Results 1 to 9 of 9
  1. I've tried to download the video by using N_m3u8DL-RE with a key
    It successfully downloaded the file, but the decrypted video is wrong.
    Here is what I've tried:
    01:53:35.359 INFO : Vid *CENC 1920x1080 | 6004 Kbps | DCUP7KE6 | 23.976 | avc1.640029 | 958 Segments | ~01h19m46s
    01:53:35.360 INFO : Vid *CENC 1280x720 | 2453 Kbps | mJeAHtMj | 23.976 | avc1.64001F | 958 Segments | ~01h19m46s
    01:53:35.360 INFO : Vid *CENC 852x480 | 1314 Kbps | k9ZRf7ZO | 23.976 | avc1.4D401E | 958 Segments | ~01h19m46s
    01:53:35.361 INFO : Vid *CENC 640x360 | 768 Kbps | Xkf2Ztxz | 23.976 | avc1.4D401E | 958 Segments | ~01h19m46s
    01:53:35.362 INFO : Vid *CENC 256x144 | 204 Kbps | ijCm99a6 | 23.976 | avc1.4D400C | 958 Segments | ~01h19m46s
    01:53:35.362 INFO : Vid 1600x720 | 32 Kbps | 3d2281ad-4cf1-4726-8787-8afdaa41625f/c8112ee8-7937-4e8c-b46e-aa501ce1f704 |
    24 Segments | ~01h20m00s
    01:53:35.363 INFO : Vid 720x324 | 16 Kbps | 3d2281ad-4cf1-4726-8787-8afdaa41625f/9e5d8fbd-e3b5-41b4-9ebb-ce12e52e7aa7 |
    01:53:35.364 INFO : Aud *CENC SVlkquIQ | 201 Kbps | mp4a.40.2 | 2CH | 959 Segments | ~01h19m46s
    01:53:37.599 INFO : Parsing streams...
    01:53:37.608 INFO : Selected streams:
    01:53:37.609 INFO : Vid *CENC 1920x1080 | 6004 Kbps | DCUP7KE6 | 23.976 | avc1.640029 | 958 Segments | ~01h19m46s
    01:53:37.610 INFO : Aud *CENC SVlkquIQ | 201 Kbps | mp4a.40.2 | 2CH | 959 Segments | ~01h19m46s
    01:53:37.611 WARN : Writing meta json
    01:53:37.617 INFO : Save Name: 10438103_2024-05-20_01-53-35
    01:53:37.617 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    01:53:37.619 INFO : Start downloading...Vid 1920x1080 | 6004 Kbps | DCUP7KE6 | 23.976 | avc1.640029
    01:53:37.685 WARN : Type: cenc
    01:53:37.686 WARN : PSSH(WV): CAESEOxHnYORfEIpi7hjA+aRGUkaC2J1eWRybWtleW9zIhAGkkjZ/4dHK7a20uBPAtnP
    01:53:37.687 WARN : KID: ec479d83917c42298bb86303e6911949
    01:53:37.688 WARN : Reading media info...
    01:53:37.722 INFO : [0x1]: Video, h264 (avc1), 1920x1080
    01:55:46.436 INFO : Binary merging...
    01:55:48.413 INFO : Decrypting...
    01:55:48.431 INFO : Start downloading...Aud SVlkquIQ | 201 Kbps | mp4a.40.2 | 2CH
    01:55:48.447 WARN : Type: cenc
    01:55:48.448 WARN : PSSH(WV): CAESEOxHnYORfEIpi7hjA+aRGUkaC2J1eWRybWtleW9zIhAGkkjZ/4dHK7a20uBPAtnP
    01:55:48.449 WARN : KID: ec479d83917c42298bb86303e6911949
    01:55:48.451 WARN : Reading media info...
    01:55:48.479 INFO : [0x2]: Audio, aac (mp4a)
    01:55:54.305 INFO : Binary merging...
    01:55:54.552 INFO : Decrypting...
    01:55:54.556 WARN : 10438103_2024-05-20_01-53-35.mp4
    01:55:54.556 WARN : 10438103_2024-05-20_01-53-35.m4a
    01:55:54.556 WARN : Muxing to 10438103_2024-05-20_01-53-35.MUX.mp4
    01:55:54.698 WARN : [h264 @ 000002816bbf4fc0] left block unavailable for requested intra4x4 mode -1
    01:55:54.699 WARN : [h264 @ 000002816bbf4fc0] error while decoding MB 0 11, bytestream 273
    01:55:54.862 WARN : [aac @ 000002816bbf4fc0] Number of scalefactor bands in group (15) exceeds limit (14).
