They changed something regarding tokens. Will take a look and will be fixed in the next version. Thanks for reporting the problem.
Results 241 to 270 of 533
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
For me it works fine. Give the URL you're having problems with.
The last time I downloaded anything through Widefrog was about 2 months ago. This is the first and only URL I tried, after which I came here to check if there was maybe a new version available for the tool. I have not checked whether it is working fine for other URL's.
Works fine for me. Make sure you're using the latest version.
Code:python widefrog.py "https://eurovisionsport.com/mediacard/EVS_240504_F_20240501EGRimini_12" [INFO] Current app version: 2.9.0 [INFO] Running on: windows/64bit/python 3.12.2 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. [INFO] Current progress: [1/1] [INFO] Finished generating the download commands. [INFO] Saved the generated download commands to app_files\cmds.txt [INFO] If you used a VPN, turn it off to avoid wasting data for the downloading stage. Also you may edit the app_files\cmds.txt file if necessary. Type yes when ready: no [INFO] Cancelling the downloading stage.
Code:N_m3u8DL-RE "https://evs-ltcu-dash-secure2.akamaized.net/out/v1/845fb899c73345e08ebf77d214af5c3f/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd" --key 352b4c727dea4884b657ccc0e8002306:ed4219f37091e753d6e28358a5529394 --save-dir "media\eurovisionsport_com" --save-name "Sol_-_Finale" --check-segments-count false -M format=mkv
Hello
it seems that the tool doesn't work for Gully; no DRM's on this channel but I'm looking for the batch downloading feature of the tool here; I'd like to grab these videos:
https://replay.gulli.fr/dessins-animes/Zig-et-Sharko-s04
is it possible to implement it in the tool or not?
thanks for answer -
I don't add sites by request. If you want batch downloaders for your favourite sites, you can try learning scripting. There are guides on the internet
v2.10.0:
=> + play.virginmediatelevision.ie
=> + vix.com
=> - dazn.com : Removed the service cause of unreliable user agent trick.
Minor changes:
=> extended the 35mm.online service : Now you can download entire seasons for specific shows.
=> renamed the 6play.fr service to m6.fr because of the site's name change
=> fixed some bugs for cda.pl, npo.nl and vtmgo.beLast edited by 2nHxWW6GkN1l916N3ayz8HQoi; 18th Nov 2024 at 15:22.
Hello. I won't publish this on github due to a variety reasons. One of them is that I intend to be the only main contributor to its source code. Sure, a bug code fix is always appreciated but this forum post is enough to just propose a small code snippet to fix something. Plus, more people just download the exe file, so it's not worth it for me the hassle.
If you have coding skills and like to write services, then go for devine. They have documentation and you can look at how others wrote their own services. I won't add documentation/template for this tool, since, as I said, I'm the only one responsible for maintaining it.
As for rtlplay, I won't add it since I don't have access to that site via free vpns.--[----->+<]>.++++++++++++.---.--------.
Good morning
I have an error when I want to download a francetv program I am French with a French IP address
python widefrog.py "https://www.france.tv/france-5/les-5-vies-de-la-terre/6657002-l-air.html"
[INFO] Current app version: 2.10.0
[INFO] Running on: windows/64bit/python 3.12.6
[APP_ERROR] Failed to download: https://www.france.tv/france-5/les-5-vies-de-la-terre/6657002-l-air.html. Reason: Failed to initialize the france_tv service. Solution: Debug the service.
[WARNING] Saved the failed URLs to app_files\cmds_failed.txt
[WARNING] No download commands have been generated.]
