I am using yt-dlp in order to download videos from SVT-Play for later viewing.
But when I do that I do not get the subtitles that appear when playing the video directly on a web browser from the site.
Specifically I have a script running on an Ubuntu 20.04.4 LTS server using yt-dlp and it uses two steps to download:
1) Check the available streams to select the wanted resolution
Here I use the following to list all of the contained streams:
2) Run the download itself to get the video at the wanted resolution with embedded audioCode:yt-dlp -F $VIDEOURL
It uses the syntax:
Snippet from the script:Code:getvideo <output filename> <video URL> <video quality>
Note that the $QUALITY variable holds 2 different parts for video and audio quality separated by + like this:Code:COMMAND="yt-dlp -f $QUALITY -o $TARGETFILE $VIDEOURL" ... eval "$COMMAND"
I just discovered that a video file downloaded like this does not display the subtitles the same way as the video does when played in the browser...Code:hls-1557+hls-AAC-190-2ch-Svenska
Specifically the browser played video switches on subtitles when a person on screen talks in a different language than Swedish, but this is not present in the videos downloaded using the command above.
Most videos I download have English as the foreign language and then I don't notice the lack of the subtitles, but now I encountered a video with French as the foreign language and then I cannot understand the video display...
So I would like to know if it is possible and then how to get the foreign language subtitles added to the output video?
EDIT:
I forgot to say that adding the argument --write-subs to the command only results in a text file with the subtitles being downloaded. When viewing the video with that file present (named as the video but with extension sv.svt) the subtitles appear if the video is locally played with the VLC player but NOT if opened using a browser!
So the video mp4 file itself is unaffected and therefore the text is not visible in a browser.
My question is how to ensure the subtitles are embedded in the mp4 video itself?
Results 1 to 10 of 10
I'm using Windows 10, so your method will be slightly different.
yt-dlp.conf (This is stored in the same directory as yt-dlp.exe)
I also have copies of ffmpeg.exe & ffprobe.exe in the same directory.This is a copied, modified & pasted command line to add the subs. It's wrapped up in a batch file. I end up with an mkv.Code:# Start a line with a hash(#) to comment it out. # __________________________________________________________ # Suppress HTTPS certificate validation --no-check-certificate # Prefer ffmpeg over avconv for postprocessing --prefer-ffmpeg #Write subtitles - order of preference --write-sub --sub-format srt/vtt/best --sub-langs en # Convert the subtitles to another format - if needed. --convert-subs srt #Keep the original subs -k --merge-output-format mp4
Code:ffmpeg.exe" -i "thevideo.mp4" -sub_charenc ISO-8859-1 -i "thevideo.srt" -map 0:0 -map 0:1 -map 1:0 -c:v copy -c:a copy -c:s copy -disposition forced "thevideo.mkv"
I am not familiar with using the yt-dlp conf file and it seems like it would affect ALL downloads made using yt-dlp, right?
Cannot find it in my Ubuntu server installation, at least not if it is named yt-dlp.conf...
Do I understand this procedure correctly as follows:
1) Download the video using settings in the conf file (they are global, right?)
This will bring down both the video (as an mkv file) and the subtitles (as an srt file)
2) Run ffmpeg towards the downloaded video file to embed the subtitles into it by re-encoding the whole thing.
This ends up again with an mkv file whereas I need mp4 video files for further use.
I have already tried various ffmpeg commands to embed the subtitles but invariably that results in a very lengthy procedure taking like 30 minutes for a 60 minute video.
I was hoping for some way to do it during the download since the video when viewed on-line actually contains the subtitles when people on screen talk in a different language than Swedish (the main language of the video).
I could not understand why the subtitles were not present when I downloaded the video to disk for later viewing.
I assumed I had missed some argument to yt-dlp... -
Hello:
- To download your mp4 video file via yt-dlp please use instructions on https://github.com/mrblomblo/yt-dlp-usage-script?tab=readme-ov-file
- For the config file you can create a new text file in EXE folder, name it yt-dlp.conf and insert the code given by 12pcspeak. You might want to modify the language of the subtitles you need (--sub-langs en).
- To download the subtitles in srt format, use the following code in the command line of EXE folder: Code:
yt-dlp.exe --write-subs --skip-download -N 8 your video file html link
- You can merge your video and the subtitles into one mkv video file using the following code: Code:
As I stated above my setup is a set of bash scripts running on an Ubuntu 20.04.4 LTS server...
So any instructions pertaining to Windows are not valid here.
The linked instructions on GitHub also referenced a Windows solution.
And I am looking for a system where the encoding is done during download so as not to waste extra time for a re-make of the entire file. -
Hi, I'm trying do download subtitles only from this link:
https://mediasetinfinity.mediaset.it/movie/intothestorm/into-the-storm_F306166301000102
Using this command I found ita and eng subs in srt and vtt formats:
yt-dlp_x86 --list-subs https://mediasetinfinity.mediaset.it/movie/intothestorm/into-the-storm_F306166301000102
But I can't find the correct command line to download them.
Please can you suggest me the correct command line.
