Page 7 of 18
FirstFirst ... 5 6 7 8 9 17 ... LastLast
Results 181 to 210 of 536
  1. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Make sure that you didn't delete any folders from the zip you downloaded. And you'll only use python directly in that tool folder so use cd to change directory or open directly the terminal there.
  2. Hi.
    I didn't delete anything.
    I changed to the directory '/home/heiko2/Downloads/Widefrog v2.7.0'.
    Then tried again. At least the warning is gone now.
    Do I have to change to the directory every time?
    heiko2@Worf2:~$ cd '/home/heiko2/Downloads/Widefrog v2.7.0'
    heiko2@Worf2:~/Downloads/Widefrog v2.7.0$
    heiko2@Worf2:~/Downloads/Widefrog v2.7.0$ python3 '/home/heiko2/Downloads/Widefrog v2.7.0/widefrog.py'
    [INFO] Linux detected. Chosen terminal: gnome-terminal. Chosen shell: bash.
    Best regards
    Heiko
  3. Sorry, I didn't read it properly again.
    I have the file twice now:
    heiko2@Worf2:~/Downloads/Widefrog v2.7.0$ ll /home/heiko2/app_files
    insgesamt 16
    drwxrwxr-x  3 heiko2 heiko2 4096 Okt 11 12:42 ./
    drwxr-x--- 17 heiko2 heiko2 4096 Okt 11 12:42 ../
    -rw-rw-r--  1 heiko2 heiko2 2852 Okt 11 12:42 config.json
    drwxrwxr-x  2 heiko2 heiko2 4096 Okt 11 12:42 services_cache/
    heiko2@Worf2:~/Downloads/Widefrog v2.7.0$ ll "/home/heiko2/Downloads/Widefrog v2.7.0/app_files"
    insgesamt 16
    drwxrwxr-x 3 heiko2 heiko2 4096 Okt 11 12:43 ./
    drwxrwxr-x 6 heiko2 heiko2 4096 Okt 11 12:43 ../
    -rw-rw-r-- 1 heiko2 heiko2 2857 Okt 11 12:46 config.json
    drwxrwxr-x 2 heiko2 heiko2 4096 Okt 11 12:43 services_cache/
    Which is the correct config.json?
    Best regards
    Heiko
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Yes
    The one that is generated in the tool folder. The other one that's outside, delete it. Use the config to input the email and password of your plus.rtl.de account then look in the first post, search for "plus.rtl.de" and look at the example commands and additional comments
    May 2011
    Thanks for this amazing tool!
  6. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    v2.8.0:
    => + app.nzrplus.com
    => + rtp.pt (only the /play/ section)
    Off topic: if someone knows a video from https://www.rtlplay.be/rtlplay that can be viewed outside Belgium, feel free to leave a message
    No problem.
  7. Hello.
    It seems to be working now. Thank you very much.
    But only the channels entered in the config.json are supported. Or?
    Can I add some myself, e.g. www.disneyplus.com?
    Do encrypted .m3u8 pages also work?
    Best regards
    Heiko
  8. Code:
    heiko@Worf:~/Downloads/Widefrog  v2.8.0$ python3 widefrog.py "https://open.spotify.com/intl-de/album/1sTY2Gf3TsSZJ80KfYU7mS"
    [INFO] Current app version: 2.8.0
    [INFO] Running on: linux/64bit/python 3.10.12
    [INFO] Starting the service initialization stage.
    [USER_ERROR]/[APP_ERROR] Failed to download: https://open.spotify.com/intl-de/album/1sTY2Gf3TsSZJ80KfYU7mS. Reason: Failed to initialize the open_spotify_com service. Solution: Check the service credentials in the app_files/config.json file. If you are sure everything is right then debug the service.
    [INFO] Current progress: [1/1]
    [INFO] Starting the collections extraction stage.
    [INFO] Starting the media data extraction stage.
    [INFO] Finished generating the download commands.
    [WARNING] Saved the failed URLs to app_files/cmds_failed.txt
    [WARNING] No download commands have been generated.
  9. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    What did I tell you about reading one sentence and asking me 10 questions? Read the first post. If this tool ain't what you want, use a generic solution for your site. Also disneyplus is paid content so read the rules of the forum as well. You may use google translate if english isn't your first language.
    Edit: from now on I'll ignore your questions that were already answered in the first post, whether or not you have a good grasp of the english language
  10. hello
    is it planned in the future updates of the quebec channels
    telequebec.tv
    ici.tout.tv
    noovo.ca
    these channels are non-paying with drm
    thanks in advance 2nHxWW6GkN1l916N3ayz8HQoi
  11. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Hello. Unfortunately I don't add sites by request. It's entirely random. Also you can find a list of the supported sites in the first post. Currently
    https://video.telequebec.tv is supported. You can find a list of example commands and additional comments by searching for the site name, as always.
  12. I found one case for which cda_pl plugin fails to extract links.
    It happens when in a folder there's only 1 page (eg. https://www.cda.pl/Bajki123/folder/19713517/vfilm)
    From what i discovered it's because 'paginationControl' div is not present.
