Results 1 to 18 of 18
  1. Since when raiplay started to block access to .mp4 files in their sites (about three months ago; when they were accessible I downloaded videos directly to avoid the harassment of reconstructing .mp4 files from .m3u8) I've been experimenting with several programs in order to download from manifest. I've noticed a strange fact: with yt-dlp, youtube-dl, ffmpeg and so on there is no problem, anyway I cannot make N_m3u8DL-RE working. I'm curious why, as I like to use this software. As an example, please look at the following video https://www.raiplay.it/video/2022/10/Flesh-and-Blood-S1E1----164d288a-5fcd-4024-997d-f...e732705ab.html, which inspecting gives https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_.../playlist.m3u8. The N_m3u8DL-RE log is the following
    N_m3u8DL-RE -M format=mp4 "https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_root/SUBTITLE_multiaudio/AvcnG04SYgtYaFSOUT4TBweeqqEEqualeeqqEEqual_,1200,1800,2400/playlist.m3u8" --tmp-dir t:\ --save-dir t:\ --save-name "fleshblood"
    20:27:34.518 INFO : N_m3u8DL-RE (Beta version) 20230615
    20:27:34.577 INFO : Loading URL: https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_root/SUBTITLE_multiaudio/AvcnG04SYgtYaFSOUT4TBweeqqEEqualeeqqEEqual_,1200,1800,2400/playlist.m3u8
    20:27:35.425 INFO : New version detected! v0.2.0-beta
    20:27:36.543 INFO : Content Matched: HTTP Live Streaming
    20:27:36.545 INFO : Parsing streams...
    20:27:36.547 WARN : Master List detected, try parse all streams
    20:27:36.555 WARN : Writing meta json
    20:27:36.564 INFO : Extracted, there are 6 streams, with 3 basic streams, 3 audio streams, 0 subtitle streams
    20:27:36.565 INFO : Vid 1280x720 | 2344 Kbps
    20:27:36.566 INFO : Vid 1024x576 | 1758 Kbps
    20:27:36.567 INFO : Vid 768x432 | 1288 Kbps
    20:27:36.567 INFO : Aud aac | Italiano | Italiano
    20:27:36.568 INFO : Aud aac | Audiodescrizione | Audiodescrizione
    20:27:36.569 INFO : Aud aac | VO | VO
    20:28:03.061 INFO : Parsing streams...
    20:28:04.840 INFO : Selected streams:
    20:28:04.841 INFO : Vid 1280x720 | 2344 Kbps | 277 Segments | ~46m10s
    20:28:04.842 INFO : Aud aac | Italiano | Italiano | 277 Segments | ~46m09s
    20:28:04.843 INFO : Aud aac | Audiodescrizione | Audiodescrizione | 277 Segments | ~46m09s
    20:28:04.844 INFO : Aud aac | VO | VO | 277 Segments | ~46m09s
    20:28:04.845 WARN : Writing meta json
    20:28:04.868 INFO : Save Name: fleshblood
    20:28:04.872 INFO : Start downloading...Vid 1280x720 | 2344 Kbps
    20:28:19.987 WARN : Reading media info...
    20:28:21.332 INFO : [0x102]: Data, timed_id3 (ID3 )
    20:28:21.340 INFO : [0x100]: Video, h264 (Main) ([27][0][0][0]), 1280x720, 25 fps
    21:22:06.122 INFO : ffmpeg merging...
    21:22:07.457 WARN : [mpegts @ 000002593a0db880] start time for stream 0 is not set in estimate_timings_from_pts
    21:23:13.699 INFO : Start downloading...Aud aac | Italiano | Italiano
    21:23:16.249 WARN : Reading media info...
    21:23:16.671 INFO : NaN: Audio, aac (LC), 116 kb/s
    21:25:08.632 INFO : ffmpeg merging...
    21:25:08.976 WARN : [aac @ 0000021cefa4a440] Estimating duration from bitrate, this may be inaccurate
    21:25:11.702 INFO : Start downloading...Aud aac | Audiodescrizione | Audiodescrizione
    21:25:12.750 WARN : Reading media info...
    21:25:12.834 INFO : NaN: Audio, aac (LC), 115 kb/s
    21:26:52.962 INFO : ffmpeg merging...
    21:26:53.284 WARN : [aac @ 0000019f570aa440] Estimating duration from bitrate, this may be inaccurate
    21:26:56.126 INFO : Start downloading...Aud aac | VO | VO
    21:26:56.731 WARN : Reading media info...
