The python program below will call node-js (to be installed on your system) and simulate a browser environment to extract the HMAC-SECRET and AES-KEY from My5's current javascript online code.
To install node see https://nodejs.org/en for install to sut your OS.
then run
to install needed modules.Code:npm install node-fetch npm install jsdom npm install require.js
Finally save the python below to autkeys.py and run it in a terminal window.
It outputs to the command line and a file records the result - output.json
The script produces an altered version of Diazole's browser JavaScript that runs via node (node-js) called simulate_browser.js.Code:import subprocess import json import os js_code = """ const { JSDOM } = require("jsdom"); const fs = require("fs"); async function simulateBrowser() { const fetch = await import('node-fetch').then(mod => mod.default); const dom = new JSDOM(`<!DOCTYPE html><body></body>`, { url: "https://player.akamaized.net/", resources: "usable", runScripts: "dangerously" }); const window = dom.window; window.fetch = fetch; try { const response = await window.fetch("https://player.akamaized.net/html5player/core/html5-c5-player.js"); const jsCode = await response.text(); const scriptElement = window.document.createElement("script"); scriptElement.textContent = jsCode; window.document.body.appendChild(scriptElement); const inlineScript = ` fetch('https://player.akamaized.net/html5player/core/html5-c5-player.js') .then((r) => r.text()) .then((b) => { const dfnm = /\\\\x72\\\\x65\\\\x74\\\\x75\\\\x72\\\\x6e\\\\x20\\\\x74\\\\x79\\\\x70\\\\x65\\\\x6f\\\\x66\\\\x20([a-z0-9]+)\\\\[(\\\\d+)\\\\]\\\\.([a-z0-9]+)\\\\x20\\\\x3d\\\\x3d\\\\x3d\\\\x20\\\\x27\\\\x66\\\\x75\\\\x6e\\\\x63\\\\x74\\\\x69\\\\x6f\\\\x6e\\\\x27/gi.exec(b); const krm = /\\\\x27\\\\\\\\x68\\\\x27:[a-z0-9]+\\\\.[a-z0-9]+\\\\((\\\\d+)\\\\),'\\\\\\\\x61':[a-z0-9]+\\\\.[a-z0-9]+\\\\((\\\\d+)\\\\)/gi.exec(b); if (!dfnm || !krm) { window.simulationResult = { error: 'Regex did not match any content', dfnm, krm }; return; } window.simulationResult = { HMAC_SECRET: window[dfnm[1]][dfnm[2]][dfnm[3]](krm[1]), AES_KEY: window[dfnm[1]][dfnm[2]][dfnm[3]](krm[2]), }; }) .catch((err) => { window.simulationResult = { error: err.message }; }); `; const inlineScriptElement = window.document.createElement("script"); inlineScriptElement.textContent = inlineScript; window.document.body.appendChild(inlineScriptElement); // Wait for the fetch and processing to complete await new Promise(resolve => setTimeout(resolve, 3000)); // Write the result to a file if (window.simulationResult) { fs.writeFileSync("output.json", JSON.stringify(window.simulationResult)); } else { fs.writeFileSync("output.json", JSON.stringify({ error: 'Unknown error' })); } } catch (err) { console.error('Error in simulateBrowser:', err); fs.writeFileSync("output.json", JSON.stringify({ error: err.message })); } } simulateBrowser().catch((err) => { console.error('Error in simulateBrowser:', err); fs.writeFileSync("output.json", JSON.stringify({ error: err.message })); }); """ with open("simulate_browser.js", "w") as f: f.write(js_code) result = subprocess.run(["node", "simulate_browser.js"], capture_output=True, text=True) if result.returncode != 0: print("Error executing JavaScript file") print(result.stderr) exit() if not os.path.exists("output.json"): print("output.json file was not created") print("Node.js output:", result.stdout) exit() with open("output.json", "r") as f: output = json.load(f) if "error" in output: print("Error in JavaScript execution:", output["error"]) else: print(output)
If you wish, node will run simulate_browser.js directly and write output to output.json
Note there is a wait set in the script
await new Promise(resolve => setTimeout(resolve, 3000)); // 3 seconds
If 3 seconds isn't enough, make it 5000 (5 seconds) and more til it works
[Attachment 79285 - Click to enlarge]
Thanks to help from Open AI
https://files.videohelp.com/u/301890/autkeys.py
Results 1 to 11 of 11
Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
Got one error after the install when running the autkeys.py
Code:Node.js v20.13.1 PS C:\Scripts\hmac> py .\autkeys.py Error executing JavaScript file node:internal/modules/cjs/loader:1148 throw err; ^ Error: Cannot find module 'jsdom' Require stack: - C:\Scripts\hmac\simulate_browser.js at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15) at Module._load (node:internal/modules/cjs/loader:986:27) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (C:\Scripts\hmac\simulate_browser.js:2:19) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) { code: 'MODULE_NOT_FOUND', requireStack: [ 'C:\\Scripts\\hmac\\simulate_browser.js' ] } Node.js v20.13.1 PS C:\Scripts\hmac>
Reran the installs again
Thank you, A_N_G_E_L_ACode:found 0 vulnerabilities PS C:\Scripts\hmac> py .\autkeys.py {'HMAC_SECRET': 'lh8f+vMkRbUGaxRVmkMB6g==', 'AES_KEY': 'jmf6e2n+fgQrfw8DJ34hBg=='} PS C:\Scripts\hmac>Last edited by PSXman_uk; 20th May 2024 at 09:51.
Yes, just need to find out how to implement it should the other one stop working
Well I'd run authmac.py from menu to upate output.json.
Then my5_getter.py I'd add code to read the file 'output json' and extract the dictionary keys therein.
Something like this
Code:import json file = open('./output.json','r') myjson = json.load(file) HMAC_SECRET = myjson["HMAC_SECRET"] AES_KEY = myjson["AES_KEY"] ## for testing print("HMAC_SECRET") print(HMAC_SECRET) print("AES_KEY") print(AES_KEY) ## # and the rest of my5_getter.py........Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
Got a small error on another machine works but has this error first
Could not find platform independent libraries <prefix> -
Seems to not be able to find python home so you can use python command not py and it works with no error
My5 Downloader
By Diazole in forum Video Streaming DownloadingReplies: 24Last Post: 15th Dec 2024, 16:40 -
New My5 Downloader
By Briskly6533 in forum Video Streaming DownloadingReplies: 6Last Post: 20th Apr 2024, 08:06 -
help required with a random i t v download using angelas script..
By LastResort in forum Video Streaming DownloadingReplies: 24Last Post: 20th Jul 2023, 15:40 -
Script downloader for My5
By joaopa0 in forum Video Streaming DownloadingReplies: 2Last Post: 7th Apr 2023, 05:11 -
help decrypting drm dash hmac
By filipino in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2021, 06:07