    01:55:54.863 WARN : [mp4 @ 000002816c0ebe80] track 1: codec frame size is not set
    01:55:54.879 WARN : [mp4 @ 000002816c0ebe80] aac bitstream error
    01:55:57.764 WARN :     Last message repeated 66 times
    01:55:57.843 WARN : Cleaning files...
    01:55:58.110 WARN : Rename to 10438103_2024-05-20_01-53-35.mp4
    01:55:58.111 INFO : Done
    The decryption of the download version didn't work as expected. I cannot watch video content.
    Please help me to find out the correct decoding method
    Thanks you.
  2. can you paste your command you used?
    make sure mp4decrypt or/and shaka-packager in your system variable path.
    key cached:
    ec479d83917c42298bb86303e6911949:9eeb0fb0e0782ec620b6dee66c1c58a2
    but it from 2022, not sure if the key will work or not.
  3. This is my command.
    what is the key cache used for?
    C:\N_m3u8DL-RE\N_m3u8DL-RE>N_m3u8DL-RE --key n0suchd3v1c3f113:r3adth3fuck1ngma2ua1 "https://www.kanopy.com/kapi/manifests/dash/10438103.mpd" -M format=mp4
    08:45:10.397 INFO : N_m3u8DL-RE (Beta version) 20230628
    08:45:10.412 INFO : Loading URL: https://www.kanopy.com/kapi/manifests/dash/10438103.mpd
    08:45:10.756 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
    08:45:10.758 INFO : Parsing streams...
    08:45:10.789 WARN : Writing meta json
    08:45:10.799 INFO : Extracted, there are 8 streams, with 7 basic streams, 1 audio streams, 0 subtitle streams
    08:45:10.800 INFO : Vid *CENC 1920x1080 | 6004 Kbps | DCUP7KE6 | 23.976 | avc1.640029 | 958 Segments | ~01h19m46s
    08:45:10.800 INFO : Vid *CENC 1280x720 | 2453 Kbps | mJeAHtMj | 23.976 | avc1.64001F | 958 Segments | ~01h19m46s
    08:45:10.801 INFO : Vid *CENC 852x480 | 1314 Kbps | k9ZRf7ZO | 23.976 | avc1.4D401E | 958 Segments | ~01h19m46s
    08:45:10.801 INFO : Vid *CENC 640x360 | 768 Kbps | Xkf2Ztxz | 23.976 | avc1.4D401E | 958 Segments | ~01h19m46s
    08:45:10.802 INFO : Vid *CENC 256x144 | 204 Kbps | ijCm99a6 | 23.976 | avc1.4D400C | 958 Segments | ~01h19m46s
    08:45:10.802 INFO : Vid 1600x720 | 32 Kbps | 3d2281ad-4cf1-4726-8787-8afdaa41625f/c8112ee8-7937-4e8c-b46e-aa501ce1f704 |
    08:45:10.802 INFO : Vid 720x324 | 16 Kbps | 3d2281ad-4cf1-4726-8787-8afdaa41625f/9e5d8fbd-e3b5-41b4-9ebb-ce12e52e7aa7 |
    08:45:10.803 INFO : Aud *CENC SVlkquIQ | 201 Kbps | mp4a.40.2 | 2CH | 959 Segments | ~01h19m46s
    08:45:13.075 INFO : Parsing streams...
    08:45:13.078 INFO : Selected streams:
    08:45:13.079 INFO : Vid *CENC 1920x1080 | 6004 Kbps | DCUP7KE6 | 23.976 | avc1.640029 | 958 Segments | ~01h19m46s
    08:45:13.079 INFO : Aud *CENC SVlkquIQ | 201 Kbps | mp4a.40.2 | 2CH | 959 Segments | ~01h19m46s
    08:45:13.080 WARN : Writing meta json
    08:45:13.083 INFO : Save Name: 10438103_2024-05-20_08-45-10
    08:45:13.084 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    08:45:13.085 INFO : Start downloading...Vid 1920x1080 | 6004 Kbps | DCUP7KE6 | 23.976 | avc1.640029
    08:45:13.157 WARN : Type: cenc
    08:45:13.158 WARN : PSSH(WV): CAESEOxHnYORfEIpi7hjA+aRGUkaC2J1eWRybWtleW9zIhAGkkjZ/4dHK7a20uBPAtnP
    08:45:13.158 WARN : KID: ec479d83917c42298bb86303e6911949
    08:45:13.159 WARN : Reading media info...