debug :
python widefrog.py "https://www.france.tv/france-5/les-5-vies-de-la-terre/6657002-l-air.html" --debug
File "C:\Users\sebastien\Desktop\widefrog\widefrog. py", line 113, in <module>
main_service.run_service(response)
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 400, in run_service
dwn_cmds, failed_cmds = main_service.get_download_commands_parallel(demo_u rls)
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 335, in get_download_commands_parallel
source_urls, failures = main_service.initialize_services(source_urls)
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 322, in initialize_services
if service_tools.get_service(source_url) is not None:
File "C:\Users\sebastien\Desktop\widefrog\utils\tools\s ervice.py", line 70, in get_service
raise e
File "C:\Users\sebastien\Desktop\widefrog\utils\tools\s ervice.py", line 54, in get_service
service = service.initialize_service()
File "C:\Users\sebastien\Desktop\widefrog\services\fran ce_tv.py", line 64, in initialize_service
france_tv.set_endpoints()
File "C:\Users\sebastien\Desktop\widefrog\services\fran ce_tv.py", line 56, in set_endpoints
france_tv.LICENSE_URL = re.findall(r'widevineLaUrl:"([^"]+)"', response)[0]
IndexError: list index out of range
Hello. They changed something recently. A quick fix is to edit and replace line ~56
withCode:france_tv.LICENSE_URL = re.findall(r'widevineLaUrl:"([^"]+)"', response)[0]
in france_tv.py fileCode:france_tv.LICENSE_URL = "https://api-drm.ftven.fr/v1/wvls/contentlicenseservice/v1/licenses"
Good morning
I have an error when I want to download a bfmtv program I am French with a French IP address
python widefrog.py "https://www.rmcbfmplay.com/video/rmc-decouverte/gladiateurs-des-origines-a-la-chute-du-colisee/e5-antioche-le-martyr-chretien-du-colisee?contentId=Product::NEUF_RMCDEC_RMC00214747 &universe=PROVIDER" --debug
raise e
File "C:\Users\sebastien\Desktop\widefrog\services\rmcb fmplay_com.py", line 110, in initialize_service
rmcbfmplay_com.BFM_TOKEN = rmcbfmplay_com.get_token()
File "C:\Users\sebastien\Desktop\widefrog\services\rmcb fmplay_com.py", line 62, in get_token
credentials = builtins.CONFIG["SERVICE_CREDENTIALS"][class_name]
Hello. Works fine for me. Delete the entire tool foder, do a fresh install, and set the right credentials.
Code:python widefrog.py "https://www.rmcbfmplay.com/video/rmc-decouverte/gladiateurs-des-origines-a-la-chute-du-colisee/e5-antioche-le-martyr-chretien-du-colisee?contentId=Product::NEUF_RMCDEC_RMC00214747&universe=PROVIDER" [INFO] Current app version: 2.10.0 [INFO] Running on: windows/64bit/python 3.12.2 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. [INFO] Current progress: [1/1] [INFO] Finished generating the download commands. [INFO] Saved the generated download commands to app_files\cmds.txt [INFO] If you used a VPN, turn it off to avoid wasting data for the downloading stage. Also you may edit the app_files\cmds.txt file if necessary. Type yes when ready: no [INFO] Cancelling the downloading stage.
Code:N_m3u8DL-RE "https://ncdn-cu-kairos.pfd.sfr.net/dashcenc/catchup/NEUF_RMCDEC/ee7/RMC_d6c9b7e573_e3ee245b48e541f6a/manifest.mpd" --key aa8be47a53db29b0e0533b28450a1cbb:1a1027b7e1c097a80e4bd4522c8ea4e4 --save-dir "media\rmcbfmplay_com" --save-name "E5_-_Antioche_le_martyr_chretien_du_Colisee" -M format=mkv
Hello, I have an error with FranceTV, on French IP.
An account is required to play a video in browser, but there is no 'Service Credentials' for FranceTV in config.json file.Code:D:\widefrog_v2_10_0_windows>widefrog.exe https://www.france.tv/documentaires/documentaires-societe/6651473-restos-du-coeur-40-ans-de-solidarite-en-france.html [INFO] Current app version: 2.10.0 [INFO] Running on: windows/64bit/python 3.12.2 [INFO] Starting the service initialization stage. [APP_ERROR] Failed to download: https://www.france.tv/documentaires/documentaires-societe/6651473-restos-du-coeur-40-ans-de-solidarite-en-france.html. Reason: Failed to initialize the france_tv service. Solution: Debug the service. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Starting the media data extraction stage. [INFO] Finished generating the download commands. [WARNING] Saved the failed URLs to app_files\cmds_failed.txt [WARNING] No download commands have been generated.
Bonjour. You don't need an account to download from them, even if they restrict the video playing to an account. You can use the python version with the fix from post #256. It will be included in the next version in the exe file as well.
hello
I have just done a fresh installation, there is an error on rmcbfm I have a French IP because I am French, does bfm change the DRM?
edit: post delete Its work SorryLast edited by diesel; 30th Nov 2024 at 16:15. Reason: resolved
hello error with the channel tf1 I have a French IP is a subscription with the correct login and password in the config.json file
python widefrog.py "https://www.tf1.fr/tmc/lagence-limmobilier-de-luxe-en-famille" --query=4::4: --debug
[USER_ERROR]/[APP_ERROR] Failed to download: https://www.tf1.fr/tmc/lagence-limmobilier-de-luxe-en-famille. Reason: Failed to initialize the tf1_fr service. Solution: Check the service credentials in the app_files\config.json file. If you are sure everything is right then debug the service.
