. Download to mp4 the next time.
  3. Originally Posted by ProWo View Post
    Unfortuntely as I specified, I tried a bunch of different formats, and only .ts produces a file with no issues.
  4. The problem doesn't concern av container type but the streaming or connection quality. Fixing such errors like you list always leads to skipping of some frames and thus to a/v jumps
  5. Originally Posted by noemi7 View Post
    update : I just tried this command
    ffmpeg -i .\prof1.ts -c:v copy -c:a aac output.mkv
    and finally the produced file has normal audio, does this mean I have to re-encode the audio each time I want to convert it or is there a way to fix this directly ?
    Mar 2021
    Israel
    Try opening the ts files in TS Doctor. It usually finds errors and creates a new file without errors. Give it a try. 30 days fully functional trial available.
    I have been using it for many years after recording files from my satellite dish.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Yes definitely try TSDoctor to iron out transmission errors