    Here's what i came up with
                    pag_div = soup.find('div', class_='paginationControl')  # Find the pagination div
                    if pag_div:  # Check if pag_div is present
                        try:
                            if not is_folder:
                                disabled_page = pag_div.find('span', class_='disabledPage').text
                            else:
                                disabled_page = pag_div.find('li', class_='active').find('a').text
                            if disabled_page != str(page):
                                break
                        except:
                            break
                        check = check_range(True, page, None)
                        if check is True:
                            continue
                        elif check is False:
                            return collection
                    else: # break when paginationControl div is not present and 1 page was already processed
                        if page > 1:
                            break
  13. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Thanks for the found bug and also the fix. Will add it in the next version.
  14. Member MartinTH's Avatar
    Oct 2024
    Germany
    I get this Error Message every time I try to download a Video Podcast from Spotify:
    H:\widefrog>widefrog.exe https://open.spotify.com/episode/2Bz7rpQM3nTeGlkvByQBdS
    [INFO] Current app version: 2.7.0
    [INFO] Running on: windows/64bit/python 3.12.2
    [USER_ERROR]/[APP_ERROR] Failed to download: https://open.spotify.com/episode/2Bz7rpQM3nTeGlkvByQBdS. Reason: Failed to initialize the open_spotify_com service. Solution: Check the service credentials in the app_files\config.json file. If you are sure everything is right then debug the service.
    [WARNING] Saved the failed URLs to app_files\cmds_failed.txt
  15. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Thanks for notifying. I'll take a look into the latest librespot release. If I don't figure out Rust to Python, I'll most likely remove the spotify service.
  16. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    about that look my PM
  17. Hello
    I followed the order that you gave me to download the individual season, that is to say season 13 of top chef. I noticed today that the order takes all the seasons appearing on m6.play. Have you made any changes to the orders? query or is it the site that changed its algorithm thank you for your answer in advance
    Best Regards
  18. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I don't understand the problem. Running
    python widefrog.py "https://www.6play.fr/top-chef-p_872" --query=6::6:
    Will get you all 18 episodes of season 13 that is represented by the 6 Rail. Isn't that what you want? The entire season 13?
  19. your query work all seasons but not for individually could you test it , abd let mee now if its work
    thanks by advance
  20. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You lost me. Write the exact command you're trying to run like I did and explain what is the specific output you want to happen.
  21. I'm testing commands
    and
    this gives me all the episodes of all the seasons
  22. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Sorry but for me
    [INFO] Current progress: [1/18]
    [INFO] Current progress: [2/18]
    [INFO] Current progress: [17/18]
    [INFO] Current progress: [18/18]
    [INFO] Saved the generated download commands to app_files\cmds.txt
    [INFO] If you used a VPN, turn it off to avoid wasting data for the downloading stage. Also you may edit the app_files\cmds.txt file if necessary. Type yes when ready: no
    [INFO] Cancelling the downloading stage.
    Gives me all of the 18 episodes for season 13. Can't fix an issue that I can't replicate. I guess make sure you're using the latest version. That's all I can say.
  23. just for test i've tried your command
    but i get error (maybe same error from the user above?)
    [Attachment 82978 - Click to enlarge]
    so, my question is:
    1) why all warning about nzrplus.com, cda.pl, spotify.com and many more if I'm not calling these services but only 6play?
    maybe useless warning?
    i've already edit config.json on "WARN_EXTERNAL_TOOLS": false but i gather this is only related to N_m3u8DL-RE when not installed on env
    other solution to not show others warnings outside the service you're calling ?
    2) the command above for widefrog can't work for me too, but i have login and i can play video from 6play
  24. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    1. They're essential warnings because they indicate you didn't properly install all of the necessary requirements as it was explained in the first post. Whenever you update to a new version, you need to install from scratch if the requirements.txt file was also updated. If you don't care about the mentioned warned services, you are free to delete them from the services folder
    2. not saying there aren't any problems, just saying I can't replicate the issue. Add --debug to your command and show me the output please.
  25. updated requirements.txt, same error.
    about the warnings i hope that in the next versions you can remove the warnings not related to the service that is being called, that is to show only a warning if the service in question has a problem. it is useless (in my humble opinion) to show warnings to all the services if then only one of them is used (and maybe this works)
    about debug here my shot:
    [Attachment 82979 - Click to enlarge]
  26. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Solved issue because of outdated urllib3 package
    pip install urllib3 --upgrade
    And also badly installed python dependencies. 6play then worked as intended
  27. yes, solved thanks to great support of 2nHxWW6GkN1l916N3ayz8HQoi
    my bad is run pip install -r requirements.txt (see point 2 Installation from first page of this thread)
    now all work fine, 6play issue solved.
  28. hello
    how to download a whole season of season 8 on tf1 I can't do it
    https://www.tf1.fr/tfx/mamans-et-celebres/videos/saison-8
    Best Regards
  29. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Hello. Normally a command like
    python widefrog.py "https://www.tf1.fr/tfx/mamans-et-celebres/videos" --query=8::8:
    does the job. But in this case they changed something in the site. Will fix it in next version. Thanks for reporting the issue.
  30. python widefrog.py "https://www.tf1.fr/tfx/mamans-et-celebres/videos" --query=8::8:
    [INFO] Current app version: 2.6.0
    [INFO] Running on: windows/64bit/python 3.12.6