[WARNING] No download commands have been generated. -
Make sure you use the proper URL ending in "/videos". You can access by clicking on "Voir tout" at the bottom of the show page. Also check you put the right credentials. If still problems, try a fresh install.Code:python widefrog.py "https://www.tf1.fr/tmc/lagence-limmobilier-de-luxe-en-famille/videos" --query=4::4: [INFO] Current app version: 2.10.0 [INFO] Running on: windows/64bit/python 3.12.2 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. [INFO] Current progress: [1/10] [INFO] Current progress: [2/10] [INFO] Current progress: [3/10] [INFO] Current progress: [4/10] [INFO] Current progress: [5/10] [INFO] Current progress: [6/10] [INFO] Current progress: [7/10] [INFO] Current progress: [8/10] [INFO] Current progress: [9/10] [INFO] Current progress: [10/10] [INFO] Finished generating the download commands. [INFO] Saved the generated download commands to app_files\cmds.txt [INFO] If you used a VPN, turn it off to avoid wasting data for the downloading stage. Also you may edit the app_files\cmds.txt file if necessary. Type yes when ready: no [INFO] Cancelling the downloading stage.
Hello. There's a list of the supported sites in the first post. viu.com isn't in that list
hello I came to report a bug on the m6 service
python widefrog.py "https://www.m6.fr/enquetes-criminelles-p_986/dany-leprince-je-ne-suis-pas-un-assassin-c_13104436" --debug
[INFO] Running on: windows/64bit/python 3.12.0
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 355, in get_download_commands_parallel
success, fail = future.result()
File "C:\Users\sebastien\AppData\Local\Programs\Python\ Python312\Lib\concurrent\futures\_base.py", line 449, in result
return self.__get_result()
File "C:\Users\sebastien\AppData\Local\Programs\Python\ Python312\Lib\concurrent\futures\_base.py", line 401, in __get_result
raise self._exception
File "C:\Users\sebastien\AppData\Local\Programs\Python\ Python312\Lib\concurrent\futures\thread.py", line 58, in run
result = self.fn(*self.args, **self.kwargs)
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 242, in get_download_commands
raise e
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 233, in get_download_commands
download_command = main_service.get_download_command(service, source_element)
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 77, in get_download_command
raise e
File "C:\Users\sebastien\Desktop\widefrog\utils\main_se rvice.py", line 63, in get_download_command
manifest, pssh, additional = service.get_video_data(source_element)
File "C:\Users\sebastien\Desktop\widefrog\services\m6_f r.py", line 353, in get_video_data
raise CustomException(ERR_MSG.format(
utils.structs.CustomException: [USER_ERROR] Failed to download: https://www.m6.fr/enquetes-criminelles-p_986/dany-leprince-je-ne-suis-pas-un-assassin-c_13104436. Reason: The content isn't available. Solution: Do not attempt to download it.
and bug francetv
widefrog.py "https://www.france.tv/films/3088143-la-bonne-epouse.html" --debug
raise e
NameError: name 'response' is not definedLast edited by diesel; 12th Dec 2024 at 07:57.
bug also rmcbfmtv
python widefrog.py "https://www.rmcbfmplay.com/video/rmc-bfm-play/la-capitale-gauloise-disparue?contentId=Product::NEUF_BFMAVOD_BAV001462 09&universe=PROVIDER" --debug
raise e
File "C:\Users\sebastien\Desktop\widefrog\services\rmcb fmplay_com.py", line 91, in get_token
redirect = response.headers["location"]
File "C:\Users\sebastien\AppData\Local\Programs\Python\ Python312\Lib\site-packages\requests\structures.py", line 52, in __getitem__
return self._store[key.lower()][1]
KeyError: 'location' -
Hello. For francetv and rmcbfmtv, it works both times for me and I can't reproduce the error. And for m6, I can't access the video so I can't fix if there's any bug. Tried for videos that I can access and use DRM, and it works. I guess you should try again and if it still doesn't work, use another way of downloading that is meant to be more general.
Batch IMDB Image Downloader
By Jay123210599 in forum ComputerReplies: 3Last Post: 11th Jan 2024, 13:02 -
Help downloading DRM protected content
By edenshapira in forum Video Streaming DownloadingReplies: 0Last Post: 28th Oct 2023, 15:59 -
Downloading DRM protected content from mewatch.sg
By notred in forum Video Streaming DownloadingReplies: 4Last Post: 25th Nov 2022, 05:34 -
Weird Behaviour Of DRM Protected Content
By portalie in forum Video Streaming DownloadingReplies: 1Last Post: 6th Feb 2022, 16:10