    21:26:56.802 INFO : NaN: Audio, aac (LC), 122 kb/s
    21:28:46.468 INFO : ffmpeg merging...
    21:28:46.834 WARN : [aac @ 000001dc7ea6b440] Estimating duration from bitrate, this may be inaccurate
    21:29:00.838 WARN : fleshblood.mp4
    21:29:00.840 WARN : fleshblood.Italiano.m4a
    21:29:00.842 WARN : fleshblood.Audiodescrizione.m4a
    21:29:00.843 WARN : fleshblood.VO.m4a
    21:29:00.844 WARN : Muxing to t:\fleshblood.MUX.mp4
    21:29:02.150 WARN : Stream map '0:1' matches no streams.
    21:29:02.152 WARN : To ignore this, add a trailing '?' to the map.
    21:29:02.160 ERROR: Mux failed
    21:29:02.161 ERROR: Failed
    Another thing: subtitles are present (.srt format), anyway N_m3u8DL-RE doesn't recognize them.
    What do you think about it, my friends? Thank you very, very much, in advance, for all kind help and explanations. Have a great evening
  2. try -M format=mkv:muxer=mkvmerge
    (need to have mkvmerge on same folder with RE)
    also: from your m3u8 link no subs are present (vtt) so need to download, then add manually with mkvmerge
  3. Using the same folder for both the temp and the save folder doesn't seem the smartest of moves though:
    It's possible that files get deleted before the muxing process starts, hence a possible reason why it fails. I had no problems downloading and muxing with the following command (the m3u8 url below will let you grab up to 1080p btw):
    N_m3u8DL-RE -M format=mp4 "https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_root/SUBTITLE_multiaudio/AvcnG04SYgtYaFSOUT4TBweeqqEEqualeeqqEEqual_,1200,1800,2400,3600,5000/playlist.m3u8"
    For subtitles you might want to use the --mux-import switch (if you know already have the subtitle file) to do everything in one go.
  4. Member aqzs's Avatar
    Mar 2024
    Paris
    Thanks for letting me discover --mux-import arg which could be useful in the future !
  5. Originally Posted by white_snake View Post
    Thank you so very much for advice and help. I've changed the Temp dir and I've left only the save dir on external hd, but unfortunately I still get an error. Please see the log
    N_m3u8DL-RE020 -M format=mp4 "https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_root/SUBTITLE_multiaudio/AvcnG04SYgtYaFSOUT4TBweeqqEEqualeeqqEEqual_,1200,1800,2400/playlist.m3u8" --save-dir t:\ --save-name "fleshblood_2"
    20:17:42.540 INFO : N_m3u8DL-RE (Beta version) 20230628
    20:17:42.631 INFO : Loading URL: https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_root/SUBTITLE_multiaudio/AvcnG04SYgtYaFSOUT4TBweeqqEEqualeeqqEEqual_,1200,1800,2400/playlist.m3u8
    20:17:43.849 INFO : Content Matched: HTTP Live Streaming
    20:17:43.902 INFO : Parsing streams...
    20:17:43.904 WARN : Master List detected, try parse all streams
    20:17:43.913 WARN : Writing meta json
    20:17:43.923 INFO : Extracted, there are 6 streams, with 3 basic streams, 3 audio streams, 0 subtitle streams
    20:17:43.925 INFO : Vid 1280x720 | 2344 Kbps
    20:17:43.926 INFO : Vid 1024x576 | 1758 Kbps
    20:17:43.928 INFO : Vid 768x432 | 1288 Kbps
    20:17:43.947 INFO : Aud aac | Italiano | Italiano
    20:17:43.948 INFO : Aud aac | Audiodescrizione | Audiodescrizione
    20:17:43.950 INFO : Aud aac | VO | VO
    20:17:54.023 INFO : Parsing streams...
    20:17:55.947 INFO : Selected streams:
    20:17:55.949 INFO : Vid 1280x720 | 2344 Kbps | 277 Segments | ~46m10s
    20:17:55.951 INFO : Aud aac | Italiano | Italiano | 277 Segments | ~46m09s
    20:17:55.952 INFO : Aud aac | Audiodescrizione | Audiodescrizione | 277 Segments | ~46m09s
    20:17:55.952 INFO : Aud aac | VO | VO | 277 Segments | ~46m09s
    20:17:55.953 WARN : Writing meta json
    20:17:55.967 INFO : Save Name: fleshblood_2
    20:17:55.968 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    20:17:55.969 INFO : Start downloading...Vid 1280x720 | 2344 Kbps
    20:18:00.905 WARN : Reading media info...
