I just bought a Blu-ray, and I'm disappointed to see almost 2 minutes of ads before the film. What program(s) allow me to demux the BDMV, remove the parts I don't like (while keeping the menu's) and re-author it, so I can burn it to a disk?
Thanks in advance.
I've got YouTube in my frickin' veins thats SiS sos !!
I would recommend three free apps for this. MakeMKV (you can pull the beta key off their forums), BD Rebuilder (pull up the Doom9 site and it links you to the pre-requisite softwares you need installed for it to run) and Imgburn.
Rip with MakeMKV, import into BD Rebuilder (and select a movie-only backup) and Imgburn to burn to a BD-R. -
Can't you skip the ads?
I just asked you if you can skip the ads,if you can't then by all mean re-auther.
Adding/Replacing Subtitles and Videos to a Ripped BDMV
By Hardback247 in forum Authoring (Blu-ray)Replies: 33Last Post: 1st Apr 2024, 16:06 -
BDMV Folder Tweaks
By the associate in forum Authoring (Blu-ray)Replies: 1Last Post: 16th Jan 2021, 10:33 -
Impossible to play BDMV Folder
By abel413 in forum Authoring (Blu-ray)Replies: 17Last Post: 11th Jan 2020, 21:32 -
Erase Contents on BDMV folder on HDD and Paste from another BDMV folder
By maczones in forum Authoring (Blu-ray)Replies: 4Last Post: 27th May 2019, 11:10 -
Adding subtitles to BDMV-Certification Blu-Rays
By DPantigoso in forum Authoring (Blu-ray)Replies: 15Last Post: 23rd May 2019, 22:59
