Hope any of you can help with this.
I'm trying to figure out how to edit a double text in one line. Here's an example;
-I feel stuck.<br/>-I am not a joy boy.<br/>-I feel stuck.<br/>-I am not a joy boy.
I tried both tools using Merge lines with same time codes and Merge lines with same text. Obviously it doesn't work because it's one line. Which tool I can use to fix?
Thx.
Can you attach the whole file? I want to try something and one line is not enough.
Move text after line break to the next susbtitle
By maser478 in forum SubtitleReplies: 2Last Post: 2nd Aug 2023, 08:29 -
Convert Timed Text subtitles to ASS with text positions?
By Hakunamatata67 in forum SubtitleReplies: 0Last Post: 3rd Feb 2022, 02:08 -
Divide each line of text into new subtitle line
By martanius in forum SubtitleReplies: 1Last Post: 11th Apr 2021, 16:21 -
overlay some text with a black background/white text over one small section
By devdev in forum EditingReplies: 0Last Post: 16th Dec 2020, 12:27 -
How to add a new line with same text to multiple subtitle at once?
By zyck in forum SubtitleReplies: 7Last Post: 19th Apr 2020, 08:01