    20:18:02.440 INFO : [0x102]: Data, timed_id3 (ID3 )
    20:18:02.447 INFO : [0x100]: Video, h264 (Main) ([27][0][0][0]), 1280x720, 25 fps
    20:23:13.523 INFO : Binary merging...
    20:24:06.404 INFO : Start downloading...Aud aac | Italiano | Italiano
    20:24:08.662 WARN : Reading media info...
    20:24:09.055 INFO : NaN: Audio, aac (LC), 116 kb/s
    20:24:31.072 INFO : Binary merging...
    20:24:35.315 INFO : Start downloading...Aud aac | Audiodescrizione | Audiodescrizione
    20:24:35.553 WARN : Reading media info...
    20:24:35.730 INFO : NaN: Audio, aac (LC), 115 kb/s
    20:24:55.891 INFO : Binary merging...
    20:25:06.480 INFO : Start downloading...Aud aac | VO | VO
    20:25:06.715 WARN : Reading media info...
    20:25:06.805 INFO : NaN: Audio, aac (LC), 122 kb/s
    20:25:26.842 INFO : Binary merging...
    20:25:30.789 WARN : fleshblood_2.ts
    20:25:30.790 WARN : fleshblood_2.Italiano.ts
    20:25:30.792 WARN : fleshblood_2.Audiodescrizione.ts
    20:25:30.793 WARN : fleshblood_2.VO.ts
    20:25:30.794 WARN : Muxing to fleshblood_2.MUX.mp4
    20:25:31.178 WARN : [mpegts @ 0000018ff5c4b740] start time for stream 0 is not set in estimate_timings_from_pts
    20:25:31.187 WARN : [aac @ 0000018ff6060700] Estimating duration from bitrate, this may be inaccurate
    20:25:31.214 WARN : [aac @ 0000018ff5c89080] Estimating duration from bitrate, this may be inaccurate
    20:25:31.231 WARN : [aac @ 0000018ff625da80] Estimating duration from bitrate, this may be inaccurate
    20:25:31.304 WARN : [mp4 @ 0000018ff63dcc80] Could not find tag for codec timed_id3 in stream #0, codec not currently
    supported in container
    20:25:31.309 WARN : Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
    20:25:31.323 ERROR: Mux failed
    20:25:31.324 ERROR: Failed
    What do you think? Thanks, again, for all your help and efforts. Have a great evening
  6. The subtitles are outside the playlist, which is why they are not found. To find them easily, just install an extension to better format the JSON in the browser like this one for chrome https://chromewebstore.google.com/detail/json-formatter/bcjindcccaagfpapjjmafapmmgkkhgoa
    and then replace the .html with .json at the video link
    https://www.raiplay.it/video/2022/10/Flesh-and-Blood-S1E1----164d288a-5fcd-4024-997d-f70e732705ab.json
    copy it in the browser, scroll down the page
    right-click on the link and
    save as
    The MUX fails simply because unfortunately Raiplay has recently made changes, and whatever you download has the same extension .ts, so whatever program you use to mux with N_m3u8DL-RE will always make an error because it won't shoot which is the video and which is the audio, you will have to mux it yourself with another program, I recommend MKVToolNix GUI, or rename the file extensions to mp4 for the video and aac for the audio and mux them with the command line with ffmpeg. Sometimes audio and video are in one .mp4 file. Rarely the audio has to be corrected with a delay of +200ms.
  7. Member aqzs's Avatar
    Mar 2024
    Paris
    save as
    I suggest muxing with mkvmerge since it doesn't re encode everything
  8. Originally Posted by misiek1963 View Post
    The command I wrote above works perfectly for me, run the same exact command and see what happens (I can see from your log you didn't since it loaded the 720p m3u8). If it doesn't work, you probably need to update your ffmpeg binaries.
