I'm using Pinnacle capture, edit and convert mpeg2 file, then use MyDVD 3.0 to write to DVD using Pioneer DVR-A04. The DVD play just fine until about half way through the file, and the sound quits. The video contiunes to play just fine. Every time, the sound quits half way through, but the video plays all the way through. I tested the mpeg file, it was fine. I made the DVD in my hard drive and tested it, it was fine. So, I think it was the problem with the burning process.
Does anyone know if there is any way to fix the problem?
James
Results 1 to 1 of 1
conversion loses sound half-way through
By santino_avi in forum Video ConversionReplies: 5Last Post: 21st Oct 2008, 11:35 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 08:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