Thank you -
I use this when I download using yt-dlp (not so often because I usually use the underlying ffmpeg directly):
Where:Code:COMMAND="yt-dlp -f $QUALITY $SUBTITLEFLAG -o $TARGETFILE $VIDEOURL"
$QUALITY = whatever code yt-dlp -F URL will list if you check the video, like '135+140' (for separate video and audio streams)
$SUBTITLEFLAG = empty or "--write-subs" or "--embed-subs"
$TARGETFILE = the output mp4 file name
$VIDEOURL = the Internet URL to the video
Regarding the subtitles I have found that it is difficult to get them embedded as subtitles in the video so I use the write-subs instead, which results in a file with extension srt is created containing the text of the subtitles.
It used to work fine many years ago but lately when I have tried to get the subtitles it has not been easy.
If you find a good solution please post it here. -
I joined the site just to Reply here,
I don't know and haven't tried embedding subtitles during download, personally I prefer the separate SRT file, as it's a text file I can edit and correct if I choose, and every player supports it these days (I primarily use VLC, but I've seen others). Thanks for the tip of setting the stream as 251+136, I've been doing that separately, downloading the files separately and combining them myself! (two downloads then one combine command).
You can do this in two steps (or I can, rather, LOL!), download then embed. Note that they're still optional subtitles you have to turn on - it sounds like you want burnt-in (I've never put any effort into learning how to do this as it's such a bad idea, too permanent and unnecessary) - but they'll be available wherever the video is, and every modern player I've seen supports this. I have a new MP3 player which CAN play SRT files, but it works smoother if it's an embedded stream in the MP4 file, so I've been incorporating the subtitles as an optional subtitle stream lately. I carefully created commands for all the tasks I do with YT-DLP and FFMPEG then saved them into DOS Batch files to make it simpler/easier. Having used Ubuntu in the past, I'm certain you can just run the same commands, just adjusted accordingly. My Batch files are robust, but the actual commands are these:
Get a video with separate SRT subtitle file:
...where %1 is the first parameter I send to the batch file, the format to download (251, 136, etc), 2nd is the URL (note I've had some downloads complain about not being able to do things, particularly with converting to SRT format, because of not knowing where FFMPEG is, that's why the --ffmpeg-location. Obviously adjust to your system).Code:yt-dlp.exe -i -o "%%(title)s-%%(format)s.%%(ext)s" --format %1 --ignore-config --write-sub --sub-lang "en.*" --convert-subs srt --ffmpeg-location "C:\Apps\FFmpeg-3.3.3\bin" --hls-prefer-native --abort-on-unavailable-fragment --no-mtime -c "%2"
Add a subtitle file to an MP4:
1st parameter is the original MP4, 2nd is the SRT subtitle file, 3rd is the target filename). If there are Unicode characters (I'm always doing music videos, so I commonly have music notes) this will give an error, so change cp1252 to UTF-8.Code:ffmpeg -i %1 -sub_charenc cp1252 -i %2 -c copy -c:s mov_text -metadata:s:s:0 language=eng %3
I also have the reverse, create an SRT from a subtitle track:
1st is the MP4/MKV, 2nd is the SRT file to create. Again, if there's Unicode I add "-sub_charenc UTF-8" after the %1, but this has been if-fy, some videos I have trouble finding a character encoding that doesn't complain (default might complain about finding UTF-8 characters, but when I use UTF-8 it complains that's not the right encoding and doesn't create a file at all).Code:ffmpeg -i %1 -map 0:s:0 %2
What I've been using to combine the audio and video files:
1st is the video filename, 2nd is the audio filename, 3rd is the target filename (the filename of the final combined result).Code:ffmpeg -i %1 -i %2 -c:v copy -c:a aac -map 0:v:0 -map 1:a:0 %3
As a matter of interest, sometimes I like an MP3 of the music video (since the highest quality audio always downloads as WEBM):
1st is the WEBM, 2nd is the MP3 to create.Code:ffmpeg -i %1 -vn -ar 44100 -ac 2 -b:a 128k %2
I hate MKVs, so this repackages MKV as an MP4:
1st is the MKV, 2nd is the target MP4, 3rd is the subtitle track (0, 1, 2) to copy. Omit from "map 0:a:0" until but keeping %2 to skip subtitles.Code:ffmpeg -i %1 -vcodec copy -map 0:v:0 -acodec copy -map 0:a:0 -map 0:s:%3 -c:s mov_text -metadata:s:s:0 language=eng %2
I actually found this thread because of Googling my problem, my downloading a subtitle is failing even though there is one (and not the useless auto-generated one). "en.*" isn't working, it says it finds no data (even though the subtitle works on YouTube), I tried "en*" and "English" - since YouTube CALLS it "English" - but still nothing, so I'm looking for something like "yt-dlp.exe -F %1" but to list available subtitles/streams. (I've seen a command, probably FFMPEG, that lists all streams embedded in an MP4 or MKV, I want that for a URL), to see if I can find out what that subtitle is named.
i'm downloading a video via m3u8 with yt-dlp
By nammin in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jul 2023, 01:21 -
Downloading a movie from YouTube with yt-dlp
By CrymanChen in forum Video Streaming DownloadingReplies: 0Last Post: 17th Jun 2023, 05:14 -
problem downloading audio format with yt-dlp
By thedebutent59 in forum Video Streaming DownloadingReplies: 1Last Post: 6th Oct 2022, 12:36 -
downloading multiple audio track with yt-dlp
By chisdchisdq in forum Video Streaming DownloadingReplies: 2Last Post: 17th Apr 2022, 05:16 -
Recording and Downloading issues with yt-dlp
By Alan2154 in forum Video Streaming DownloadingReplies: 12Last Post: 9th Nov 2021, 08:38