  9. Originally Posted by white_snake View Post
    Thank you very much for answer and all your efforts to help, I've used literally your command with the last version of N_m3u8DL-RE and last binaries of ffmpeg, but the problem is still present. Please see the log
    18:51:52.423 WARN : fleshbloodult.ts
    18:51:52.434 WARN : fleshbloodult.Italiano.ts
    18:51:52.436 WARN : fleshbloodult.Audiodescrizione.ts
    18:51:52.437 WARN : fleshbloodult.VO.ts
    18:51:52.439 WARN : Muxing to fleshbloodult.MUX.mp4
    18:51:52.906 WARN : [mpegts @ 00000205bba8bf40] start time for stream 0 is not set in estimate_timings_from_pts
    18:51:52.978 WARN : [aac @ 00000205bba94840] Estimating duration from bitrate, this may be inaccurate
    18:51:52.981 WARN : [aac @ 00000205bc2b00c0] Estimating duration from bitrate, this may be inaccurate
    18:51:52.984 WARN : [aac @ 00000205bba91180] Estimating duration from bitrate, this may be inaccurate
    18:51:53.213 WARN : [mp4 @ 00000205bba92fc0] Could not find tag for codec timed_id3 in stream #0, codec not currently
    18:51:53.253 WARN : Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
    18:51:53.291 ERROR: Mux failed
    18:51:53.295 ERROR: Failed
    I really don't know what to do...
  10. yt-dlp support raiplay (and your EP on 1080p)
    so run yt-dlp video_link
  11. Originally Posted by misiek1963 View Post
    As lomero said, since this is not a DRM-protected video, yt-dlp is definitely the best way to go here. Anyway, if you still want to solve the issue (as in the future you might need to do this with a protected video), I suggest you specifically use the N_m3u8DL-RE binary from here and the ffmpeg binary from here.
    If that still doesn't fix it, then there must be something wrong with your system configuration (possibly cmd is using a different ffmpeg build somewhere else in your system). At that point you can either investigate the issue (run: `where ffmpeg`) or use a different muxer like mkvmerge:
  12. Originally Posted by white_snake View Post
    Thank you, thank you so very much for all precious help and advice. I took the binaries from links you gave me and, to be sure to use the right ffmpeg I used the command --ffmpeg-binary-path to pick up the last version. No need to say now everything worked! Thanks, again, for all your kind help. Did you get the following warnings, too?
    17:37:52.213 WARN : [mpegts @ 000001fa5a69c040] start time for stream 0 is not set in estimate_timings_from_pts
    17:37:52.226 WARN : [aac @ 000001fa5ab10500] Estimating duration from bitrate, this may be inaccurate
    17:37:52.230 WARN : [aac @ 000001fa5a6de300] Estimating duration from bitrate, this may be inaccurate
    17:37:52.233 WARN : [aac @ 000001fa5b31e140] Estimating duration from bitrate, this may be inaccurate
    Is it your log similar to mine?
    17:18:27.035 INFO : N_m3u8DL-RE (Beta version) 20231113
    17:18:27.201 INFO : Loading URL: https://streamcdnr7-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/teche_root/SUBTITLE_multiaudio/AvcnG04SYgtYaFSOUT4TBweeqqEEqualeeqqEEqual_,1200,1800,2400,3600,5000/playlist.m3u8
    17:18:28.669 INFO : Content Matched: HTTP Live Streaming
    17:18:28.703 INFO : Parsing streams...
    17:18:28.706 WARN : Master List detected, try parse all streams
    17:18:28.716 WARN : Writing meta json
    17:18:28.725 INFO : Extracted, there are 7 streams, with 4 basic streams, 3 audio streams, 0 subtitle streams
    17:18:28.728 INFO : Vid 1920x1080 | 5210 Kbps
    17:18:28.733 INFO : Vid 1440x810 | 3516 Kbps
    17:18:28.736 INFO : Vid 1280x720 | 2344 Kbps
    17:18:28.770 INFO : Vid 1024x576 | 1758 Kbps
    17:18:28.776 INFO : Aud aac | Italiano | Italiano
    17:18:28.777 INFO : Aud aac | Audiodescrizione | Audiodescrizione
    17:18:28.779 INFO : Aud aac | VO | VO
    17:18:39.542 INFO : Parsing streams...
    17:18:40.964 INFO : Selected streams:
    17:18:40.968 INFO : Vid 1920x1080 | 5210 Kbps | 277 Segments | ~46m10s
    17:18:40.974 INFO : Aud aac | Italiano | Italiano | 277 Segments | ~46m09s
    17:18:40.977 INFO : Aud aac | Audiodescrizione | Audiodescrizione | 277 Segments | ~46m09s
    17:18:40.979 INFO : Aud aac | VO | VO | 277 Segments | ~46m09s
    17:18:40.981 WARN : Writing meta json
    17:18:41.008 INFO : Save Name: fleshbloodult_2
    17:18:41.010 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    17:18:41.014 INFO : Start downloading...Vid 1920x1080 | 5210 Kbps
    17:18:45.430 WARN : Reading media info...