    08:45:13.484 INFO : [0x1]: Video, h264 (avc1), 1920x1080
    08:47:22.068 INFO : Binary merging...
    08:47:24.042 INFO : Decrypting...
    08:47:24.044 INFO : Start downloading...Aud SVlkquIQ | 201 Kbps | mp4a.40.2 | 2CH
    08:47:24.060 WARN : Type: cenc
    08:47:24.062 WARN : PSSH(WV): CAESEOxHnYORfEIpi7hjA+aRGUkaC2J1eWRybWtleW9zIhAGkkjZ/4dHK7a20uBPAtnP
    08:47:24.064 WARN : KID: ec479d83917c42298bb86303e6911949
    08:47:24.065 WARN : Reading media info...
    08:47:24.091 INFO : [0x2]: Audio, aac (mp4a)
    08:47:28.338 INFO : Binary merging...
    08:47:28.577 INFO : Decrypting...
    08:47:28.581 WARN : 10438103_2024-05-20_08-45-10.mp4
    08:47:28.581 WARN : 10438103_2024-05-20_08-45-10.m4a
    08:47:28.581 WARN : Muxing to 10438103_2024-05-20_08-45-10.MUX.mp4
    08:47:28.724 WARN : [h264 @ 0000022f26c05dc0] left block unavailable for requested intra4x4 mode -1
    08:47:28.725 WARN : [h264 @ 0000022f26c05dc0] error while decoding MB 0 11, bytestream 273
    08:47:28.891 WARN : [aac @ 0000022f26c05dc0] Number of scalefactor bands in group (15) exceeds limit (14).
    08:47:28.892 WARN : [mp4 @ 0000022f2717d8c0] track 1: codec frame size is not set
    08:47:28.909 WARN : [mp4 @ 0000022f2717d8c0] aac bitstream error
    08:47:31.929 WARN :     Last message repeated 66 times
    08:47:32.008 WARN : Cleaning files...
    08:47:32.273 WARN : Rename to 10438103_2024-05-20_08-45-10.mp4
    08:47:32.274 INFO : Done
  4. @+Constantine+
    Your command seems correct... but it looks like the key you're using for decryption is incorrect
    Try again to decrypt with key provided by @Shellcmd
    N_m3u8DL-RE "https://www.kanopy.com/kapi/manifests/dash/10438103.mpd" --key ec479d83917c42298bb86303e6911949:9eeb0fb0e0782ec620b6dee66c1c58a2 -M format=mp4
    And if it still not work then post video link here
    Mar 2024
    Poland
    [Attachment 79278 - Click to enlarge]
    N_m3u8DL-RE -M format=mp4 --key ec479d83917c42298bb86303e6911949:9eeb0fb0e0782ec620b6dee66c1c58a2  "https://www.kanopy.com/kapi/manifests/dash/10438103.mpd"
    The decryption keys are ok
  6. when you run download with RE you can see the kid:
    [Attachment 79280 - Click to enlarge]
    this is the kid, and this is from pssh into mpd. your RE command use another key (also wrong key, real key is kid+key 32+32 characters, your kid:key is totally wrong also for characters numbers)
    so your real key, as other users above say, it's the key provided by shellcmd
  7. Looks like someone's messing either with you, or the keys.
    Translates into..
    --key nosuchdevice....:readthef***ingmanual
  8. Originally Posted by pram0dm View Post
    Translates into..
    You have eagle eyes
  9. @+Constantine+
    You got the wrong keys because the Widevine L3 Guesser Extension does not have the challenge scheme for Kanopy using license server https://kcms.kanopy.com/api/v1/playback/widevine_license.
    Suggest that you create a .har file and upload to FoxRefire. He is very fast, efficient and always willing to help.
    Please read
    https://forum.videohelp.com/threads/414140-[Release]-Widevine-L3-Guesser-Extension-Works-in-2024-Firefox-Chrome-All-OS/page7#post2733414
    and visit
