I have bought a few films now on VCD. Only one will play on my LG DVD-4210 player, which has had the hack for vcd put in. I have checked the directories on the discs but can't see any major differences. Can anyone point me in the right direction and can I re-burn the discs so that they do play, sample film directories are below:
Film 1 (This one plays)
CDI- empty
EXT-
LOT_X.VCD;1 64K
PSD_X.VCD;1 24
MPEGAV
AVSEQ01.DAT;1 402,964K
SEGMENT- empty
VCD-
ENTRIES.VCD;1 2,048K
INFO.VCD;1 2,048K
LOT.VCD;1 64K
PSD.VCD;1 24K
Film 2 (Doesn't play)
EXT- empty
MPEGAV-
AVSEQ01.DAT;1 379,058K
VCD-
INFO.VCD;1 2,048K
Film 3 (Doesn't play)
CDI- empty
EXT-
LOT_X.VCD;1 64K
PSD_X.VCD;1 40
MPEGAV-
AVSEQ01.DAT;1 6,826K
AVSEQ02.DAT;1 489,898K
SEGMENT- empty
VCD-
INFO.VCD;1 2,048K
LOT.VCD;1 64K
PSD.VCD;1 40K
could be other VCD not standard compliant...
wut you can do is copy the AVSEQ01.DAT file onto your computer....then you can use nero's VCD template to make a VCD out of it...after nero scans the .dat file, if it asks you to turn standard compliance off, then it prolly won't be able to play on your DVD player...
if this is the case, then you can use VCDgear to burn the .dat file into a proper .mpg file (strips away the extra info and headers that VCDs put in front of .mpg file to turn into .dat file)
on the other hand, if you can reburn the AVSEQ01.DAT file w/ nero's VCD template AS A STANDARD COMPLIANT VCD, then there shouldn't be a problem for your dvd player to play it
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 19:14 -
Sony +R Differences
By Madz in forum MediaReplies: 4Last Post: 31st Dec 2011, 03:46 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
Player Differences
By Xandal in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 15:43