    17:18:45.545 INFO : [0x102]: Data, timed_id3 (ID3 )
    17:18:45.549 INFO : [0x100]: Video, h264 (High) ([27][0][0][0]), 1920x1080, 25 fps
    17:33:17.820 INFO : Binary merging...
    17:36:14.144 INFO : Start downloading...Aud aac | Italiano | Italiano
    17:36:16.219 WARN : Reading media info...
    17:36:20.488 INFO : NaN: Audio, aac (LC), 116 kb/s
    17:36:52.714 INFO : Binary merging...
    17:36:55.242 INFO : Start downloading...Aud aac | Audiodescrizione | Audiodescrizione
    17:36:55.566 WARN : Reading media info...
    17:36:55.667 INFO : NaN: Audio, aac (LC), 115 kb/s
    17:37:21.039 INFO : Binary merging...
    17:37:23.458 INFO : Start downloading...Aud aac | VO | VO
    17:37:23.842 WARN : Reading media info...
    17:37:23.918 INFO : NaN: Audio, aac (LC), 122 kb/s
    17:37:48.913 INFO : Binary merging...
    17:37:51.436 WARN : fleshbloodult_2.ts
    17:37:51.439 WARN : fleshbloodult_2.Italiano.ts
    17:37:51.441 WARN : fleshbloodult_2.Audiodescrizione.ts
    17:37:51.443 WARN : fleshbloodult_2.VO.ts
    17:37:51.445 WARN : Muxing to fleshbloodult_2.MUX.mp4
    17:40:32.384 WARN : Cleaning files...
    17:40:32.505 WARN : Rename to fleshbloodult_2.mp4
    17:40:32.562 INFO : Done
    Anyway you and lomero are right in saying it's better to use yt-dlp, it's simpler, really.
    As for encrypted streams, I've tested and there's no problem, in such case the manifest is in .mpd form and N_m3u8DL-RE worked. Have a great evening
  13. yes, sometimes you get this error with ffmpeg, but isn't a problem
    and i can see you have your final video file now, right ?
    another way, i can repeat, try with yt-dlp link
  14. Originally Posted by lomero View Post
    Yes, I do. And you're right, better using yt-dlp
  15. better and more easy to do. no need m3u8 or mpd. for video with no encryption, and easy site like yours, is a better way
    also yt-dlp have a fixup feature to clean your final video
  16. Originally Posted by misiek1963 View Post
    You're welcome, glad you got it working.
    Yes, I do get the same exact error (that's from ffmpeg), but it can be just ignored.
  17. good evening, can anyone help me with this link? https://www.raiplay.it/video/2017/10/Sotto-copertura-La-cattura-di-Zagaria-S2E1-1cbd0e...339f7028e.html
    there seems to be only an SD resolution, but I think there is something to unlock also because if I watch it on the TV the Rai HD symbol appears.
    Doesn't this link indicate full HD, 5000 resolution?
    https://ma688-r.analytics.edgekey.net/9.gif?a=C~b=c9b625d8154de20535~c=9c4efdb1-1c2e-4...-43743863618e~ e=3~g=0~w=24230~ac=7743945.mp4/playlist.m3u8~ag=www.raiplay.it~ah=www.raiplay.it~ al=Windows~am=HLS~at=Firefox% 20126~aw=https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/dom2/Italy/podcastcdn/Fiction/RaiUno/Sotto_copertura/7743945.mp4/playlist.m3u8?auth=daEd5d4cjbCbRc_cNdNbUbS cEcQcQa5bSa0-bMtH1w-c0-HmxwAFv&aifp=V001~ax=O~ ay=CoreLibrary-4.20.28:JSLoader-1.6.8:THEOplayerLoader-1.1.5~bb=~dx=16.241~en=7743945.mp4/playlist.m3u8~os=Windows-10~sa=Desktop~tt=7743945 .mp4/playlist.m3u8~m=E~v=5000~aa=b70cb04c54ab478189e9d8 ee45637b13.msvdn.net~ap=2978~aq=3562000~cl=3562.99 ~gb=~ta=0~tb=0~td=0~ te=0~tf=0~tx=1125~ty=5000~tz=0~xa=Browser.Close~m= E~u=~v=5000~x=1125~y=5000~z=0~aa =b70cb04c54ab478189e9d8ee45637b13.msvdn.net~ap=297 8~aq=3562000~cl=3562.99~da=0~dc=~dd=1~de=19392~dg= 0~dh=0~fb=0~fd=0~ fe=0~fi=~fk=U:1125,S:0,Q:0,D:0~fl=-~gb=~rs=
  18. 720x404 only
