Hey all,
I've recently acquired a Toshiba DVR620, and I cannot get a picture at all over HDMI. I can't find anything online related to this problem. There is an HDMI option in the unit's menu, but it's always greyed out.
My TV doesn't recognize it's connected over HDMI, just the analog outputs work. It's supposed to output DVD, VHS, and any other input over HDMI (which is why I wanted this unit) but none of it works over HDMI. The port itself is clean and nothing is visibly damaged.
I've tried different cables, I've tried routing it through my AVR, and I've tried my HDMI capture device on my PC. Nothing works.
Any ideas on what I could do to fix it?
Thanks!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I have read that, and the manual, but I still cannot get it to fully work.
I managed to get another similar Toshiba unit with a malfunctioning VCR portion, and swapped the DVD board containing the HDMI port into the other unit that I have. The HDMI port now works ... but only over DVD. I cannot get it to work over VHS still. -
The topic does mention that you do have to set the analog input (L1 or L2) - Reply #12. I assume you did try that with your un-modded unit.
As for the modded unit, I also refer you to my own reply, and others, in that topic. Typically, VHS is ony available over compostite. The DVR620 appears to be an exception rather than the rule. -
try this - shut both the TV and player down. Then disconnect the player from power. Disconnect the HDMI cable on both ends, then press and hold the power button on the Toshiba player itself for 10 seconds. Plug the HDMI cable back into the TV and the player. Plug the player back in and turn it on. Wait 10 seconds then turn the TV on and select the appropriate Source that you're plugged into.
or try doing a factory reset - https://www.manualslib.com/manual/838963/Toshiba-Dvr620ku.html?page=99
Question about video output for VCD/DVD combo (Toshiba DVR620)
By 12centuries in forum DVD & Blu-ray RecordersReplies: 12Last Post: 26th May 2024, 14:57 -
Toshiba DVR620KU VHS/DVD Combo Player-Recorder
By Gio99 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 6th Feb 2024, 15:50 -
Toshiba VCR's-any good than JVC HR-737MS?
By Idan1822 in forum MediaReplies: 2Last Post: 18th May 2023, 10:50 -
Capturing RGB output from DVD/VCR combo
By Hackerpcs in forum Capturing and VCRReplies: 37Last Post: 23rd Nov 2021, 03:59 -
Toshiba VRC/DVD combo player E25...
By help65 in forum DVD & Blu-ray WritersReplies: 1Last Post: 10th Apr 2021, 02:26
