v2.9.0:
=> + tg4.ie
=> + watch.tbn.uk
=> - open.spotify.com : The site now needs real cdms and I'm pretty sure you can get one toasted in specific conditions. So I got rid of spotify service. Thanks @lomero for explaining this issue.
Minor changes:
=> fixed some bugs for cda.pl and tf1.fr
=> updated the requirements.txt file
Results 211 to 240 of 546
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
I am trying to use the this file...
https://files.videohelp.com/u/308780/widefrog_v2_1_0_linux.zip
in Ubuntu 22.04, but I keep getting this error when I try to run it...
[12905] Failed to load Python shared library '/tmp/_MEI8kDrIJ/libpython3.12.so.1.0': dlopen: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.38' not found (required by /tmp/_MEI8kDrIJ/libpython3.12.so.1.0)
I am wondering is there an easy way to fix this? -
No idea. I assume you need to update glibc to 2.38. Just use python version instead of the linux executable.
i found a series which is giving error while trying to download (35mm online)
looks like it's not being recognized as a collection. can you look into it ?Code:https://35mm.online/vod/dla-dzieci/reksio
That's cause I had no idea content like that existed. I'll check to see if I can query that entire season without messing things up.
trying to download following serie but it errors out.
tried the examples in the first post but its the same.Code:https://npo.nl/start/serie/reizen-waes/seizoen-7_1/onder-de-rivieren/afspelen
[Attachment 83108 - Click to enlarge] -
Npo nl recently changed something. It can be fixed by changing the code for the service npo_nl.py at line ~232
becomesCode:).content.decode())["token"]
If you only use the exe, you're gonna have to wait till next release.Code:).content.decode())["jwt"]
In the newest Widefrog.exe release 2.9.0, i ran into a warning which never occured since now and also show in 2.8 since now. (2.8 was working fine a week ago)
Code:C:\Users\netzt\Videos\FFMPEG\widefrog_v2_9_0_windows>widefrog.exe [WARNING] External tool is not installed: N_m3u8DL-RE. Download commands may not be launched properly.
That happens because N_m3u8DL-RE isn't properly set in system env vars. Open cmd in a random folder and check if N_m3u8DL-RE is recognized as a command. Or you can simply move the N_m3u8DL-RE exe in the same folder as the download tool.
Okay wow i didn't notice it, maybe i screwed smth up in the meantime.. i will take another look into this.
Edit: works smooth like butter again. Thanks and keep up the great work (i have no idea how tf i messed this up)Last edited by Casseopaya; 27th Oct 2024 at 08:18.
https://www.futurly.com/s/preview/courses/blender-architecture#6337f80fe4b05a534f0e3d5a
can you share where is the decryptor part is located of the key?
like the key itself is encrypted. i just wanna know where is the code of decryption of key located. please help? -
Search for 'window.apkId.substring'
Here is your video : https://gofile.io/d/EMDwau -
Honestly I forgot. It will be added or not added when in the next version. Just be patient.
Thanks for the found bug and also the fix (again)
Hello
I can't understand, I tried to grab a video on 6play tonight but it doesn't seem to work anymore; I tried last week with another video and everything was ok. My wvd file is still ok, I tried on another plateform and I was able to get the keys.
Do you know if something changed on 6play since last week? I also tried with wks-keys which worked previously but I got the same issue.
Thank you for answer -
Hello. Works fine for me. Unless you provide me the video URL and the error message, I can't help
thank you for your answer
here is the linkk for the video
https://www.m6.fr/le-1945-p_1058/le-1945-du-04-11-2024-c_13098470
and here is the answer I get:
[Attachment 83361 - Click to enlarge]
I tried with V2.9.0 and also with 2.6.0 -
They just changed the site name 6play to m6. It works with
It will be fixed in the next version. Also, you should delete the warned services if you didn't bother properly installing the tool as it was explained in detail in the first postCode:python widefrog.py "https://www.6play.fr/le-1945-p_1058/le-1945-du-04-11-2024-c_13098470"
thank you for answer, I will follow your advices concerning the warned services!
hello all
your forum posts that it was possible to recover broadcasts from rtlplay.be
https://forum.videohelp.com/threads/413893-Download-from-RTL-Play#post2728863
I added the service and put my email and password in the config.json, does this work? -
That script is old and I can't maintain it since I don't have access anymore to that site. Look for another solution.
I'm trying to download something from vtm go, but getting the error
I tried both the windows.exe as the python version.Code:Failed to extract content data. Solution: Make sure you can play the content. If you can, then debug the vtmgo_be service.
Also tried different shows/series/episodes.
Did I missed a prereq?
Batch IMDB Image Downloader
By Jay123210599 in forum ComputerReplies: 3Last Post: 11th Jan 2024, 13:02 -
Help downloading DRM protected content
By edenshapira in forum Video Streaming DownloadingReplies: 0Last Post: 28th Oct 2023, 15:59 -
Downloading DRM protected content from mewatch.sg
By notred in forum Video Streaming DownloadingReplies: 4Last Post: 25th Nov 2022, 05:34 -
Weird Behaviour Of DRM Protected Content
By portalie in forum Video Streaming DownloadingReplies: 1Last Post: 6th Feb 2022, 16:10
